<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[What is the relationship between Tenants, SCIM Entity Types, and SCIM Entities?]]></title><description><![CDATA[<p dir="auto">To create a User in a Tenant with SCIM, you have to create a client and server entity, and enable SCIM for the Tenant linked to the <strong>SCIM Entity Type</strong>, not to the <strong>SCIM Entity</strong>.</p>
<p dir="auto">How exactly does this work? Why is there no relationship between the entity and the tenant? I could have multiple SCIM server and client entities, with different permissions, but the Tenant ignores all that and considers only the default SCIM Entity Type when allowing you to create or delete a user.</p>
]]></description><link>https://fusionauth.io/community/forum/topic/2837/what-is-the-relationship-between-tenants-scim-entity-types-and-scim-entities</link><generator>RSS for Node</generator><lastBuildDate>Thu, 15 Oct 2026 08:33:39 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/2837.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 03 Jan 2025 10:29:39 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to What is the relationship between Tenants, SCIM Entity Types, and SCIM Entities? on Fri, 10 Jan 2025 04:53:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2884">@fusionauth-qhj5e</a> <a href="https://fusionauth.io/docs/lifecycle/migrate-users/scim/#configuration" rel="nofollow ugc">Here is some documentation</a> on the subject.  Hope it helps.</p>
]]></description><link>https://fusionauth.io/community/forum/post/7729</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7729</guid><dc:creator><![CDATA[mark.robustelli]]></dc:creator><pubDate>Fri, 10 Jan 2025 04:53:59 GMT</pubDate></item><item><title><![CDATA[Reply to What is the relationship between Tenants, SCIM Entity Types, and SCIM Entities? on Mon, 06 Jan 2025 08:17:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2507">@mark-robustelli</a> Thanks. I'm configuring a single SCIM tenant with a client. I want to understand why tenants use entity types instead of entities, and how the permissions relate, so I can document it.</p>
]]></description><link>https://fusionauth.io/community/forum/post/7712</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7712</guid><dc:creator><![CDATA[fusionauth.qhj5e]]></dc:creator><pubDate>Mon, 06 Jan 2025 08:17:09 GMT</pubDate></item><item><title><![CDATA[Reply to What is the relationship between Tenants, SCIM Entity Types, and SCIM Entities? on Fri, 03 Jan 2025 14:47:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2884">@fusionauth-qhj5e</a> Are you currently trying to set up multiple SCIM server and client entities? Can you give us a little more background on how you are trying to configure things?  There may not be a way to implement multiple SCIM Entity Types, but could be a feature request. Explaining the use case in detail, could help the team to prioritize.</p>
]]></description><link>https://fusionauth.io/community/forum/post/7705</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7705</guid><dc:creator><![CDATA[mark.robustelli]]></dc:creator><pubDate>Fri, 03 Jan 2025 14:47:12 GMT</pubDate></item></channel></rss>
