<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Best Practices for Securing Partner APIs with FusionAuth]]></title><description><![CDATA[<p dir="auto">We use FusionAuth for user authentication on our website and plan to expose certain API endpoints to external partners. Our idea is to have partners authenticate via FusionAuth and then use the access token (JWT) to call our secured APIs.</p>
<p dir="auto">Is this the recommended way to secure partner APIs with FusionAuth? Should we separate partner users into a different tenant or application for better isolation? And if partners need server-to-server access, is the client credentials grant the right approach?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/3008/best-practices-for-securing-partner-apis-with-fusionauth</link><generator>RSS for Node</generator><lastBuildDate>Wed, 12 Aug 2026 05:36:04 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/3008.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 30 Jun 2025 05:02:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Best Practices for Securing Partner APIs with FusionAuth on Mon, 30 Jun 2025 05:04:52 GMT]]></title><description><![CDATA[<p dir="auto">Yes—using FusionAuth access tokens to secure partner-facing APIs is a solid approach. The key is ensuring the tokens contain the right claims to enforce proper authorization for your endpoints.</p>
<p dir="auto">Separating partners into a different tenant or application can improve security and simplify management. Different tenants fully isolate users and tokens, but would require duplicating application configs. Alternatively, you could keep partners in the same tenant and distinguish them via roles, claims, or separate applications.</p>
<p dir="auto">If partners are accessing APIs server-to-server, the client credentials grant (Entities in FusionAuth) is the correct choice. Be sure to carefully scope each partner’s access to avoid over-permissioning.</p>
<p dir="auto">More on these topics:</p>
<li><a href="https://fusionauth.io/docs/extend/examples/api-gateways/api-authorization" rel="nofollow ugc">API Authorization with FusionAuth</a></li>
<li><a href="https://fusionauth.io/docs/get-started/core-concepts/tenants" rel="nofollow ugc">Tenants Overview</a></li>
<li><a href="https://fusionauth.io/articles/tokens/jwt-components-explained" rel="nofollow ugc">JWT Anatomy</a></li>
<li><a href="https://fusionauth.io/articles/identity-basics/authorization-models" rel="nofollow ugc">Authorization Models</a></li>
]]></description><link>https://fusionauth.io/community/forum/post/8221</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8221</guid><dc:creator><![CDATA[wesley]]></dc:creator><pubDate>Mon, 30 Jun 2025 05:04:52 GMT</pubDate></item></channel></rss>
