<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to Authenticate a Local React App with FusionAuth Hosted on Azure Without Cross-Origin Cookie Issues]]></title><description><![CDATA[<p dir="auto">We are working on creating a React application on our local machine (localhost) and need to authenticate users through our FusionAuth instance, which is hosted in an Azure App Service. We have faced cross-origin and cookie-related problems when the app operates on localhost while FusionAuth is located on a different domain (specifically, our Azure App Service endpoint). The FusionAuth documentation indicates that these problems are anticipated because of browser security limitations concerning cross-site cookies. It also suggests that a good way to address this is to run the application and FusionAuth on localhost during development. However, in our case, FusionAuth needs to be hosted on Azure App Service so running it locally is not a feasible option.</p>
]]></description><link>https://fusionauth.io/community/forum/topic/3032/how-to-authenticate-a-local-react-app-with-fusionauth-hosted-on-azure-without-cross-origin-cookie-issues</link><generator>RSS for Node</generator><lastBuildDate>Tue, 09 Jun 2026 08:41:34 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/3032.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 09 Aug 2025 02:09:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to Authenticate a Local React App with FusionAuth Hosted on Azure Without Cross-Origin Cookie Issues on Sat, 09 Aug 2025 02:10:49 GMT]]></title><description><![CDATA[<p dir="auto">If you are using the React SDK (which uses Hosted Backend: <a href="https://fusionauth.io/docs/apis/hosted-backend" rel="nofollow ugc">https://fusionauth.io/docs/apis/hosted-backend</a>, then there are a couple options but they will all require some integration work from your end. The SDKs and Hosted Backend are designed to be easy to use and implement but they are not flexible as you can see with the cookies. Also I'm not sure if this was a consideration in the decision that running FusionAuth locally is not an option but just in case it was: You can use your FusionAuth non-production licenses wherever you want, we do not charge more "per deployment". So you can activate your non-prod license on a locally hosted FusionAuth instance in addition to your FusionAuth on Azure App Service, you can run your non-prod license on as many instances as you want.</p>
<p dir="auto">Develop your application while hosting it on Azure App service so FusionAuth and the app are on the same domain</p>
<p dir="auto">Setup a proxy for either your application or FusionAuth so they can be on the same domain</p>
<li>Documentation for setting up a proxy for FusionAuth: <a href="https://fusionauth.io/docs/operate/deploy/proxy-setup" rel="nofollow ugc">https://fusionauth.io/docs/operate/deploy/proxy-setup</a></li>
<ol start="3">
<p dir="auto">Create your own Hosted Backend, example here: <a href="https://github.com/FusionAuth/fusionauth-javascript-sdk-express/tree/main" rel="nofollow ugc">https://github.com/FusionAuth/fusionauth-javascript-sdk-express/tree/main</a></p>
<p dir="auto">Similar to #3, instead of setting up a Hosted Backend use the OAuth2 endpoints directly. In this scenario you will also be responsible for doing the OAuth code exchange for a token then setting the token cookies on the browser as well as session management with these tokens.</p>
<p dir="auto"><a href="https://fusionauth.io/docs/lifecycle/authenticate-users/oauth/endpoints" rel="nofollow ugc">https://fusionauth.io/docs/lifecycle/authenticate-users/oauth/endpoints</a></p>
<p dir="auto"><a href="https://fusionauth.io/docs/operate/secure/token-storage" rel="nofollow ugc">https://fusionauth.io/docs/operate/secure/token-storage</a></p>
]]></description><link>https://fusionauth.io/community/forum/post/8298</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8298</guid><dc:creator><![CDATA[wesley]]></dc:creator><pubDate>Sat, 09 Aug 2025 02:10:49 GMT</pubDate></item></channel></rss>
