<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to Handle CAPTCHA and Rate Limits for Automated Testing in FusionAuth]]></title><description><![CDATA[<p dir="auto">We are developing our automatic frontend tests for our application that integrates FusionAuth. Currently, we are encountering a captcha that is preventing our tests from running on developers' computers. Based on FusionAuth documentation, we can obtain a whitelist for our static IP; however, some developers work remotely, and we plan to integrate tests into our CI/CD pipeline in the future.</p>
<p dir="auto">We are searching for a solution; at the moment, the whitelist for static IPs is the only available option. Are there alternative solutions? Our instance is on the older infrastructure, we could update it and set a custom domain but in the current setup it will be a subdomain which would not enable the use of the same cookies because it will not be the same origin.</p>
]]></description><link>https://fusionauth.io/community/forum/topic/3035/how-to-handle-captcha-and-rate-limits-for-automated-testing-in-fusionauth</link><generator>RSS for Node</generator><lastBuildDate>Mon, 12 Oct 2026 08:44:57 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/3035.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 09 Aug 2025 03:36:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to Handle CAPTCHA and Rate Limits for Automated Testing in FusionAuth on Sat, 09 Aug 2025 03:36:32 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the question.  Updating your instance wouldn't change your situation. Currently, the only options are what you found outlined in the documentation you mentioned.</p>
<li><a href="https://fusionauth.io/docs/get-started/run-in-the-cloud/cloud#captcha-and-rate-limits" rel="nofollow ugc">https://fusionauth.io/docs/get-started/run-in-the-cloud/cloud#captcha-and-rate-limits</a></li>
<p dir="auto">As we build out our Cloud Offerings there may be other options, but this is what is currently available.  Oftentimes, we find that people will use a local copy of FusionAuth to complete their automated testing if they cannot locate an IP address that meets our allowlisting requirements.</p>
]]></description><link>https://fusionauth.io/community/forum/post/8304</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8304</guid><dc:creator><![CDATA[wesley]]></dc:creator><pubDate>Sat, 09 Aug 2025 03:36:32 GMT</pubDate></item><item><title><![CDATA[Reply to How to Handle CAPTCHA and Rate Limits for Automated Testing in FusionAuth on Fri, 15 Aug 2025 09:14:10 GMT]]></title><description><![CDATA[<p dir="auto">You’ll need to disable or mock CAPTCHA in a test environment and adjust rate-limit settings in FusionAuth’s config or use test API keys to avoid hitting production limits during automated runs.</p>
]]></description><link>https://fusionauth.io/community/forum/post/8328</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8328</guid><dc:creator><![CDATA[james61972]]></dc:creator><pubDate>Fri, 15 Aug 2025 09:14:10 GMT</pubDate></item><item><title><![CDATA[Reply to How to Handle CAPTCHA and Rate Limits for Automated Testing in FusionAuth on Sat, 09 Aug 2025 03:36:32 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the question.  Updating your instance wouldn't change your situation. Currently, the only options are what you found outlined in the documentation you mentioned.</p>
]]></description><link>https://fusionauth.io/community/forum/post/8304</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8304</guid><dc:creator><![CDATA[wesley]]></dc:creator><pubDate>Sat, 09 Aug 2025 03:36:32 GMT</pubDate></item></channel></rss>
