<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Managing Rate Limits and CAPTCHA During FusionAuth Cloud Integration]]></title><description><![CDATA[<p dir="auto">We’re integrating FusionAuth into our system but are running into <strong>rate limiting and CAPTCHA challenges</strong> that are blocking our progress during login testing. Is there a way to <strong>temporarily increase rate limits</strong> to avoid these issues during integration, or is <strong>self-hosting</strong> FusionAuth the only alternative?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/2990/managing-rate-limits-and-captcha-during-fusionauth-cloud-integration</link><generator>RSS for Node</generator><lastBuildDate>Sun, 14 Jun 2026 19:49:41 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/2990.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 30 Jun 2025 04:00:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Managing Rate Limits and CAPTCHA During FusionAuth Cloud Integration on Mon, 30 Jun 2025 04:01:22 GMT]]></title><description><![CDATA[<p dir="auto">These challenges are expected because of the <strong>security protections</strong> in place on FusionAuth Cloud deployments. One option is indeed to <strong>self-host FusionAuth</strong>, which gives you full control over rate limits and CAPTCHA settings.</p>
<p dir="auto">Alternatively, you could <strong>add your IP address to FusionAuth’s allowlist</strong>, which can exempt you from certain rate limits and CAPTCHA checks. Details on this approach and the requirements are documented here:<br />
<a href="https://fusionauth.io/docs/get-started/run-in-the-cloud/cloud#captcha-and-rate-limits" rel="nofollow ugc">CAPTCHA and Rate Limits - FusionAuth Cloud</a></p>
]]></description><link>https://fusionauth.io/community/forum/post/8185</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8185</guid><dc:creator><![CDATA[wesley]]></dc:creator><pubDate>Mon, 30 Jun 2025 04:01:22 GMT</pubDate></item></channel></rss>
