<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to Create a JWT Populate Lambda in FusionAuth]]></title><description><![CDATA[<p dir="auto">Our FusionAuth instance only lists 11 Lambdas by default, and <strong>JWT Populate</strong> is not one of them. How can we create a <strong>JWT Populate</strong> Lambda?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/2973/how-to-create-a-jwt-populate-lambda-in-fusionauth</link><generator>RSS for Node</generator><lastBuildDate>Tue, 11 Aug 2026 11:11:04 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/2973.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 29 Jun 2025 16:05:51 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to Create a JWT Populate Lambda in FusionAuth on Sun, 29 Jun 2025 16:06:18 GMT]]></title><description><![CDATA[<p dir="auto">The 11 Lambdas you see are the default ones included with FusionAuth. To create a <strong>JWT Populate</strong> Lambda, follow these steps:</p>
<li>Navigate to <strong>Settings &gt; Lambda</strong> in the FusionAuth Admin UI.</li>
<li>Click the green <strong>+</strong> button in the top right to create a new Lambda.</li>
<li>In the "Type" dropdown, select <strong>JWT Populate</strong>.</li>
<li>Configure your Lambda logic as needed.</li>
<p dir="auto">For additional guidance, you can refer to the <a href="https://fusionauth.io/docs/extend/code/lambdas/jwt-populate" rel="nofollow ugc">JWT Populate Lambda documentation</a>, which includes a helpful video walkthrough of the process.</p>
]]></description><link>https://fusionauth.io/community/forum/post/8151</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8151</guid><dc:creator><![CDATA[wesley]]></dc:creator><pubDate>Sun, 29 Jun 2025 16:06:18 GMT</pubDate></item></channel></rss>
