<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Cannot login to FusionAuth dashboard]]></title><description><![CDATA[<h2>Cannot login to FusionAuth dashboard</h2>
<h3>Description</h3>
<p dir="auto">Our FusionAuth instance was running with no errors until one day, when logging in to FusionAuth we are redirected to "Return to Login" page everytime.</p>
<h3>Observed versions</h3>
<li>Version: 1.45.2</li>
<h3>Expected behavior</h3>
<p dir="auto">Being able to log in to FusionAuth and get redirected to the Admin dashboard</p>
<h3>Screenshots</h3>
<p dir="auto"><img src="https://github.com/user-attachments/assets/627b0f58-27f7-4878-ae1f-dde87169172e" alt="Image" class=" img-fluid img-markdown" /></p>
<h3>Platform</h3>
<li>Device: Desktop</li>
<li>OS: Windows, Apple</li>
<li>Browser + version: Chrome Version 134.0.6998.37 (Official Build) (64-bit)</li>
<li>Database PostgresSQL; Version: 9.6.18-apline</li>
<li>FusionAuth server &amp; FusionAuth DB are running withing a Kubernetes cluster</li>
<h3>Attempted fixes:</h3>
<li>Restart FusionAuth</li>
<li>Restart Database</li>
<li>Tried multiple accounts</li>
<h3>Additional context</h3>
<li>This problem seemed to occur due to an unexpected restart of the PostgresSQL database.</li>
<li>The database is up &amp; running.</li>
<li>Debug log when the database restarted</li>
<pre><code>2025-03-12 03:15:00.232 CET
### Error querying database. Cause: java.sql.SQLTransientConnectionException: HikariPool-1 - Connection is not available, request timed out after 2001ms.
### The error may exist in io/fusionauth/api/domain/InstanceMapper.java (best guess)
### The error may involve io.fusionauth.api.domain.InstanceMapper.retrieve
### Cause: java.sql.SQLTransientConnectionException: HikariPool-1 - Connection is not available, request timed out after 2001ms. at org.apache.ibatis.exceptions.ExceptionFactory.wrapException(ExceptionFactory.java:30) at org.apache.ibatis.session.defaults.DefaultSqlSession.selectList(DefaultSqlSession.java:153) at org.apache.ibatis.session.defaults.DefaultSqlSession.selectList(DefaultSqlSession.java:145) at org.apache.ibatis.session.defaults.DefaultSqlSession.selectList(DefaultSqlSession.java:140) at org.apache.ibatis.session.defaults.DefaultSqlSession.selectOne(DefaultSqlSession.java:76) at jdk.internal.reflect.GeneratedMethodAccessor6.invoke(Unknown Source) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.base/java.lang.reflect.Method.invoke(Method.java:568) at org.apache.ibatis.session.SqlSessionManager$SqlSessionInterceptor.invoke(SqlSessionManager.java:357) at jdk.proxy2/jdk.proxy2.$Proxy52.selectOne(Unknown Source) at org.apache.ibatis.session.SqlSessionManager.selectOne(SqlSessionManager.java:166) at org.apache.ibatis.binding.MapperMethod.execute(MapperMethod.java:87) at org.apache.ibatis.binding.MapperProxy$PlainMethodInvoker.invoke(MapperProxy.java:145) at org.apache.ibatis.binding.MapperProxy.invoke(MapperProxy.java:86) at jdk.proxy2/jdk.proxy2.$Proxy59.retrieve(Unknown Source) at io.fusionauth.api.license.FusionAuthLicenseMetaDataManager.localLookup(FusionAuthLicenseMetaDataManager.java:50) at com.inversoft.license.v2.BaseConfigurationLicenseMetaDataManager.lookup(BaseConfigurationLicenseMetaDataManager.java:30) at com.inversoft.license.v2.local.DefaultLocalLicenseSystem.load(DefaultLocalLicenseSystem.java:35) at com.inversoft.license.v2.DefaultLicenseProvider$LocalReloader.run(DefaultLicenseProvider.java:131) at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) at java.base/java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136) at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635) at java.base/java.lang.Thread.run(Thread.java:833) Caused by: java.sql.SQLTransientConnectionException: HikariPool-1 - Connection is not available, request timed out after 2001ms. at com.zaxxer.hikari.pool.HikariPool.createTimeoutException(HikariPool.java:696) at com.zaxxer.hikari.pool.HikariPool.getConnection(HikariPool.java:181) at com.zaxxer.hikari.pool.HikariPool.getConnection(HikariPool.java:146) at com.zaxxer.hikari.HikariDataSource.getConnection(HikariDataSource.java:100) at org.apache.ibatis.transaction.jdbc.JdbcTransaction.openConnection(JdbcTransaction.java:139) at org.apache.ibatis.transaction.jdbc.JdbcTransaction.getConnection(JdbcTransaction.java:61) at org.apache.ibatis.executor.BaseExecutor.getConnection(BaseExecutor.java:337) at org.apache.ibatis.executor.SimpleExecutor.prepareStatement(SimpleExecutor.java:86) at org.apache.ibatis.executor.SimpleExecutor.doQuery(SimpleExecutor.java:62) at org.apache.ibatis.executor.BaseExecutor.queryFromDatabase(BaseExecutor.java:325) at org.apache.ibatis.executor.BaseExecutor.query(BaseExecutor.java:156) at org.apache.ibatis.executor.CachingExecutor.query(CachingExecutor.java:109) at org.apache.ibatis.executor.CachingExecutor.query(CachingExecutor.java:89) at org.apache.ibatis.session.defaults.DefaultSqlSession.selectList(DefaultSqlSession.java:151) ... 23 common frames omitted Caused by: org.postgresql.util.PSQLException: This connection has been closed. at org.postgresql.jdbc.PgConnection.checkClosed(PgConnection.java:907) at org.postgresql.jdbc.PgConnection.setNetworkTimeout(PgConnection.java:1649) at com.zaxxer.hikari.pool.PoolBase.setNetworkTimeout(PoolBase.java:561) at com.zaxxer.hikari.pool.PoolBase.isConnectionDead(PoolBase.java:168) at com.zaxxer.hikari.pool.HikariPool.getConnection(HikariPool.java:170) ... 35 common frames omitted
2025-03-12 03:15:01.330 CET
2025-03-12 02:15:01.329 AM ERROR io.fusionauth.api.service.system.DefaultAsyncTaskManager - An exception occurred while managing an async task.
### Error querying database. Cause: java.sql.SQLTransientConnectionException: HikariPool-1 - Connection is not available, request timed out after 2000ms.
### The error may exist in io/fusionauth/api/domain/LockMapper.java (best guess)
### The error may involve io.fusionauth.api.domain.LockMapper.lock
<li>Debug log after restart</li>
<pre><code>2025-03-12T09:14:09.786694464Z
2025-03-12T09:14:09.786718924Z
2025-03-12 09:14:09.786 AM WARN com.inversoft.configuration.BasePropertiesFileInversoftConfiguration - Your FusionAuth configuration file [/usr/local/fusionauth/config/fusionauth.properties] needs attention. Here are the warnings:
2025-03-12T09:14:09.786772574Z
2025-03-12T09:14:09.786782694Z
- You are using a deprecated configuration property name of [FUSIONAUTH_APP_HTTP_PORT]. The new allowed names for that property are [fusionauth-app.http.port]
2025-03-12T09:14:09.786789094Z
2025-03-12T09:14:09.786794554Z
2025-03-12T09:14:09.788385584Z
2025-03-12 09:14:09.788 AM INFO com.inversoft.jdbc.hikari.DataSourceProvider - Connecting to PostgreSQL database at [jdbc:postgresql://divizend-auth-db-0:5432/fusionauth]
2025-03-12T09:14:09.791886714Z
2025-03-12 09:14:09.791 AM WARN com.zaxxer.hikari.HikariConfig - HikariPool-1 - idleTimeout has been set but has no effect because the pool is operating as a fixed size pool.
2025-03-12T09:14:09.794193314Z
2025-03-12 09:14:09.793 AM INFO com.zaxxer.hikari.HikariDataSource - HikariPool-1 - Starting...
2025-03-12T09:14:09.819821924Z
2025-03-12 09:14:09.819 AM INFO com.zaxxer.hikari.pool.HikariPool - HikariPool-1 - Added connection org.postgresql.jdbc.PgConnection@6cbe68e9
2025-03-12T09:14:09.831727314Z
2025-03-12 09:14:09.831 AM INFO com.zaxxer.hikari.HikariDataSource - HikariPool-1 - Start completed.
2025-03-12T09:14:11.268084494Z
2025-03-12 09:14:11.267 AM INFO com.inversoft.scheduler.DefaultScheduler - Starting up scheduler
2025-03-12T09:14:11.268828044Z
2025-03-12 09:14:11.268 AM INFO com.inversoft.scheduler.DefaultScheduler - Scheduler is running
2025-03-12T09:14:11.439808283Z
2025-03-12 09:14:11.439 AM INFO io.fusionauth.api.service.system.NodeService - Node [deb1186a-32c4-493e-83a7-a5299b66f6a8] added with address [http://10.52.0.28:80]
2025-03-12T09:14:12.945987592Z
2025-03-12 09:14:12.944 AM ERROR com.inversoft.scheduler.LogAndRetainFailureHandler - The scheduled service [class io.fusionauth.api.service.cache.KeyCacheLoader] failed but will be re-run.
2025-03-12T09:14:12.946030462Z
io.fusionauth.pem.PEMDecoderException: java.security.InvalidKeyException: Could not decode the X.509 public key. Expected at 2 values in the DER encoded sequence but found [2] at io.fusionauth.pem.PEMDecoder.decode(PEMDecoder.java:126) at io.fusionauth.pem.domain.PEM.decode(PEM.java:111) at io.fusionauth.api.service.cache.KeyCacheLoader.internalLoad(KeyCacheLoader.java:101) at com.inversoft.cache.BaseCacheLoader.load(BaseCacheLoader.java:21) at io.fusionauth.api.service.cache.KeyCacheLoader.run(KeyCacheLoader.java:58) at com.inversoft.scheduler.InjectableRunnable.run(InjectableRunnable.java:56) at com.inversoft.scheduler.DefaultScheduler.&lt;init&gt;(DefaultScheduler.java:70) at com.inversoft.scheduler.DefaultScheduler$$FastClassByGuice$$208640461.GUICE$TRAMPOLINE(&lt;generated&gt;) at com.inversoft.scheduler.DefaultScheduler$$FastClassByGuice$$208640461.apply(&lt;generated&gt;) at com.google.inject.internal.DefaultConstructionProxyFactory$FastClassProxy.newInstance(DefaultConstructionProxyFactory.java:82) at com.google.inject.internal.ConstructorInjector.provision(ConstructorInjector.java:114) at com.google.inject.internal.ConstructorInjector.construct(ConstructorInjector.java:91) at com.google.inject.internal.ConstructorBindingImpl$Factory.get(ConstructorBindingImpl.java:300) at com.google.inject.internal.ProviderToInternalFactoryAdapter.get(ProviderToInternalFactoryAdapter.java:40) at com.google.inject.internal.SingletonScope$1.get(SingletonScope.java:169) at com.google.inject.internal.InternalFactoryToProviderAdapter.get(InternalFactoryToProviderAdapter.java:45) at com.google.inject.internal.FactoryProxy.get(FactoryProxy.java:60) at com.google.inject.internal.InternalInjectorCreator.loadEagerSingletons(InternalInjectorCreator.java:213) at com.google.inject.internal.InternalInjectorCreator.injectDynamically(InternalInjectorCreator.java:186) at com.google.inject.internal.InternalInjectorCreator.build(InternalInjectorCreator.java:113) at com.google.inject.Guice.createInjector(Guice.java:87) at com.google.inject.Guice.createInjector(Guice.java:69) at com.google.inject.Guice.createInjector(Guice.java:59) at org.primeframework.mvc.guice.GuiceBootstrap.initialize(GuiceBootstrap.java:60) at org.primeframework.mvc.BasePrimeMain.hup(BasePrimeMain.java:69) at org.primeframework.mvc.BasePrimeMain.start(BasePrimeMain.java:100) at io.fusionauth.app.FusionAuthMain.main(FusionAuthMain.java:27) Caused by: java.security.InvalidKeyException: Could not decode the X.509 public key. Expected at 2 values in the DER encoded sequence but found [2] at io.fusionauth.pem.PEMDecoder.decode_X_509(PEMDecoder.java:334) at io.fusionauth.pem.PEMDecoder.decode(PEMDecoder.java:112) ... 26 common frames omitted
2025-03-12T09:14:15.700435663Z
2025-03-12 09:14:15.699 AM INFO io.fusionauth.api.service.system.NodeService - Node [deb1186a-32c4-493e-83a7-a5299b66f6a8] promoted to master at [2025-03-12T09:14:15.699888323Z], the previous master Node [cf39ac34-f49e-4394-8721-8a2f8bfad22c] has been shutdown or removed
2025-03-12T09:14:16.467362998Z
2025-03-12 09:14:16.466 AM INFO io.fusionauth.app.primeframework.FusionHTTPContextAuthSetup - Initializing the FusionAuth HTTP Context.
2025-03-12T09:14:16.674891576Z
2025-03-12 09:14:16.674 AM INFO org.primeframework.mvc.PrimeMVCRequestHandler - Initializing Prime
2025-03-12T09:14:16.676199576Z
2025-03-12 09:14:16.675 AM INFO org.primeframework.mvc.PrimeMVCRequestHandler - Initializing Prime
2025-03-12T09:14:16.676563276Z
2025-03-12 09:14:16.676 AM INFO io.fusionauth.http.server.HTTPServer - Starting the HTTP server. Buckle up!
2025-03-12T09:14:16.684964236Z
2025-03-12 09:14:16.684 AM INFO io.fusionauth.http.server.HTTPServer - HTTP server listening on port [80]
2025-03-12T09:14:16.684994656Z
2025-03-12 09:14:16.684 AM INFO io.fusionauth.http.server.HTTPServer - HTTP server started successfully
2025-03-12T09:14:16.685016076Z
2025-03-12 09:14:16.684 AM INFO io.fusionauth.http.server.HTTPServer - Starting the HTTP server. Buckle up!
2025-03-12T09:14:16.685700126Z
2025-03-12 09:14:16.685 AM INFO io.fusionauth.http.server.HTTPServer - HTTP server listening on port [9012]
2025-03-12T09:14:16.685722766Z
2025-03-12 09:14:16.685 AM INFO io.fusionauth.http.server.HTTPServer - HTTP server started successfully
]]></description><link>https://fusionauth.io/community/forum/topic/2892/cannot-login-to-fusionauth-dashboard</link><generator>RSS for Node</generator><lastBuildDate>Wed, 12 Aug 2026 05:30:51 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/2892.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 12 Mar 2025 12:04:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Cannot login to FusionAuth dashboard on Wed, 12 Mar 2025 15:09:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/3452">@mohamed-aziz-khayati</a> does this occur simply when you visit the page or when you try to login (submit your username and password)?</p>
]]></description><link>https://fusionauth.io/community/forum/post/7885</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7885</guid><dc:creator><![CDATA[mark.robustelli]]></dc:creator><pubDate>Wed, 12 Mar 2025 15:09:47 GMT</pubDate></item></channel></rss>
