<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Assigning an API key to a tenant after it has been created?]]></title><description><![CDATA[<p dir="auto">How do i assign a tenant to an api key after it’s been created?</p>
<p dir="auto">I just created one and it’s currently assigned to All Tenants.</p>
]]></description><link>https://fusionauth.io/community/forum/topic/301/assigning-an-api-key-to-a-tenant-after-it-has-been-created</link><generator>RSS for Node</generator><lastBuildDate>Thu, 08 Oct 2026 13:19:01 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/301.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 14 Aug 2020 03:04:19 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Assigning an API key to a tenant after it has been created? on Fri, 14 Aug 2020 03:04:44 GMT]]></title><description><![CDATA[<p dir="auto">You can’t. You have to create another API key.</p>
<p dir="auto">If you want to keep the same value, you could copy the value, delete it, and then recreate with the same value and set the tenant you want.</p>
]]></description><link>https://fusionauth.io/community/forum/post/852</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/852</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Fri, 14 Aug 2020 03:04:44 GMT</pubDate></item></channel></rss>
