<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Using Separate Applications in a Single Tenant for AD&#x2F;Entra ID and Client Authentication]]></title><description><![CDATA[<p dir="auto">We’d like to configure FusionAuth so that our Admin portal authenticates against Active Directory/Microsoft Entra ID, while our client-facing site uses FusionAuth for authentication. Does this setup make sense, and should we use separate tenants for this, or can both flows be managed within a single tenant?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/3056/using-separate-applications-in-a-single-tenant-for-ad-entra-id-and-client-authentication</link><generator>RSS for Node</generator><lastBuildDate>Tue, 18 Aug 2026 14:12:53 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/3056.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 10 Sep 2025 01:11:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Using Separate Applications in a Single Tenant for AD&#x2F;Entra ID and Client Authentication on Wed, 10 Sep 2025 01:12:52 GMT]]></title><description><![CDATA[<p dir="auto">You can manage both flows within a single tenant. Typically, you’d configure separate applications, one for the Admin portal tied to your AD/Entra ID provider, and another for your client-facing site using FusionAuth. You can then use login hints or managed domains to direct users to the correct Identity Provider (IdP).</p>
<p dir="auto"><a href="https://fusionauth.io/docs/lifecycle/authenticate-users/identity-providers/#hints" rel="nofollow ugc">Identity Provider Hints</a><br />
<a href="https://fusionauth.io/docs/lifecycle/authenticate-users/identity-providers/overview-oidc#managed-domains" rel="nofollow ugc">Managed Domains</a></p>
]]></description><link>https://fusionauth.io/community/forum/post/8368</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8368</guid><dc:creator><![CDATA[wesley]]></dc:creator><pubDate>Wed, 10 Sep 2025 01:12:52 GMT</pubDate></item></channel></rss>
