<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Identity Provider with no email?]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I have been recently introduced to FusionAuth and I need to create a sign in option through another platform(<a href="http://strava.com" rel="nofollow ugc">strava.com</a>). For this job I have created an Identity Provider with OpenID Connect that works the client ID, client secret etc. FusionAuth can reach and can also fetch the data from the endpoints but the problem is that the developers have removed their Email as accessable data variable. Thus I get:</p>
<p dir="auto">"An email address was not provided for the user. This account cannot be used to login, unable to complete this login request."</p>
<p dir="auto">My question is such:<br />
Can I bypass the email requirement somehow or create a static fake email that I will use for every sign in (I assume lambdas will be required)?</p>
<p dir="auto">Thank you in advance for the support.</p>
]]></description><link>https://fusionauth.io/community/forum/topic/304/identity-provider-with-no-email</link><generator>RSS for Node</generator><lastBuildDate>Fri, 13 Nov 2026 02:33:06 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/304.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 17 Aug 2020 08:26:14 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Identity Provider with no email? on Tue, 10 Jan 2023 22:15:38 GMT]]></title><description><![CDATA[<p dir="auto">It looks like setting the email address in a lambda works for Facebook now (as of at least 1.41.2):</p>
<pre><code class="language-js">  if (!facebookUser.email) {
    user.email = facebookUser.id + '@no-email.facebook.com';
<pre><code class="language-text">1/10/2023 10:10:33 PM Z Linking strategy [LinkByEmail]
1/10/2023 10:10:33 PM Z Resolved email to []
1/10/2023 10:10:33 PM Z Resolved username to [null]
1/10/2023 10:10:33 PM Z Resolved unique Id to [115587478085870]
1/10/2023 10:10:33 PM Z Identity provider returned a unique Id [115587478085870].
1/10/2023 10:10:33 PM Z A link has not yet been established for this external user.
1/10/2023 10:10:33 PM Z The user with the email address [] does not exist.
1/10/2023 10:10:33 PM Z Invoke configured lambda with Id [787cd34e-1618-4cd9-8156-936734cfe368]
1/10/2023 10:10:33 PM Z The lambda set or modified the initially resolved email. Email is now [115587478085870@no-email.facebook.com]
1/10/2023 10:10:33 PM Z Creating user:
1/10/2023 10:10:33 PM Z User is not registered for application with Id [e0da3f10-7efa-4a6b-95f8-fbf4894884b5]
1/10/2023 10:10:33 PM Z User has successfully been reconciled and logged into FusionAuth.
1/10/2023 10:10:33 PM Z Authentication type: FACEBOOK
1/10/2023 10:10:33 PM Z Authentication state: Authenticated
]]></description><link>https://fusionauth.io/community/forum/post/5807</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/5807</guid><dc:creator><![CDATA[trevorr]]></dc:creator><pubDate>Tue, 10 Jan 2023 22:15:38 GMT</pubDate></item><item><title><![CDATA[Reply to Identity Provider with no email? on Wed, 19 May 2021 13:44:36 GMT]]></title><description><![CDATA[<p dir="auto">In the next release we plan to add additional options for IdPs for account linking. In this up-coming release you should be able to do things such as:</p>
<li>Use an IdP that only uses usernames (at your own risk)</li>
<li>Modify or build an email address using a Lambda for any IdP (at your own risk)</li>
<li>Modify or build a username using a Lambda for any IdP (at your own risk)</li>
<li>Use an IdP that does not have a username or email address</li>
]]></description><link>https://fusionauth.io/community/forum/post/3043</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/3043</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Wed, 19 May 2021 13:44:36 GMT</pubDate></item><item><title><![CDATA[Reply to Identity Provider with no email? on Fri, 05 Feb 2021 02:30:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/516">@joseantonio</a> said in <a href="/community/forum/post/2313">Identity Provider with no email?</a>:</p>
<p dir="auto">I need to make an API call inside the SAML reconcile. Is this possible?</p>
<p dir="auto">Nope, this is currently not possible, unfortunately.</p>
<p dir="auto">Upgrading lambda functionality to <a href="https://github.com/FusionAuth/fusionauth-issues/issues/267" rel="nofollow ugc">support network requests is an open issue</a>. Please vote it up if it is important to you.</p>
<p dir="auto">If this is very important to you, you can engage our professional services.</p>
<p dir="auto">More on <a href="https://fusionauth.io/docs/v1/tech/core-concepts/roadmap/" rel="nofollow ugc">the FusionAuth roadmap</a>.</p>
]]></description><link>https://fusionauth.io/community/forum/post/2332</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2332</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Fri, 05 Feb 2021 02:30:09 GMT</pubDate></item><item><title><![CDATA[Reply to Identity Provider with no email? on Tue, 02 Feb 2021 11:48:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/20">@dan</a>  Thank you for the help. Indeed it is not possible to assign a generated email in SAML reconcile lambdas. However, I found a solution for my problem.</p>
<p dir="auto">Using <strong>SAML reconcile lambda</strong>, I create a new metadata field for the registration called "<em>generated_email</em>". Then, I assign it to the JWT response for the specific application using a <strong>JWT populate lambda</strong>. Example:<br />
<em>Edit: adding code for SAML reconcile lambda as well.</em></p>
<p dir="auto">SAML reconcile:</p>
<pre><code>function reconcile(user, registration, samlResponse) {
var userid=samlResponse.assertion.subject.nameID.id;
//registration.email = userid + '@subdomain.mydomain.com'; This can't be done yet
registration.data.generated_email=userid + '@subdomain.mydomain.com';
<p dir="auto">JWT populate:</p>
<pre><code>function populate(jwt, user, registration) {
if(registration.data&amp;&amp;registration.data.generated_email){
    var new_email= registration.data.generated_email;
    jwt.email= new_email;
  }else{
    console.debug('No generated email set');
<p dir="auto">(after checking that it exists for the registration).</p>
<p dir="auto"><strong>New problem</strong>: I need to make an API call inside the SAML reconcile. Is this possible?</p>
]]></description><link>https://fusionauth.io/community/forum/post/2313</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2313</guid><dc:creator><![CDATA[joseantonio]]></dc:creator><pubDate>Tue, 02 Feb 2021 11:48:28 GMT</pubDate></item><item><title><![CDATA[Reply to Identity Provider with no email? on Tue, 05 Jan 2021 16:46:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/516">@joseantonio</a></p>
<p dir="auto">I was incorrect. I've learned that you should be able to do this with a SAML Lambda. Here's the documentation for the SAML lambda you should customize: <a href="https://fusionauth.io/docs/v1/tech/lambdas/samlv2-response-populate/" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/lambdas/samlv2-response-populate/</a> Sorry about that.</p>
<p dir="auto">Please let us know how this goes.</p>
]]></description><link>https://fusionauth.io/community/forum/post/2107</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2107</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Tue, 05 Jan 2021 16:46:31 GMT</pubDate></item><item><title><![CDATA[Reply to Identity Provider with no email? on Tue, 05 Jan 2021 04:07:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/516">@joseantonio</a>  Nope, only for OIDC. Feel free to <a href="https://github.com/fusionauth/fusionauth-issues/issues" rel="nofollow ugc">file an issue explaining your use case</a> or <a href="https://account.fusionauth.io/account/support/" rel="nofollow ugc">open a support ticket if you have a support plan</a>.</p>
]]></description><link>https://fusionauth.io/community/forum/post/2100</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2100</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Tue, 05 Jan 2021 04:07:54 GMT</pubDate></item><item><title><![CDATA[Reply to Identity Provider with no email? on Mon, 04 Jan 2021 08:59:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/3">@robotdan</a> Is the workaround for no email Identity Providers available in SAML as well?</p>
]]></description><link>https://fusionauth.io/community/forum/post/2089</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2089</guid><dc:creator><![CDATA[joseantonio]]></dc:creator><pubDate>Mon, 04 Jan 2021 08:59:23 GMT</pubDate></item><item><title><![CDATA[Reply to Identity Provider with no email? on Wed, 02 Dec 2020 11:40:34 GMT]]></title><description><![CDATA[<p dir="auto"><em><strong>Important</strong></em><br />
<em>Apple only returns the user object the first time the user authorizes the app. Persist this information from your app; subsequent authorization requests won’t contain the user object.</em><br />
(<a href="https://developer.apple.com/documentation/sign_in_with_apple/sign_in_with_apple_js/configuring_your_webpage_for_sign_in_with_apple" rel="nofollow ugc">https://developer.apple.com/documentation/sign_in_with_apple/sign_in_with_apple_js/configuring_your_webpage_for_sign_in_with_apple</a>)</p>
<p dir="auto">So you should go to Settings-&gt;ID Apple -&gt;Password&amp;Security and remove the app from apps that use your Apple ID</p>
<p dir="auto">Now you can register again and apple will send the userInfo.</p>
]]></description><link>https://fusionauth.io/community/forum/post/1837</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1837</guid><dc:creator><![CDATA[mattiapicariello]]></dc:creator><pubDate>Wed, 02 Dec 2020 11:40:34 GMT</pubDate></item><item><title><![CDATA[Reply to Identity Provider with no email? on Thu, 05 Nov 2020 00:35:16 GMT]]></title><description><![CDATA[<p dir="auto">What is the lambda seeing? Can you have the entire JSON object printed to the log and share that?</p>
]]></description><link>https://fusionauth.io/community/forum/post/1612</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1612</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Thu, 05 Nov 2020 00:35:16 GMT</pubDate></item><item><title><![CDATA[Reply to Identity Provider with no email? on Tue, 03 Nov 2020 14:37:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/3">@robotdan</a> said in <a href="/community/forum/post/1532">Identity Provider with no email?</a>:</p>
<p dir="auto">Each of these IdPs can be assigned a Reconcile Lambda, a default lambda is provided with FusionAuth that you can use and modify.</p>
<p dir="auto">I'm using the default lambda. And it does NOT return "name/fullname" as I mentioned earlier. Google and Twitter do return "name/fullname".</p>
<p dir="auto">Here's how Apple Identity provider is set up:</p>
<p dir="auto"><img src="/community/forum/assets/uploads/files/1604414235986-download.png" alt="download.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://fusionauth.io/community/forum/post/1592</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1592</guid><dc:creator><![CDATA[bogorad]]></dc:creator><pubDate>Tue, 03 Nov 2020 14:37:25 GMT</pubDate></item><item><title><![CDATA[Reply to Identity Provider with no email? on Tue, 27 Oct 2020 15:26:09 GMT]]></title><description><![CDATA[<p dir="auto">Can we just skip the login part and just return the <code>userInfo</code> ?</p>
]]></description><link>https://fusionauth.io/community/forum/post/1541</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1541</guid><dc:creator><![CDATA[fusionauth_user]]></dc:creator><pubDate>Tue, 27 Oct 2020 15:26:09 GMT</pubDate></item><item><title><![CDATA[Reply to Identity Provider with no email? on Tue, 27 Oct 2020 01:33:25 GMT]]></title><description><![CDATA[<p dir="auto">The results of the <code>Userinfo</code> endpoint will reflect what is in the JWT and what additional details FusionAuth knows about the user.</p>
<p dir="auto">So with Twitter, Facebook, Google and Apple, this will all depend upon what is returned from those providers, and then subsequently what you do with that information during login.</p>
<p dir="auto"><a href="https://fusionauth.io/docs/v1/tech/lambdas/apple-reconcile/" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/lambdas/apple-reconcile/</a><br />
<a href="https://fusionauth.io/docs/v1/tech/lambdas/facebook-reconcile/" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/lambdas/facebook-reconcile/</a><br />
<a href="https://fusionauth.io/docs/v1/tech/lambdas/google-reconcile/" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/lambdas/google-reconcile/</a><br />
<a href="https://fusionauth.io/docs/v1/tech/lambdas/twitter-reconcile/" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/lambdas/twitter-reconcile/</a></p>
<p dir="auto">In your example, are you using an Apple Reconcile Lambda, and if so, can you post your lambda function?</p>
<p dir="auto">Apple will only return the user's first and last name on the very first authentication event. Subsequent events will not contain this information, so if you were to log a user in using the Apple provider, and then subsequently assign a reconcile Lambda that would otherwise attempt to capture this information, you will not have that User's first and last name in FusionAuth.</p>
<p dir="auto">Similarly with Twitter, we would need to see your reconcile Lambda function body that you have assigned to this IdP configuration to understand what is being obtained from Twitter and stored in FusionAuth.</p>
<p dir="auto">Hope that helps!</p>
]]></description><link>https://fusionauth.io/community/forum/post/1532</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1532</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Tue, 27 Oct 2020 01:33:25 GMT</pubDate></item><item><title><![CDATA[Reply to Identity Provider with no email? on Mon, 26 Oct 2020 21:37:00 GMT]]></title><description><![CDATA[<p dir="auto">I played with it more and found this:</p>
<p dir="auto">Login with Apple sometimes works, sometimes doesn't. It looks like users with emails that are not known to my FusionAuth are fine. But existing emails are not.</p>
<p dir="auto">When a new user is successfully registered via Google or Twitter (didn't try other providers) all there fields are returned by /oauth2/userinfo: 'given_name', 'family_name', and 'name'. And consequently the FusionAuth database has all three: 'firstName', 'lastName', and 'fullName'.</p>
<p dir="auto">However, when a new user is onboarded via the Apple plugin, the user is missing 'name' as returned by /oauth2/userinfo, and 'FullName' is also missing from the database.</p>
]]></description><link>https://fusionauth.io/community/forum/post/1529</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1529</guid><dc:creator><![CDATA[bogorad]]></dc:creator><pubDate>Mon, 26 Oct 2020 21:37:00 GMT</pubDate></item><item><title><![CDATA[Reply to Identity Provider with no email? on Wed, 30 Sep 2020 21:46:48 GMT]]></title><description><![CDATA[<p dir="auto">Hiya,</p>
<p dir="auto">Hmmm. That's not super helpful, eh? The ibatis errors shouldn't be related (see <a href="https://github.com/FusionAuth/fusionauth-issues/issues/721" rel="nofollow ugc">https://github.com/FusionAuth/fusionauth-issues/issues/721</a> for more about that particular warning).</p>
<p dir="auto">Just to check, the screenshot you shared had <code>debug</code> disabled, but you definitely enabled it?</p>
<p dir="auto">Are you seeing anything in the event log (in the admin UI) that might shed more light on the situation?</p>
<p dir="auto">Does the email address you are using to try to login with have any special characteristics?</p>
]]></description><link>https://fusionauth.io/community/forum/post/1327</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1327</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Wed, 30 Sep 2020 21:46:48 GMT</pubDate></item><item><title><![CDATA[Reply to Identity Provider with no email? on Tue, 29 Sep 2020 23:55:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/20">@dan</a> here's the message:</p>
<p dir="auto"><code>An email address was not provided for the user. This account cannot be used to log in, unable to complete this login request.</code></p>
<p dir="auto"><code>debug</code> is enabled, but I have no idea where to look for logs - under docker the log that is seen in e.g. Portanier is only showing some older warnings:</p>
<p dir="auto"><code>WARNING: Please consider reporting this to the maintainers of org.apache.ibatis.reflection.Reflector WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations WARNING: All illegal access operations will be denied in a future release</code></p>
<p dir="auto">Another interesting thing: of two of my friends who tried it, one was able to log in, and Apple even asked him if he wanted to hide his real email address. The other one got the same message that I'm getting.</p>
]]></description><link>https://fusionauth.io/community/forum/post/1318</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1318</guid><dc:creator><![CDATA[bogorad]]></dc:creator><pubDate>Tue, 29 Sep 2020 23:55:35 GMT</pubDate></item><item><title><![CDATA[Reply to Identity Provider with no email? on Tue, 29 Sep 2020 23:07:47 GMT]]></title><description><![CDATA[<p dir="auto">Hiya,</p>
<p dir="auto">Can you please check the <code>debug</code> setting (below 'reconcile lambda') and run through the login sequence again? It'd be great to see if that provides more details.</p>
]]></description><link>https://fusionauth.io/community/forum/post/1310</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1310</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Tue, 29 Sep 2020 23:07:47 GMT</pubDate></item><item><title><![CDATA[Reply to Identity Provider with no email? on Sat, 26 Sep 2020 18:33:56 GMT]]></title><description><![CDATA[<p dir="auto">Checked again. Here's the screenshot:</p>
<p dir="auto"><img src="/community/forum/assets/uploads/files/1601145095659-fua-a.png" alt="fua-a.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Apple authentication is done, back to FusionAuth, and still</p>
<p dir="auto"><code>An email address was not provided for the user. This account cannot be used to login, unable to complete this login request.</code></p>
<p dir="auto">I can't really debug inside Docker - the Portainer-&gt;log only shows an irrelevant error that happened ages ago:</p>
<p dir="auto">`<br />
26-Sep-2020 13:55:07.670 INFO [http-nio-9011-exec-2] org.apache.tomcat.util.http.Parameters.processParameters Invalid chunk starting at byte [172] and ending at byte [173] with a value of [=] ignored</p>
<p dir="auto">Note: further occurrences of Parameter errors will be logged at DEBUG level.</p>
<p dir="auto">WARNING: An illegal reflective access operation has occurred</p>
<p dir="auto">WARNING: Illegal reflective access by org.apache.ibatis.reflection.Reflector (file:/usr/local/fusionauth/fusionauth-app/web/WEB-INF/lib/mybatis-3.4.6.jar) to field java.util.UUID.serialVersionUID</p>
<p dir="auto">WARNING: Please consider reporting this to the maintainers of org.apache.ibatis.reflection.Reflector</p>
<p dir="auto">WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations</p>
<p dir="auto">WARNING: All illegal access operations will be denied in a future release`</p>
]]></description><link>https://fusionauth.io/community/forum/post/1293</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1293</guid><dc:creator><![CDATA[bogorad]]></dc:creator><pubDate>Sat, 26 Sep 2020 18:33:56 GMT</pubDate></item><item><title><![CDATA[Reply to Identity Provider with no email? on Fri, 25 Sep 2020 22:40:13 GMT]]></title><description><![CDATA[<p dir="auto">I am using <code>name email</code> as it shows in the documentation and I can log in. You can enable <code>debug</code> on the Apple Identity Provider which may provide you some additional details if it is not working.</p>
]]></description><link>https://fusionauth.io/community/forum/post/1289</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1289</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Fri, 25 Sep 2020 22:40:13 GMT</pubDate></item><item><title><![CDATA[Reply to Identity Provider with no email? on Fri, 25 Sep 2020 20:38:39 GMT]]></title><description><![CDATA[<p dir="auto">Is 'login with Apple' working right now? I get the above mentioned error with different accounts. I followed the instruction <a href="https://fusionauth.io/docs/v1/tech/identity-providers/apple#overview" rel="nofollow ugc">here</a> - maybe it's a bit out of date?</p>
<p dir="auto">I don't get asked by Apple whether I want to give my real or fake email, so FusionAuth must not be asking for it?</p>
<p dir="auto">Apple dev doc says:</p>
<p dir="auto">To request user information in the <code>id_token</code> (assuming you are requesting via the <code>/auth/authorize</code> REST API), you’ll need to include the <code>scope</code> query parameter, which supports the values—<code>name</code> and <code>email</code>. You can request one, both, or none.<br />
Note: Use space separation and percent-encoding for multiple scopes; for example, <code>“scope=name%20email”</code>.</p>
<p dir="auto">...</p>
<p dir="auto">If you request the user’s verified email address, Sign in with Apple prompts the user for it, to share with your app. The user may choose to share their real email address or an anonymous one that uses the private email relay service. In both cases, Apple verifies that the email address works and is ready for use.</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://fusionauth.io/community/forum/post/1286</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1286</guid><dc:creator><![CDATA[bogorad]]></dc:creator><pubDate>Fri, 25 Sep 2020 20:38:39 GMT</pubDate></item><item><title><![CDATA[Reply to Identity Provider with no email? on Fri, 28 Aug 2020 20:06:14 GMT]]></title><description><![CDATA[<p dir="auto">Perhaps arbitrary. It is sort of a hack to allow some specific OIDC IdPs to work.</p>
<p dir="auto">In the case of Facebook, the reason for an email address being omitted from the response is easier to discern in FusionAuth. When you configure a Facebook IdP, you are inherently asking FusionAuth to defer authentication to Facebook.</p>
<p dir="auto">The Facebook user can optionally decide to not share their email with FusionAuth. I am assuming this is the case since you are not getting an email back from Facebook.</p>
<p dir="auto">In this scenario, we fail the login because the user has chosen not to share their email address.</p>
<p dir="auto">So this is the reason why we don't allow the user to login.</p>
<p dir="auto">The longer term solution to this is coming - where FusionAuth will take a unique Id from Google, Facebook, Twitter etc - and record their unique Id instead of just relying upon the email address. This will allow us to recognize the user uniquely apart from their email address. This will likely also allow FusionAuth to reconcile the user and possibly make the email address optional when creating the user.</p>
]]></description><link>https://fusionauth.io/community/forum/post/1022</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1022</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Fri, 28 Aug 2020 20:06:14 GMT</pubDate></item><item><title><![CDATA[Reply to Identity Provider with no email? on Fri, 28 Aug 2020 18:37:24 GMT]]></title><description><![CDATA[<p dir="auto">From my (layman's) standpoint, that feels a bit arbitrary <img src="https://fusionauth.io/community/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f914.png?v=rcgg4tg866g" class="not-responsive emoji emoji-android emoji--thinking_face" style="height:23px;width:auto;vertical-align:middle" title=":thinking_face:" alt="🤔" /><br />
Is a Facebook login different from OIDC? Is there a good reason as to why FusionAuth is preventing these users from being able to login?</p>
]]></description><link>https://fusionauth.io/community/forum/post/1020</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1020</guid><dc:creator><![CDATA[twosevenxyz]]></dc:creator><pubDate>Fri, 28 Aug 2020 18:37:24 GMT</pubDate></item><item><title><![CDATA[Reply to Identity Provider with no email? on Fri, 28 Aug 2020 18:03:46 GMT]]></title><description><![CDATA[<p dir="auto">The work around described above only works for OpenID Connect based IdPs, it will not work for Facebook. If the Facebook user is not providing you their email, they will not be able to login.</p>
]]></description><link>https://fusionauth.io/community/forum/post/1019</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1019</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Fri, 28 Aug 2020 18:03:46 GMT</pubDate></item><item><title><![CDATA[Reply to Identity Provider with no email? on Fri, 28 Aug 2020 17:57:58 GMT]]></title><description><![CDATA[<p dir="auto">I added the following lambda, but I'm quite confident that the lambda function never runs.</p>
<pre><code>// Using the response from Facebook Me API, reconcile the User and User Registration.
function reconcile(user, registration, facebookUser) {
  user.firstName = facebookUser.first_name;
  user.middleName = facebookUser.middle_name;
  user.lastName = facebookUser.last_name;
  user.fullName = facebookUser.name;
  if (facebookUser.picture &amp;&amp; !facebookUser.picture.data.is_silhouette) {
    user.imageUrl = facebookUser.picture.data.url;
  if (facebookUser.birthday) {
    // Convert MM/dd/yyyy -&gt; YYYY-MM-DD
    var parts = facebookUser.birthday.split('/');
    user.birthDate = parts[2] + '-' +  parts[0] + '-' +  parts[1];
    user.email = facebookUser.sub + '@no-email.twoseven.xyz';
    console.info('Added missing email: \n' + JSON.stringify(facebookUser));
<p dir="auto">Whenever I perform a login with a Facebook account that has no email registered, I see the following in the event log:</p>
<pre><code>...
8/28/2020 05:05:45 AM EDT Call the [https://graph.facebook.com/oauth/access_token] endpoint.
8/28/2020 05:05:45 AM EDT Endpoint returned status code [200]
8/28/2020 05:05:45 AM EDT The identity provider was unable to reconcile the email address. An email address is required to complete this request.
]]></description><link>https://fusionauth.io/community/forum/post/1018</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/1018</guid><dc:creator><![CDATA[twosevenxyz]]></dc:creator><pubDate>Fri, 28 Aug 2020 17:57:58 GMT</pubDate></item></channel></rss>
