<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Locked out due to template changes]]></title><description><![CDATA[<p dir="auto">Hello guys.</p>
<p dir="auto">I've an issue with a Freemarker template which prevents me from login. (to my application, but even worse to the admin interface).</p>
<p dir="auto">I adjusted some helpers and content of a theme and am completely unable to login anymore. Accounts login page displays a 500 error.</p>
<p dir="auto">I'd like to reset my change in the db. Can anyone guide me in the right direction on how to achieve that?</p>
<p dir="auto">when i list the contents of themes table with</p>
<pre><code>select * from themes;
<p dir="auto">i get a white screen when issued through psql. Listing contents of user table works, however.</p>
]]></description><link>https://fusionauth.io/community/forum/topic/294/locked-out-due-to-template-changes</link><generator>RSS for Node</generator><lastBuildDate>Fri, 06 Nov 2026 13:40:05 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/294.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 12 Aug 2020 15:14:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Locked out due to template changes on Wed, 12 Aug 2020 15:15:09 GMT]]></title><description><![CDATA[<p dir="auto">This link is probably what you are looking for:</p>
<p dir="auto"><a href="https://fusionauth.io/docs/v1/tech/themes/#handling-failures" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/themes/#handling-failures</a></p>
]]></description><link>https://fusionauth.io/community/forum/post/835</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/835</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Wed, 12 Aug 2020 15:15:09 GMT</pubDate></item></channel></rss>
