<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Understanding Authenticator App Compatibility with FusionAuth&#x27;s TOTP Feature]]></title><description><![CDATA[<p dir="auto">Our user base has diverse preferences and needs, and we want to understand the range of authenticator apps compatible with FusionAuth's TOTP implementation.</p>
<p dir="auto">Could you provide a comprehensive list of all authenticator apps that FusionAuth's TOTP feature supports? Specifically, apart from Google Authenticator, does FusionAuth work with apps like Authy, Microsoft Authenticator, and LastPass Authenticator?</p>
<p dir="auto">This information is essential for our customer support team to address user inquiries and provide clear guidance on 2FA options available with our service.</p>
]]></description><link>https://fusionauth.io/community/forum/topic/2963/understanding-authenticator-app-compatibility-with-fusionauth-s-totp-feature</link><generator>RSS for Node</generator><lastBuildDate>Tue, 11 Aug 2026 12:00:29 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/2963.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 29 Jun 2025 15:45:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Understanding Authenticator App Compatibility with FusionAuth&#x27;s TOTP Feature on Sun, 29 Jun 2025 15:46:02 GMT]]></title><description><![CDATA[<p dir="auto">FusionAuth's TOTP implementation is compatible with most popular authenticator apps that follow the industry-standard TOTP algorithm, specifically those using <strong>HMACSHA1</strong>. While we cannot provide an exhaustive list, here are some commonly used authenticator apps that are known to work with FusionAuth:</p>
<li><strong>Google Authenticator</strong></li>
<li><strong>Authy</strong></li>
<li><strong>Microsoft Authenticator</strong></li>
<li><strong>LastPass Authenticator</strong></li>
<li><strong>1Password</strong></li>
<p dir="auto"><strong>Compatibility Check</strong>:</p>
<p dir="auto">If an authenticator app does not support FusionAuth’s TOTP, it will simply fail to recognize the QR code when scanned.</p>
<p dir="auto"><strong>Documentation Reference</strong>:</p>
<p dir="auto">For more details about FusionAuth's TOTP implementation and requirements, refer to the <a href="https://fusionauth.io/docs/apis/two-factor#totp-implementation" rel="nofollow ugc">FusionAuth TOTP Documentation</a>.</p>
<p dir="auto">Most users should have no issues using any modern TOTP-based authenticator app.</p>
]]></description><link>https://fusionauth.io/community/forum/post/8131</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8131</guid><dc:creator><![CDATA[wesley]]></dc:creator><pubDate>Sun, 29 Jun 2025 15:46:02 GMT</pubDate></item></channel></rss>
