<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Does FusionAuth support mutual TLS?]]></title><description><![CDATA[<p dir="auto">Hiya,</p>
<p dir="auto">Does FusionAuth support mutual TLS where the client and server both have certificates?</p>
<p dir="auto">(I'm not talking about mTLS token binding; I understand that is not implemented per <a href="https://github.com/FusionAuth/fusionauth-issues/issues/1025" rel="nofollow ugc">https://github.com/FusionAuth/fusionauth-issues/issues/1025</a> .)</p>
]]></description><link>https://fusionauth.io/community/forum/topic/2912/does-fusionauth-support-mutual-tls</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Jul 2026 22:31:30 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/2912.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 02 May 2025 12:31:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Does FusionAuth support mutual TLS? on Fri, 02 May 2025 12:37:41 GMT]]></title><description><![CDATA[<p dir="auto">By using a proxy or gateway that supports mutual TLS, you can use it with FusionAuth.</p>
<p dir="auto">For example, <a href="https://docs.aws.amazon.com/elasticloadbalancing/latest/application/mutual-authentication.html" rel="nofollow ugc">AWS ALB</a> supports <code>Mutual TLS verify</code> where the ALB does client certificate verification. Nginx has <a href="https://nginx.org/en/docs/http/ngx_http_ssl_module.html#ssl_client_certificate" rel="nofollow ugc">similar functionality</a>.</p>
<p dir="auto">If you are running FusionAuth 'bare' and terminating TLS directly at the FusionAuth server, mutual TLS is not supported.</p>
]]></description><link>https://fusionauth.io/community/forum/post/7985</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7985</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Fri, 02 May 2025 12:37:41 GMT</pubDate></item></channel></rss>
