<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Transferring Configuration from Development to Production in FusionAuth Cloud]]></title><description><![CDATA[<p dir="auto">We’ve set up a new Cloud instance for production and would like to know whether we can transfer our existing development configuration into it. Is this transfer covered under our support plan?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/2998/transferring-configuration-from-development-to-production-in-fusionauth-cloud</link><generator>RSS for Node</generator><lastBuildDate>Wed, 11 Nov 2026 12:52:15 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/2998.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 30 Jun 2025 04:30:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Transferring Configuration from Development to Production in FusionAuth Cloud on Mon, 30 Jun 2025 04:30:28 GMT]]></title><description><![CDATA[<p dir="auto">Data transfers between FusionAuth deployments aren’t typically included as a standard service, except in cases where a business is scaling up to a larger deployment. However, since this is a new production setup, we can accommodate a one-time migration for you. The process would result in about 10 minutes of downtime.</p>
<p dir="auto">Make sure you have a master API key on hand, as certain settings—like SMTP configurations—might need to be updated manually after the transfer. Alternatively, you’re welcome to migrate the configuration manually if you prefer.</p>
]]></description><link>https://fusionauth.io/community/forum/post/8201</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8201</guid><dc:creator><![CDATA[wesley]]></dc:creator><pubDate>Mon, 30 Jun 2025 04:30:28 GMT</pubDate></item></channel></rss>
