<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Currently using MojoAuth — thinking about switching to FusionAuth, looking for advice]]></title><description><![CDATA[<p dir="auto">Hey everyone</p>
<p dir="auto">I’ve been using MojoAuth<br />
for a while to handle passwordless authentication (mostly magic links and OTPs) in one of my projects. It’s been great for quick integration and a smooth user login experience — especially since it’s fully hosted and has a free tier for smaller apps.</p>
<p dir="auto">That said, I’m starting to hit a few limits as the project grows, and I’m considering whether FusionAuth might be a better long-term fit.</p>
<p dir="auto">Here are some of the things pushing me to explore FusionAuth:</p>
<p dir="auto">Limited customization: MojoAuth is very developer-friendly but doesn’t go deep into complex user management or advanced CIAM features.</p>
<p dir="auto">No self-hosting option: Everything’s cloud-based, so I don’t get full control over data or infrastructure.</p>
<p dir="auto">Federation / enterprise logins: MojoAuth handles OIDC basics well, but not broad SAML or directory sync scenarios.</p>
<p dir="auto">Scalability and lifecycle control: I might soon need more control over user provisioning, policies, and compliance (which FusionAuth seems to handle really well).</p>
<p dir="auto">I like that FusionAuth supports both self-hosting and cloud, and includes OAuth2, OIDC, SAML, and advanced federation — but it also looks more complex to set up.</p>
<p dir="auto">For anyone who’s used both:</p>
<p dir="auto">How steep was the learning curve moving from something simple like MojoAuth to FusionAuth?</p>
<p dir="auto">Is FusionAuth worth it for small-to-mid SaaS projects, or is it better suited for larger enterprise use cases?</p>
<p dir="auto">Any “gotchas” to be aware of before migrating?</p>
<p dir="auto">Would love to hear from folks who’ve gone down this road or manage similar transitions. <img src="https://fusionauth.io/community/forum/assets/plugins/nodebb-plugin-emoji/emoji/android/1f64f.png?v=rcgg4tg866g" class="not-responsive emoji emoji-android emoji--pray" style="height:23px;width:auto;vertical-align:middle" title=":pray:" alt="🙏" /></p>
]]></description><link>https://fusionauth.io/community/forum/topic/3072/currently-using-mojoauth-thinking-about-switching-to-fusionauth-looking-for-advice</link><generator>RSS for Node</generator><lastBuildDate>Wed, 11 Nov 2026 12:33:06 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/3072.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 19 Nov 2025 06:06:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Currently using MojoAuth — thinking about switching to FusionAuth, looking for advice on Wed, 19 Nov 2025 19:28:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/3690">@vijaysingh1784</a> Looks like you have done a bit of research your self and made a pretty good analysis.  I am not very familiar with MojoAuth, but just to confirm a few things:</p>
<p dir="auto">FusionAuth is very customizable. You should check out things like Lambdas, Webhooks and other various options.</p>
<p dir="auto">FusionAuth can be self-hosted or can be hosted for you.</p>
<p dir="auto">FusionAuth handles <a href="https://fusionauth.io/docs/lifecycle/authenticate-users/saml" rel="nofollow ugc">SAML</a>, <a href="https://fusionauth.io/docs/lifecycle/migrate-users/scim/" rel="nofollow ugc">SCIM</a> and other various integrations.</p>
<p dir="auto">FusionAuth is very scalable and gives you great control with api acess and other mechanisms.</p>
<p dir="auto">Depending on your needs, FusionAuth can be as easy to self host as spinning up a docker image to a full blown complex K8s deployment. It should fit your needs there.</p>
<p dir="auto">While there is no direct migration guide for the product you are talking about, there are several other <a href="https://fusionauth.io/docs/lifecycle/migrate-users/" rel="nofollow ugc">migration guides</a> for you to look over that should give you an idea on how to do it.</p>
]]></description><link>https://fusionauth.io/community/forum/post/8422</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8422</guid><dc:creator><![CDATA[mark.robustelli]]></dc:creator><pubDate>Wed, 19 Nov 2025 19:28:13 GMT</pubDate></item></channel></rss>
