<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How many applications and tenants can I have in FusionAuth?]]></title><description><![CDATA[<p dir="auto">I'm curious, how many applications and tenants can I have running in FusionAuth?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/295/how-many-applications-and-tenants-can-i-have-in-fusionauth</link><generator>RSS for Node</generator><lastBuildDate>Fri, 06 Nov 2026 22:01:09 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/295.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 12 Aug 2020 15:30:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How many applications and tenants can I have in FusionAuth? on Mon, 17 Aug 2020 19:22:00 GMT]]></title><description><![CDATA[<p dir="auto">Ah, yes, thanks for explaining.</p>
<p dir="auto">Yes</p>
<p dir="auto">You have two options</p>
<li>use the API to integrate with the current login/reg flow with FusionAuth. This lets you keep your existing html pretty much untouched, you're just calling out to FusionAuth instead of the database.</li>
<li>remove them and use the FusionAuth provided pages with OIDC. This lets you use the theming and localization capabilities of FusionAuth, including super simple social signon.</li>
<p dir="auto">It's your choice based on what your needs are, either way will work.</p>
<p dir="auto">I'd only recommend using SAML if you have an application which only supports SAML, not OIDC.</p>
<p dir="auto">You'll also want to make sure that when someone registers with one of your applications in FusionAuth, they register with all three. I'd probably use a webhook to ensure that.</p>
]]></description><link>https://fusionauth.io/community/forum/post/866</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/866</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Mon, 17 Aug 2020 19:22:00 GMT</pubDate></item><item><title><![CDATA[Reply to How many applications and tenants can I have in FusionAuth? on Mon, 17 Aug 2020 05:58:21 GMT]]></title><description><![CDATA[<p dir="auto">My case is Thant I have 3 different application that i want to bring under 1 umbrella , out of 3 one is developed via MEAN stack and other 2 are PHP applications. Currently all 3 of them uses its own user login and registration system. I wish to have single sign on (like google uses for all apps) so user with one sign in can have access to all 3.</p>
<p dir="auto">So my question is<br />
1- can it be done with FusionAuth ?<br />
2. if yes, in that case  what about the existing login/reg flow already exist in 3 applications, do i have to get rid of them completely and than add fusionauth or let them sit as it is and fusionauth will provide another layer top of it?</p>
<p dir="auto">And what will be best way connecting these applications using OIDC or SAML (i am not sure whats diffrence)?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://fusionauth.io/community/forum/post/860</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/860</guid><dc:creator><![CDATA[ashutosh]]></dc:creator><pubDate>Mon, 17 Aug 2020 05:58:21 GMT</pubDate></item><item><title><![CDATA[Reply to How many applications and tenants can I have in FusionAuth? on Fri, 14 Aug 2020 14:21:54 GMT]]></title><description><![CDATA[<p dir="auto">I'm not quite sure I follow.</p>
<p dir="auto">Do you mean using FusionAuth as the identity provider and connecting these applications using OIDC or SAML?</p>
]]></description><link>https://fusionauth.io/community/forum/post/854</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/854</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Fri, 14 Aug 2020 14:21:54 GMT</pubDate></item><item><title><![CDATA[Reply to How many applications and tenants can I have in FusionAuth? on Fri, 14 Aug 2020 06:48:58 GMT]]></title><description><![CDATA[<p dir="auto">And What if all applications are pre-developed and you can still integrate with Fusionauth SSO? without disturbing their own sign-in processes?</p>
]]></description><link>https://fusionauth.io/community/forum/post/853</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/853</guid><dc:creator><![CDATA[ashutosh]]></dc:creator><pubDate>Fri, 14 Aug 2020 06:48:58 GMT</pubDate></item><item><title><![CDATA[Reply to How many applications and tenants can I have in FusionAuth? on Wed, 12 Aug 2020 15:32:29 GMT]]></title><description><![CDATA[<p dir="auto">There are no hard limits in FusionAuth. If you use the community edition, you can have unlimited applications and tenants for free.</p>
<p dir="auto">We've <a href="https://fusionauth.io/blog/2019/02/26/got-users-100-million" rel="nofollow ugc">tested 100M users</a>, but haven't pushed the boundaries of tenants or applications.</p>
<p dir="auto">However, we have clients in production with 5,000+ tenants and 5,000+ applications.</p>
]]></description><link>https://fusionauth.io/community/forum/post/837</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/837</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Wed, 12 Aug 2020 15:32:29 GMT</pubDate></item></channel></rss>
