<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to Enforce Customer-Specific Session Lifetimes and Fast Deprovisioning for Federated Users in FusionAuth]]></title><description><![CDATA[<p dir="auto">We have a customer with strict session-lifetime requirements and I’m trying to understand the best way to implement them in FusionAuth.</p>
<p dir="auto">This customer authenticates through their <strong>own IdP</strong>, which we’ve configured as an Identity Provider in FusionAuth. In our tenant, we’ve configured:</p>
<li><strong>Access token (JWT) duration</strong>: 600 seconds</li>
<li><strong>Refresh token duration</strong>: 960 minutes</li>
<p dir="auto">These settings work well for users who log in directly through FusionAuth because they can stay signed in for a long time without re-authenticating.</p>
<p dir="auto">However, this customer requires that if a user is <strong>disabled</strong>, they must be denied access to our application within <strong>300 seconds or less</strong>.</p>
<p dir="auto">My understanding is that FusionAuth will continue to honor the user’s existing session (via refresh tokens) for up to the full refresh token lifetime, and the user won’t be forced back to the customer’s IdP until the refresh token expires.</p>
<li>Is that understanding correct?</li>
<li>If so, what options do we have to meet this customer’s requirement without forcing all users to re-authenticate every few minutes?</li>
<li>Can we limit refresh token lifetime for only this customer, possibly via a reconcile lambda or another mechanism?</li>
]]></description><link>https://fusionauth.io/community/forum/topic/3083/how-to-enforce-customer-specific-session-lifetimes-and-fast-deprovisioning-for-federated-users-in-fusionauth</link><generator>RSS for Node</generator><lastBuildDate>Sun, 14 Jun 2026 20:12:56 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/3083.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 20 Dec 2025 02:14:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to Enforce Customer-Specific Session Lifetimes and Fast Deprovisioning for Federated Users in FusionAuth on Sat, 20 Dec 2025 02:25:33 GMT]]></title><description><![CDATA[<p dir="auto">There are a couple of overlapping layers here.</p>
<p dir="auto"><strong>Access tokens aren’t revocable by default</strong><br />
Access tokens (JWTs) are self-contained. Once issued, they remain valid until they expire unless you implement a custom revocation strategy (such as token blacklisting). FusionAuth covers one approach here:<br />
<a href="https://fusionauth.io/articles/tokens/revoking-jwts" rel="nofollow ugc">https://fusionauth.io/articles/tokens/revoking-jwts</a><br />
So if your access token lifetime is 600 seconds, a disabled user could continue to access APIs until that token expires (up to ~10 minutes) unless you add an additional revocation layer.</p>
<p dir="auto"><strong>FusionAuth sessions are typically independent from the IdP</strong><br />
Once the upstream IdP authenticates the user, FusionAuth generally maintains its own session state. If a user is disabled in the upstream IdP, that does not automatically invalidate FusionAuth sessions or prevent refresh token usage.<br />
So yes, depending on your implementation, a user can potentially continue to operate in FusionAuth even if they are disabled upstream, until you either:</p>
<li>expire/stop honoring their tokens, or</li>
<li>remove/disable the user in FusionAuth, or</li>
<li>enforce additional checks at login/session refresh time.</li>
<p dir="auto"><strong>Options to meet “disabled within 300 seconds” for one customer</strong><br />
If you need disablement to take effect quickly without shortening sessions for everyone, you generally need an integration that pushes the disablement signal into FusionAuth (or into your resource servers).</p>
<p dir="auto"><strong>A. SCIM (best fit when the customer maps cleanly to a tenant)</strong><br />
If your customer can be logically isolated (e.g., “customer A users live in tenant A”), SCIM is a strong option. The customer’s IdP can provision/deprovision users into FusionAuth, and a disable/delete action can remove their FusionAuth access (including sessions). This is the cleanest approach when tenant segmentation is possible.</p>
<p dir="auto"><strong>B. Event-driven deprovisioning (IdP → your service → FusionAuth API)</strong><br />
If the customer’s IdP can emit events (user disabled/deprovisioned), you can build a lightweight integration that:</p>
<li>receives the IdP event, then</li>
<li>disables or deletes the corresponding user in FusionAuth via API.</li>
<p dir="auto">Once the user is disabled/deleted in FusionAuth, they won’t be able to continue normal authentication flows.</p>
<p dir="auto"><strong>C. Token revocation strategy (resource server enforcement)</strong><br />
If the requirement is “deny access within 300 seconds,” the most deterministic way is to enforce it at the API/resource-server layer by:</p>
<li>using short access-token lifetimes (&lt;= 300 seconds), and/or</li>
<li>adding token blacklisting / introspection-style checks in your APIs.</li>
<p dir="auto">This avoids relying on refresh token expiration to enforce disablement.</p>
<p dir="auto"><strong>About limiting refresh token lifetime per customer</strong></p>
<p dir="auto">A reconcile lambda can help with user provisioning and claims, but it won’t reliably solve the core issue of existing sessions and refresh tokens already issued. There isn’t a simple “per-customer refresh token TTL override” you can apply after the fact without an architectural approach like the ones above.</p>
]]></description><link>https://fusionauth.io/community/forum/post/8460</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8460</guid><dc:creator><![CDATA[wesley]]></dc:creator><pubDate>Sat, 20 Dec 2025 02:25:33 GMT</pubDate></item></channel></rss>
