<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Troubleshooting Blank FusionAuth Login Pages in Android WebViews on Specific Devices]]></title><description><![CDATA[<p dir="auto">We received a report from a customer who is unable to log in to our mobile application. The app uses a standard embedded webview that loads the FusionAuth-hosted login page, a flow that has been in place and working reliably for all users until now.</p>
<p dir="auto">In this specific case, the webview appears to be completely blank and does not load the login page at all.</p>
<p dir="auto">Additional context:</p>
<p dir="auto">Device: Xiaomi Redmi Note 13<br />
OS: Android</p>
<p dir="auto">Clearing app data/cache did not resolve the issue</p>
<p dir="auto">Logging in as the same user works correctly on other devices</p>
<p dir="auto">Have you encountered a similar issue before, or do you have any guidance on what could cause this behavior?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/3086/troubleshooting-blank-fusionauth-login-pages-in-android-webviews-on-specific-devices</link><generator>RSS for Node</generator><lastBuildDate>Sun, 14 Jun 2026 19:45:59 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/3086.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 01 Jan 2026 04:06:32 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Troubleshooting Blank FusionAuth Login Pages in Android WebViews on Specific Devices on Thu, 01 Jan 2026 04:08:22 GMT]]></title><description><![CDATA[<p dir="auto">This is indeed unusual, especially since the issue appears to affect only a single user and device, which makes a FusionAuth configuration issue unlikely.</p>
<p dir="auto">A few things to check and try:</p>
<li>Open in External Browser</li>
<li>Ask the user to tap the three-dot menu (if available) in the webview and choose “Open in Chrome” or their default browser.</li>
<li>If the page loads correctly there, the issue is likely related to the embedded webview rather than FusionAuth itself.</li>
<p dir="auto"><strong>WebView / Browser-Specific Issues</strong></p>
<p dir="auto">Some Android devices (including certain Xiaomi models) ship with custom WebView implementations or aggressive privacy/security settings that can interfere with embedded web content.</p>
<p dir="auto">Ensure the device has the latest Android System WebView and browser updates installed.</p>
<p dir="auto"><strong>Domain / CNAME Edge Cases</strong></p>
<p dir="auto">There have been rare cases where mobile browsers or webviews behave unexpectedly if the domain includes characters such as underscores (_) or dashes (-) in certain positions.</p>
<p dir="auto">While this typically results in explicit errors (like “Address not found”), it’s still worth reviewing your domain and CNAME setup—especially since you’re self-hosting.</p>
<p dir="auto">Given that the login works for the same user on other devices, this is most likely a device- or WebView-specific issue rather than a problem with FusionAuth itself. If opening the login page in a full browser works, that should help narrow the root cause to the embedded webview implementation on that device.</p>
]]></description><link>https://fusionauth.io/community/forum/post/8466</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8466</guid><dc:creator><![CDATA[wesley]]></dc:creator><pubDate>Thu, 01 Jan 2026 04:08:22 GMT</pubDate></item></channel></rss>
