<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Calling AWS API Gateway with SigV4 from FusionAuth Lambdas: Limitations and Recommended Architecture]]></title><description><![CDATA[<p dir="auto">We need a FusionAuth Lambda to call a private Amazon API Gateway endpoint. The API is protected using AWS SigV4 request signing (credentials + access tokens) and also restricts access via IP allowlisting.</p>
<p dir="auto">In our Lambda implementation, it looks like we don’t have access to standard crypto/request libraries (for example, AWS SDK signing helpers). We’re trying to replicate the following Ruby logic:</p>
<pre><code>RestClient.get("#{ENV['FKO_API_URL']}/#{cvr}/#{fka_id}", signature.headers)
def signer
  Aws::Sigv4::Signer.new(
    service: "execute-api",
    region: "eu-central-1",
    access_key_id: ENV["FKO_API_ACCESS_KEY_ID"],
    secret_access_key: ENV["FKO_API_SECRET_ACCESS_KEY"]
end
def signature
  signer.sign_request(
    http_method: "GET",
    url: "#{ENV['FKO_API_URL']}/#{cvr}/#{fka_id}",
    headers: { "Content-Type" =&gt; "application/json" }
end
<p dir="auto">Can FusionAuth Lambdas access crypto or request libraries (for example, AWS signing libraries) to generate SigV4 signatures?</p>
<p dir="auto">If not, is it possible to run FusionAuth Lambdas within the same private network as our API Gateway?</p>
<p dir="auto">If neither is possible, does that mean we must implement SigV4 signing ourselves (and embed credentials in the Lambda)? Any examples would help.</p>
<p dir="auto">Reference: <a href="https://fusionauth.io/docs/extend/code/lambdas/lambda-remote-api-calls" rel="nofollow ugc">https://fusionauth.io/docs/extend/code/lambdas/lambda-remote-api-calls</a></p>
]]></description><link>https://fusionauth.io/community/forum/topic/3085/calling-aws-api-gateway-with-sigv4-from-fusionauth-lambdas-limitations-and-recommended-architecture</link><generator>RSS for Node</generator><lastBuildDate>Sun, 14 Jun 2026 19:27:25 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/3085.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 01 Jan 2026 03:57:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Calling AWS API Gateway with SigV4 from FusionAuth Lambdas: Limitations and Recommended Architecture on Thu, 01 Jan 2026 03:58:42 GMT]]></title><description><![CDATA[<p dir="auto">You’re correct: FusionAuth’s Lambda environment does not provide access to external libraries (including AWS SDKs or SigV4 helpers), and there is no secure secrets store available to Lambdas. That means if you need AWS SigV4 signing from inside a Lambda, you would have to implement the signing logic yourself and embed any required credentials directly in the Lambda code—this is generally not considered secure.</p>
<p dir="auto">Also, if you are using FusionAuth Cloud, you cannot place Lambdas into your private network (for example, the same VPC/network as your API Gateway), so that option isn’t available in hosted deployments.</p>
<p dir="auto">If you need this capability, the recommended approach is typically to move the signing and secret handling into a system you control (for example, a backend service that FusionAuth calls), rather than performing SigV4 signing directly in a FusionAuth Lambda.</p>
<p dir="auto"><strong>Related issue tracking:</strong><br />
<a href="https://github.com/fusionauth/fusionauth-issues/issues/1629" rel="nofollow ugc">https://github.com/fusionauth/fusionauth-issues/issues/1629</a></p>
]]></description><link>https://fusionauth.io/community/forum/post/8464</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8464</guid><dc:creator><![CDATA[wesley]]></dc:creator><pubDate>Thu, 01 Jan 2026 03:58:42 GMT</pubDate></item></channel></rss>
