<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Implementing Security Questions with FusionAuth]]></title><description><![CDATA[<p dir="auto">How can we integrate security questions into FusionAuth? Specifically:<br />
<strong>a)</strong> Authoring security questions.<br />
<strong>b)</strong> Using security questions during the registration workflow.<br />
<strong>c)</strong> Using security questions during credential recovery.</p>
]]></description><link>https://fusionauth.io/community/forum/topic/2833/implementing-security-questions-with-fusionauth</link><generator>RSS for Node</generator><lastBuildDate>Sun, 15 Nov 2026 03:48:36 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/2833.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 31 Dec 2024 20:35:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Implementing Security Questions with FusionAuth on Tue, 31 Dec 2024 20:37:11 GMT]]></title><description><![CDATA[<p dir="auto">FusionAuth does not currently provide out-of-the-box support for security questions.</p>
<p dir="auto">If security questions are critical to your solution, you would need to implement this functionality externally and integrate it with FusionAuth using API calls. For example:</p>
<li><strong>Authoring Security Questions</strong>: Create a custom interface for users to set up their security questions and store these securely in your system.</li>
<li><strong>Using Security Questions During Registration</strong>: Extend your registration workflow to include security questions, then associate the responses with the user data stored in your database.</li>
<li><strong>Using Security Questions During Credential Recovery</strong>: Implement a custom flow to verify the user's identity using security questions before proceeding with a password reset, and use FusionAuth’s APIs to handle credential recovery.</li>
<p dir="auto">By building this functionality externally and integrating it via FusionAuth’s APIs, you can achieve the desired security question workflow while maintaining compatibility with FusionAuth.</p>
]]></description><link>https://fusionauth.io/community/forum/post/7697</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7697</guid><dc:creator><![CDATA[wesley]]></dc:creator><pubDate>Tue, 31 Dec 2024 20:37:11 GMT</pubDate></item></channel></rss>
