<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Custom Registration Fields Missing for Social Logins – Why You Should Listen for registration.update Events]]></title><description><![CDATA[<p dir="auto">My registration form includes custom fields. The values are correctly sent to our backend with the user-create-complete event. Unfortunately, this does not apply to users who register with social login. At this point, the event is dispatched without the supplementary custom content, as it occurs immediately after the social login and before the user is prompted to provide additional registration details. Consequently, I anticipated a user.update.complete event to occur shortly after the 'empty' user.create.complete event, but it did not happen. Please provide guidance on how to troubleshoot this issue.</p>
]]></description><link>https://fusionauth.io/community/forum/topic/3040/custom-registration-fields-missing-for-social-logins-why-you-should-listen-for-registration-update-events</link><generator>RSS for Node</generator><lastBuildDate>Thu, 10 Sep 2026 16:26:26 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/3040.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 09 Aug 2025 03:48:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Custom Registration Fields Missing for Social Logins – Why You Should Listen for registration.update Events on Sat, 09 Aug 2025 03:49:31 GMT]]></title><description><![CDATA[<p dir="auto">If you believe that you have discovered a bug or issue with FusionAuth, please log an issue below.</p>
<li><a href="https://github.com/FusionAuth/fusionauth-issues/issues/new/choose" rel="nofollow ugc">https://github.com/FusionAuth/fusionauth-issues/issues/new/choose</a></li>
<p dir="auto">To note, you will likely want to be listening to the registration.update webhook for changes to the registration object prompted by additional fields the user needs to have completed based on what is a required field for self service registration.</p>
<p dir="auto">In the case of a user entering all these fields "manually" (as part of a registration form) we will create the user and the registration at the same time (thus transmitting all information, including all required registration fields, as part of the user.create and registration.create events).</p>
<p dir="auto">However, in the case of a social login, the user and registration will be created after the IdP provider returns information via the user.create and registration.create events. Additional registration will be asked of the user as part of the complete registration process (if there are additional required fields) and that additional information will be transmitted as part of the registration.update event.</p>
<li><a href="https://fusionauth.io/docs/extend/events-and-webhooks/events/user-registration-update" rel="nofollow ugc">https://fusionauth.io/docs/extend/events-and-webhooks/events/user-registration-update</a></li>
]]></description><link>https://fusionauth.io/community/forum/post/8314</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8314</guid><dc:creator><![CDATA[wesley]]></dc:creator><pubDate>Sat, 09 Aug 2025 03:49:31 GMT</pubDate></item></channel></rss>
