<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to Monitor FusionAuth Cloud with Datadog (via Prometheus) and Track 2FA Drop-Off]]></title><description><![CDATA[<p dir="auto">We are investigating what additional telemetry and data we can monitor and log to our monitoring systems. I found the self-hosted version supports integration with Datadog here: <a href="https://fusionauth.io/docs/operate/monitor/datadog" rel="nofollow ugc">https://fusionauth.io/docs/operate/monitor/datadog</a></p>
<p dir="auto">However, I am unclear what we can monitor on the cloud version since we are not managing the container or deployment side.</p>
<p dir="auto">Can we integrate the cloud-hosted version into Datadog to monitor for performance issues or other issues that might impact end users? If so, are there any guides?</p>
<p dir="auto">Can we monitor failed 2FA rates using a tool like this? Or are there recommended approaches for monitoring drop-off during 2FA enrollment and other login issues?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/3059/how-to-monitor-fusionauth-cloud-with-datadog-via-prometheus-and-track-2fa-drop-off</link><generator>RSS for Node</generator><lastBuildDate>Tue, 11 Aug 2026 11:58:35 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/3059.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 18 Sep 2025 13:13:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to Monitor FusionAuth Cloud with Datadog (via Prometheus) and Track 2FA Drop-Off on Thu, 18 Sep 2025 13:14:53 GMT]]></title><description><![CDATA[<p dir="auto">You cannot integrate Datadog directly into the cloud-hosted version of FusionAuth. The only relevant section in the documentation is "Use Datadog Agent on a Remote Host." This requires setting up Datadog to monitor FusionAuth using the Prometheus Metrics API endpoint. For monitoring failed 2FA rates, FusionAuth does not currently have built-in support. There is no webhook for failed MFA, but you can use the failed login webhook to monitor incorrect password attempts.</p>
<p dir="auto"><a href="https://fusionauth.io/docs/apis/system#retrieve-system-metrics-using-prometheus" rel="nofollow ugc">Retrieve system metrics using Prometheus</a><br />
<a href="https://fusionauth.io/docs/operate/monitor/datadog#use-the-datadog-agent-on-a-remote-host" rel="nofollow ugc">Use the Datadog Agent on a remote host</a><br />
<a href="https://fusionauth.io/docs/extend/events-and-webhooks/events/user-login-failed" rel="nofollow ugc">User login failed webhook</a></p>
]]></description><link>https://fusionauth.io/community/forum/post/8377</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8377</guid><dc:creator><![CDATA[wesley]]></dc:creator><pubDate>Thu, 18 Sep 2025 13:14:53 GMT</pubDate></item></channel></rss>
