<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Forcing users to only use passwordless auth]]></title><description><![CDATA[<p dir="auto">Is it possible to force passwordless as the only option for specific users when they log in?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/280/forcing-users-to-only-use-passwordless-auth</link><generator>RSS for Node</generator><lastBuildDate>Tue, 17 Nov 2026 04:08:28 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/280.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 06 Aug 2020 15:52:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Forcing users to only use passwordless auth on Thu, 06 Aug 2020 16:08:51 GMT]]></title><description><![CDATA[<p dir="auto">Not through a FusionAuth policy, but you can do that in the login template if you want to filter it by email domain or something like that.</p>
<p dir="auto">If you have not let the user set their password, then passwordless will implicitly be the only path that will work for them (assuming you don’t offer them social login buttons).</p>
<p dir="auto">If you pass the user’s email on the redirect to FusionAuth as <code>&amp;loginId=test@example.com</code>, that value will be available to you in the template and you can then key off, parse the domain, or whatever - and use that to hide or show whatever you like.</p>
]]></description><link>https://fusionauth.io/community/forum/post/774</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/774</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Thu, 06 Aug 2020 16:08:51 GMT</pubDate></item></channel></rss>
