<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Webhook Error]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I've had working webhooks for sometime and recently added the ability in my application to modify the user registration which is sending a user registration update. I can see on my side that I receive and process the webhook in a few seconds using the C# code below. Also see below for the content of the Webhook log in FusionAuth.</p>
<p dir="auto">Other random note since I updated to 1.55.1 I don't seem to be able to test webhooks, while developing my handler the test feature worked fine. If I cut and paste the json from the log and paste into the test my webhook app throws exceptions on trying to parse the tenantID portion, regardless of what webhook type I test. I've had a few moving parts so this issue might be on me, but I can't put a finger on it.</p>
<p dir="auto">Any ideas on what might be going wrong here?</p>
<p dir="auto">Thanks,<br />
-Paul</p>
<p dir="auto">webhook code:<br />
using (StreamReader reader = new StreamReader(context.Request.Body, Encoding.UTF8))<br />
{<br />
try<br />
{<br />
string jsonString = await reader.ReadToEndAsync();<br />
using (JsonDocument document = JsonDocument.Parse(jsonString))<br />
//lots of code<br />
context.Response.StatusCode = 200;<br />
Log.Information("FusionAuth Success");<br />
return jsonString;<br />
}</p>
<p dir="auto">Webhook log info below:</p>
<p dir="auto">Webhook [<a href="http://xxxxxxxx:8080/webapi/fusionauth" rel="nofollow ugc">http://xxxxxxxx:8080/webapi/fusionauth</a>] returned response code [-1] when sending [UserRegistrationUpdate] event with Id [xxxxxxxxxxxxxxxxxxxx].</p>
<p dir="auto">Exception:<br />
java.net.SocketTimeoutException: Read timed out<br />
at java.base/sun.nio.ch.NioSocketImpl.timedRead(NioSocketImpl.java:278)<br />
at java.base/sun.nio.ch.NioSocketImpl.implRead(NioSocketImpl.java:304)<br />
at java.base/sun.nio.ch.NioSocketImpl.read(NioSocketImpl.java:346)<br />
at java.base/sun.nio.ch.NioSocketImpl$1.read(NioSocketImpl.java:796)<br />
at java.base/java.net.Socket$SocketInputStream.read(Socket.java:1099)<br />
at java.base/java.io.BufferedInputStream.fill(BufferedInputStream.java:291)<br />
at java.base/java.io.BufferedInputStream.read1(BufferedInputStream.java:347)<br />
at java.base/java.io.BufferedInputStream.implRead(BufferedInputStream.java:420)<br />
at java.base/java.io.BufferedInputStream.read(BufferedInputStream.java:399)<br />
at java.base/sun.net.www.http.HttpClient.parseHTTPHeader(HttpClient.java:827)<br />
at java.base/sun.net.www.http.HttpClient.parseHTTP(HttpClient.java:759)<br />
at java.base/sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1690)<br />
at java.base/sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1599)<br />
at java.base/java.net.HttpURLConnection.getResponseCode(HttpURLConnection.java:531)<br />
at com.inversoft.rest.RESTClient.go(RESTClient.java:403)<br />
at io.fusionauth.api.service.event.WebhookEventSender.send(WebhookEventSender.java:114)<br />
at io.fusionauth.api.service.event.DefaultEventExecutorService$SenderTask.call(DefaultEventExecutorService.java:102)<br />
at io.fusionauth.api.service.event.DefaultEventExecutorService$SenderTask.call(DefaultEventExecutorService.java:90)<br />
at com.codahale.metrics.InstrumentedExecutorService$InstrumentedCallable.call(InstrumentedExecutorService.java:197)<br />
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:317)<br />
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1144)<br />
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:642)<br />
at java.base/java.lang.Thread.run(Thread.java:1583)</p>
]]></description><link>https://fusionauth.io/community/forum/topic/2864/webhook-error</link><generator>RSS for Node</generator><lastBuildDate>Fri, 07 Aug 2026 11:18:51 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/2864.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 05 Feb 2025 20:30:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Webhook Error on Wed, 01 Apr 2026 11:57:00 GMT]]></title><description><![CDATA[<p dir="auto">Webhook errors can be a real pain to debug since they often fail silently or with very generic messages. I’ve found that most of the time it comes down to either a TLS/SSL handshake issue or the endpoint expecting a specific header that FusionAuth isn't sending.<br />
One thing that really helps is using a tool like Webhook.site or RequestBin just to see if the event is actually firing and what the payload looks like. If it works there but not on your server, it’s almost certainly a firewall or certificate trust issue on your end. Also, double-check that your secret is matching up perfectly - it’s easy for a stray whitespace to throw the whole signature validation off!</p>
]]></description><link>https://fusionauth.io/community/forum/post/8540</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8540</guid><dc:creator><![CDATA[sjames05569]]></dc:creator><pubDate>Wed, 01 Apr 2026 11:57:00 GMT</pubDate></item><item><title><![CDATA[Reply to Webhook Error on Tue, 15 Jul 2025 09:17:50 GMT]]></title><description><![CDATA[<p dir="auto">FusionAuth is expecting a timely response. If any part of your code reads the body slowly or delays responding, it might exceed FusionAuth's internal timeout (usually around 5–10 seconds).</p>
]]></description><link>https://fusionauth.io/community/forum/post/8250</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8250</guid><dc:creator><![CDATA[joliebillie276]]></dc:creator><pubDate>Tue, 15 Jul 2025 09:17:50 GMT</pubDate></item><item><title><![CDATA[Reply to Webhook Error on Fri, 07 Mar 2025 08:26:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/3391">@paul-1</a> said in <a href="/community/forum/post/7806">Webhook Error</a><a href="https://drifthunters2.io" rel="nofollow ugc">drift hunters</a>:</p>
-Paul</p>
{<br />
try<br />
{<br />
}</p>
at java.base/java.lang.Thread.run(Thread.java:1583)<br />
Your webhook is <strong>timing out</strong>. Try:</p>
<li><strong>Increase FusionAuth timeout</strong> in webhook settings.</li>
<li><strong>Ensure your webhook responds quickly</strong> (log timestamps).</li>
<li><strong>Test manually</strong> with Postman/curl to check response.</li>
<li><strong>Fix <code>tenantId</code> parsing</strong> in test mode.</li>
<li><strong>Check firewall/network issues</strong> if self-hosted.</li>
<p dir="auto">Let me know if you need more help!</p>
]]></description><link>https://fusionauth.io/community/forum/post/7875</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7875</guid><dc:creator><![CDATA[attractivecolt0219]]></dc:creator><pubDate>Fri, 07 Mar 2025 08:26:48 GMT</pubDate></item><item><title><![CDATA[Reply to Webhook Error on Wed, 05 Feb 2025 21:10:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/3391">@paul-1</a> Is it possible that the your code (i.e. //lots of code) is taking too long to process? Can you try to take out most of the code and see if that prevents the time out?</p>
<p dir="auto">As far as the "testing" goes, it seems odd that there is different data.  Have you tried to capture the data actually sent vs what you are testing with and see if there is a difference?</p>
]]></description><link>https://fusionauth.io/community/forum/post/7809</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7809</guid><dc:creator><![CDATA[mark.robustelli]]></dc:creator><pubDate>Wed, 05 Feb 2025 21:10:17 GMT</pubDate></item></channel></rss>
