<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to Change Fonts in the FusionAuth Hosted Login Page]]></title><description><![CDATA[<p dir="auto">We would like to change the fonts on our TOH user interface from the old set (Montserrat/playfair) to something different (Mulish). Is this something that you do on your side or is it something we can do?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/3037/how-to-change-fonts-in-the-fusionauth-hosted-login-page</link><generator>RSS for Node</generator><lastBuildDate>Tue, 09 Jun 2026 08:51:45 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/3037.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 09 Aug 2025 03:40:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to Change Fonts in the FusionAuth Hosted Login Page on Sat, 09 Aug 2025 03:41:02 GMT]]></title><description><![CDATA[<p dir="auto">If you want to change the font on  the hosted login page and the login experience users are offered through FusionAuth, then this can be changed via our Themes. Very likely you will want to update the CSS associated with the theme you are using for the FusionAuth Application/Tenant.  Changes to the theme can be completed through this API: <a href="https://fusionauth.io/docs/apis/themes/advanced-themes" rel="nofollow ugc">https://fusionauth.io/docs/apis/themes/advanced-themes</a>.</p>
<p dir="auto">Alternatively, you can use the Admin UI to make changes to your CSS as well.</p>
]]></description><link>https://fusionauth.io/community/forum/post/8308</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8308</guid><dc:creator><![CDATA[wesley]]></dc:creator><pubDate>Sat, 09 Aug 2025 03:41:02 GMT</pubDate></item></channel></rss>
