<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Localhost:9011 cant reach this page]]></title><description><![CDATA[<p dir="auto">Been struggling for 3 days to get past this ip address took too long to respond issue.</p>
<p dir="auto">fusionauth-app.log:<br />
2025-04-22 04:12:14.129 PM INFO  io.fusionauth.api.configuration.DefaultFusionAuthConfiguration - Loading FusionAuth configuration file [/var/www/html/fusionauth/config/fusionauth.properties]<br />
2025-04-22 04:12:14.130 PM INFO  io.fusionauth.api.configuration.DefaultFusionAuthConfiguration - Dynamically set property [fusionauth-app.url] set to [<a href="http://localhost:9011" rel="nofollow ugc">http://localhost:9011</a>]<br />
2025-04-22 04:12:14.131 PM INFO  com.inversoft.configuration.BasePropertiesFileInversoftConfiguration -</p>
<li>Overriding default value of property [database.mysql.enforce-utf8mb4] with value [true]</li>
<li>Overriding default value of property [fusionauth-app.runtime-mode] with value [development]</li>
<li>Overriding default value of property [search.type] with value [database]</li>
<p dir="auto">2025-04-22 04:12:14.310 PM INFO  com.inversoft.maintenance.MaintenanceModePoller - Poller started to Wait for configuration to be completed.<br />
2025-04-22 04:12:14.312 PM INFO  io.fusionauth.app.primeframework.FusionHTTPContextAuthSetup - Initializing the FusionAuth HTTP Context.<br />
2025-04-22 04:12:14.362 PM INFO  i.f.app.maintenance.guice.FusionAuthInteractiveMaintenanceModeModule -</p>
<hr />
<h2>--------------------------------------- Entering Maintenance Mode ---------------------------------------</h2>
<p dir="auto">2025-04-22 04:12:14.419 PM INFO  io.fusionauth.api.configuration.DefaultFusionAuthConfiguration - Loading FusionAuth configuration file [/var/www/html/fusionauth/config/fusionauth.properties]<br />
2025-04-22 04:12:14.419 PM INFO  io.fusionauth.api.configuration.DefaultFusionAuthConfiguration - Dynamically set property [fusionauth-app.url] set to [<a href="http://localhost:9011" rel="nofollow ugc">http://localhost:9011</a>]<br />
2025-04-22 04:12:14.420 PM INFO  com.inversoft.configuration.BasePropertiesFileInversoftConfiguration -</p>
<p dir="auto">2025-04-22 04:12:14.421 PM INFO  com.inversoft.maintenance.MaintenanceModePoller - Poller started to Wait for configuration to be completed.<br />
2025-04-22 04:12:14.422 PM INFO  io.fusionauth.app.primeframework.FusionHTTPContextAuthSetup - Initializing the FusionAuth HTTP Context.<br />
2025-04-22 04:12:14.431 PM INFO  org.primeframework.mvc.PrimeMVCRequestHandler - Initializing Prime<br />
2025-04-22 04:12:14.432 PM INFO  org.primeframework.mvc.PrimeMVCRequestHandler - Initializing Prime<br />
2025-04-22 04:12:14.433 PM INFO  io.fusionauth.http.server.HTTPServer - Starting the HTTP server. Buckle up!<br />
2025-04-22 04:12:14.440 PM INFO  io.fusionauth.http.server.HTTPServer - HTTP server listening on port [9011]<br />
2025-04-22 04:12:14.441 PM INFO  io.fusionauth.http.server.HTTPServer - HTTP server started successfully<br />
2025-04-22 04:12:14.441 PM INFO  io.fusionauth.http.server.HTTPServer - Starting the HTTP server. Buckle up!<br />
2025-04-22 04:12:14.442 PM INFO  io.fusionauth.http.server.HTTPServer - HTTP server listening on port [9012]<br />
2025-04-22 04:12:14.442 PM INFO  io.fusionauth.http.server.HTTPServer - HTTP server started successfully</p>
<p dir="auto">any assistance will be greatly appreciated</p>
]]></description><link>https://fusionauth.io/community/forum/topic/2908/localhost-9011-cant-reach-this-page</link><generator>RSS for Node</generator><lastBuildDate>Mon, 15 Jun 2026 14:10:29 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/2908.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 22 Apr 2025 23:36:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Localhost:9011 cant reach this page on Wed, 23 Apr 2025 14:56:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/3495">@arnel-terblanche</a> Can you tell us a little more about your setup? Is this a first time install? Was it working before? Is this a docker image you are trying to run? Please provide more details.</p>
]]></description><link>https://fusionauth.io/community/forum/post/7969</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7969</guid><dc:creator><![CDATA[mark.robustelli]]></dc:creator><pubDate>Wed, 23 Apr 2025 14:56:39 GMT</pubDate></item></channel></rss>
