<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to Disable Facebook Login and Signup Buttons in FusionAuth UI]]></title><description><![CDATA[<p dir="auto">Is there a way to <strong>disable the Facebook login and signup button</strong> in the FusionAuth user interface using the FusionAuth dashboard?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/2984/how-to-disable-facebook-login-and-signup-buttons-in-fusionauth-ui</link><generator>RSS for Node</generator><lastBuildDate>Wed, 11 Mar 2026 03:22:47 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/2984.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 30 Jun 2025 03:38:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to Disable Facebook Login and Signup Buttons in FusionAuth UI on Mon, 30 Jun 2025 03:39:33 GMT]]></title><description><![CDATA[<p dir="auto">Yes, you can disable the Facebook login and signup button through the FusionAuth dashboard. Navigate to <strong>Settings &gt; Identity Providers</strong>, then <strong>edit the Facebook Identity Provider</strong>. At the top of the configuration page, you’ll find an <strong>“Enabled” toggle</strong> that lets you disable Facebook login globally for all applications. Alternatively, you can disable Facebook login for specific applications by using the <strong>application-level toggles</strong> at the bottom of the same page.</p>
]]></description><link>https://fusionauth.io/community/forum/post/8173</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8173</guid><dc:creator><![CDATA[wesley]]></dc:creator><pubDate>Mon, 30 Jun 2025 03:39:33 GMT</pubDate></item></channel></rss>
