<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Failure when starting FusionAuth in Docker on Mac M4]]></title><description><![CDATA[<p dir="auto">When running FusionAuth in Docker on an m4 mac, I see this error:</p>
<pre><code># A fatal error has been detected by the Java Runtime Environment:
#  SIGILL (0x4) at pc=0x0000ffff8d33fc5c, pid=1, tid=21
# JRE version:  (21.0.4+7) (build )
# Java VM: OpenJDK 64-Bit Server VM (21.0.4+7-LTS, mixed mode, tiered, compressed oops, compressed class ptrs, g1 gc, linux-aarch64)
# Problematic frame:
# j  java.lang.System.registerNatives()V+0 java.base
# No core dump will be written. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
---------------  S U M M A R Y ------------
Command Line: -Dfusionauth.home.directory=/usr/local/fusionauth/fusionauth-app -Dfusionauth.config.directory=/usr/local/fusionauth/config -Dfusionauth.data.directory=/usr/local/fusionauth/data -Dfusionauth.log.directory=/usr/local/fusionauth/logs -Dfusionauth.plugin.directory=/usr/local/fusionauth/plugins -Djava.awt.headless=true -Dcom.sun.org.apache.xml.internal.security.ignoreLineBreaks=true --add-exports=java.base/sun.security.x509=ALL-UNNAMED --add-exports=java.base/sun.security.util=ALL-UNNAMED --add-opens=java.base/java.net=ALL-UNNAMED -DfusionAuthApp87AFBG16 -Xmx512M -Xms512M io.fusionauth.app.FusionAuthMain
Host: AArch64, 14 cores, 7G, Ubuntu 24.04.1 LTS
Time: Wed Jan 22 12:35:29 2025 UTC elapsed time: 0.025614 seconds (0d 0h 0m 0s)
---------------  T H R E A D  ---------------
Current thread (0x0000ffff9802c010):  JavaThread "Unknown thread" [_thread_in_native, id=21, stack(0x0000ffff9e152000,0x0000ffff9e350000) (2040K)]
Stack: [0x0000ffff9e152000,0x0000ffff9e350000],  sp=0x0000ffff9e34e000,  free space=2032k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
j  java.lang.System.&lt;clinit&gt;()V+0 java.base
v  ~StubRoutines::call_stub 0x0000ffff8d337144
V  [libjvm.so+0x8338d8]  JavaCalls::call_helper(JavaValue*, methodHandle const&amp;, JavaCallArguments*, JavaThread*)+0x218
V  [libjvm.so+0x80f488]  InstanceKlass::call_class_initializer(JavaThread*)+0x284
V  [libjvm.so+0x8101a8]  InstanceKlass::initialize_impl(JavaThread*)+0x528
V  [libjvm.so+0xdc7138]  Threads::initialize_java_lang_classes(JavaThread*, JavaThread*)+0xe8
V  [libjvm.so+0xdc9104]  Threads::create_vm(JavaVMInitArgs*, bool*)+0x3f4
V  [libjvm.so+0x8c68d4]  JNI_CreateJavaVM+0x80
C  [libjli.so+0x8bac]  JavaMain+0x7c
C  [libjli.so+0xc20c]  ThreadJavaMain+0xc
C  [libc.so.6+0x8597c]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
siginfo: si_signo: 4 (SIGILL), si_code: 1 (ILL_ILLOPC), si_addr: 0x0000ffff8d33fc5c
Registers:
R0=0x0000000000000000
R1=0x0000000000000000
R2=0x0000000000000000
<p dir="auto">What can I do?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/2853/failure-when-starting-fusionauth-in-docker-on-mac-m4</link><generator>RSS for Node</generator><lastBuildDate>Mon, 16 Nov 2026 13:48:23 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/2853.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 22 Jan 2025 22:09:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Failure when starting FusionAuth in Docker on Mac M4 on Wed, 22 Jan 2025 22:18:01 GMT]]></title><description><![CDATA[<p dir="auto">This is due to a <a href="https://bugs.openjdk.org/browse/JDK-8345296" rel="nofollow ugc">bug in the openjdk java library</a> that the docker image uses. You can learn more about the bug here and track our fix (which looks like upgrading the java image our docker file users) <a href="https://github.com/FusionAuth/fusionauth-issues/issues/2973" rel="nofollow ugc">by following this bug</a>.</p>
<p dir="auto">Until then, the workaround is to pass this java argument at start time:</p>
<pre><code>-XX:UseSVE=0
<p dir="auto">This argument disables the use of the <a href="https://developer.arm.com/documentation/102476/0100/Introducing-SVE" rel="nofollow ugc">SVE extension</a>, which is provides "better data parallelism for HPC and ML".</p>
<p dir="auto">You can do that with the <code>FUSIONAUTH_APP_ADDITIONAL_JAVA_ARGS</code> environment variable in your Dockerfile. Here's an example:</p>
<pre><code>  fusionauth:
    environment:
      FUSIONAUTH_APP_ADDITIONAL_JAVA_ARGS: -XX:UseSVE=0
]]></description><link>https://fusionauth.io/community/forum/post/7776</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7776</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Wed, 22 Jan 2025 22:18:01 GMT</pubDate></item></channel></rss>
