<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Admin UI actions over themes blocks application since 1.61.2]]></title><description><![CDATA[<p dir="auto">When accessing theme management from the admin UI, the application stops working.</p>
<p dir="auto">The call to /admin/theme/ does not respond for up to 2.6 minutes, displaying the following error:</p>
<p dir="auto"><img src="/community/forum/assets/uploads/files/1769102309931-b6ab046c-3e74-45ec-a8bb-6207498a9c9f-image.png" alt="b6ab046c-3e74-45ec-a8bb-6207498a9c9f-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">During this time, calls to /api/health on the instance stop responding.<br />
All calls to the application or API do not respond until the instance recovers.</p>
<p dir="auto">No errors appear in the application log.</p>
<p dir="auto">The same behaviour occurs when:</p>
<li>edit an existing tenant: /admin/tenant/edit/&lt;tenant_id&gt;</li>
<li>add a new tenant: /admin/tenant/add</li>
<li>edit an existing application: /admin/application/edit?applicationId=&lt;application_id&gt;</li>
<li>add a new application: /admin/application/add</li>
<p dir="auto">I assume that it affects these functionalities when all themes are obtained to be displayed in the Theme Field selector of these forms.</p>
<p dir="auto">Other admin UI actions work correctly (Users, Connectors, Lambdas, Identity Providers...)</p>
<p dir="auto">This has been happening since an upgrade to FusionAuth version 1.61.2, and also with the latest version 1.62.1.<br />
Reverting the application to a previous version (1.60.2), it works correctly and the error does not occur.</p>
<p dir="auto">I would like to mention that the number of existing themes is low (39), as is the number of tenants (96) and applications (218).</p>
<p dir="auto">The FusionAuth instance runs in a self-hosted infrastructure, with Docker image</p>
<p dir="auto">Version:  1.62.1<br />
Platform: Linux 5.14.0-427.57.1.el9_4.x86_64 amd64<br />
Database: PostgreSQL 17.4<br />
Search:   Database</p>
<p dir="auto">Enabling the debug level of logger io.fusionauth.api, the log messages during the /admin/theme call are:</p>
<pre><code>2026-01-21 11:51:25.901 AM DEBUG io.fusionauth.api.domain.TenantMapper.retrieveTenantByApplicationId - ==&gt;  Preparing: SELECT t.id AS t_id, t.access_token_signing_keys_id AS t_access_token_signing_keys_id, t.data AS t_data, t.client_credentials_access_token_populate_lambdas_id AS t_client_credentials_access_token_populate_lambdas_id, t.confirm_child_email_templates_id AS t_confirm_child_email_templates_id, t.email_update_email_templates_id AS t_email_update_email_templates_id, t.email_verified_email_templates_id AS t_email_verified_email_templates_id, t.failed_authentication_user_actions_id AS t_failed_authentication_user_actions_id, t.family_request_email_templates_id AS t_family_request_email_templates_id, t.forgot_password_email_templates_id AS t_forgot_password_email_templates_id, t.id_token_signing_keys_id AS t_id_token_signing_keys_id, t.insert_instant AS t_insert_instant, t.login_id_in_use_on_create_email_templates_id AS t_login_id_in_use_on_create_email_templates_id, t.login_id_in_use_on_update_email_templates_id AS t_login_id_in_use_on_update_email_templates_id, t.login_validation_lambdas_id AS t_login_validation_lambdas_id, t.last_update_instant AS t_last_update_instant, t.login_new_device_email_templates_id AS t_login_new_device_email_templates_id, t.login_suspicious_email_templates_id AS t_login_suspicious_email_templates_id, t.multi_factor_email_message_templates_id AS t_multi_factor_email_message_templates_id, t.multi_factor_requirement_lambdas_id AS t_multi_factor_requirement_lambdas_id, t.multi_factor_sms_message_templates_id AS t_multi_factor_sms_message_templates_id, t.multi_factor_sms_messengers_id AS t_multi_factor_sms_messengers_id, t.name AS t_name, t.parent_registration_email_templates_id AS t_parent_registration_email_templates_id, t.passwordless_email_templates_id AS t_passwordless_email_templates_id, t.password_reset_success_email_templates_id AS t_password_reset_success_email_templates_id, t.password_update_email_templates_id AS t_password_update_email_templates_id, t.phone_configuration_forgot_password_templates_id AS t_phone_configuration_forgot_password_templates_id, t.phone_configuration_identity_update_templates_id AS t_phone_configuration_identity_update_templates_id, t.phone_configuration_login_id_in_use_on_create_templates_id AS t_phone_configuration_login_id_in_use_on_create_templates_id, t.phone_configuration_login_id_in_use_on_update_templates_id AS t_phone_configuration_login_id_in_use_on_update_templates_id, t.phone_configuration_login_new_device_templates_id AS t_phone_configuration_login_new_device_templates_id, t.phone_configuration_login_suspicious_templates_id AS t_phone_configuration_login_suspicious_templates_id, t.phone_configuration_messengers_id AS t_phone_configuration_messengers_id, t.phone_configuration_password_reset_success_templates_id AS t_phone_configuration_password_reset_success_templates_id, t.phone_configuration_password_update_templates_id AS t_phone_configuration_password_update_templates_id, t.phone_configuration_passwordless_templates_id AS t_phone_configuration_passwordless_templates_id, t.phone_configuration_set_password_templates_id AS t_phone_configuration_set_password_templates_id, t.phone_configuration_two_factor_method_add_templates_id AS t_phone_configuration_two_factor_method_add_templates_id, t.phone_configuration_two_factor_method_remove_templates_id AS t_phone_configuration_two_factor_method_remove_templates_id, t.phone_configuration_verification_complete_templates_id AS t_phone_configuration_verification_complete_templates_id, t.phone_configuration_verification_templates_id AS t_phone_configuration_verification_templates_id, t.scim_enterprise_user_request_converter_lambdas_id AS t_scim_enterprise_user_request_converter_lambdas_id, t.scim_enterprise_user_response_converter_lambdas_id AS t_scim_enterprise_user_response_converter_lambdas_id, t.scim_group_request_converter_lambdas_id AS t_scim_group_request_converter_lambdas_id, t.scim_group_response_converter_lambdas_id AS t_scim_group_response_converter_lambdas_id, t.scim_user_request_converter_lambdas_id AS t_scim_user_request_converter_lambdas_id, t.scim_user_response_converter_lambdas_id AS t_scim_user_response_converter_lambdas_id, t.set_password_email_templates_id AS t_set_password_email_templates_id, t.scim_client_entity_types_id AS t_scim_client_entity_types_id, t.scim_server_entity_types_id AS t_scim_server_entity_types_id, t.themes_id AS t_themes_id, t.two_factor_method_add_email_templates_id AS t_two_factor_method_add_email_templates_id, t.two_factor_method_remove_email_templates_id AS t_two_factor_method_remove_email_templates_id, t.ui_ip_access_control_lists_id AS t_ui_ip_access_control_lists_id, t.verification_email_templates_id AS t_verification_email_templates_id, ct.connectors_id AS ct_connectors_id, ct.data AS ct_data, ct.sequence AS ct_sequence, t.admin_user_forms_id AS t_admin_user_forms_id FROM tenants AS t LEFT OUTER JOIN connectors_tenants AS ct ON t.id = ct.tenants_id WHERE id = (SELECT tenants_id FROM applications WHERE id = ?) ORDER BY ct.sequence ASC
2026-01-21 11:51:25.901 AM DEBUG io.fusionauth.api.domain.TenantMapper.retrieveTenantByApplicationId - ==&gt; Parameters: 3c219e58-ed0e-4b18-ad48-f4f92793ae32(UUID)
2026-01-21 11:51:25.904 AM DEBUG io.fusionauth.api.domain.TenantMapper.retrieveTenantByApplicationId - &lt;==      Total: 1
2026-01-21 11:51:25.907 AM DEBUG io.fusionauth.api.domain.TenantMapper.retrieveCount - ==&gt;  Preparing: SELECT count(id) FROM tenants
2026-01-21 11:51:25.907 AM DEBUG io.fusionauth.api.domain.TenantMapper.retrieveCount - ==&gt; Parameters:
2026-01-21 11:51:25.908 AM DEBUG io.fusionauth.api.domain.TenantMapper.retrieveCount - &lt;==      Total: 1
2026-01-21 11:51:25.910 AM DEBUG io.fusionauth.api.domain.UserMapper.retrieveById - ==&gt;  Preparing: SELECT u.id AS u_id, u.active AS u_active, COALESCE(u.breached_password_last_checked_instant, i.breached_password_last_checked_instant) AS u_breached_password_last_checked_instant, COALESCE(u.breached_password_status, i.breached_password_status) AS u_breached_password_status, u.birth_date AS u_birth_date, u.clean_speak_id AS u_clean_speak_id, i.id AS i_id, COALESCE(u.connectors_id, i.connectors_id) AS u_connectors_id, u.data AS u_data, i.email AS i_email, COALESCE(u.password_encryption_scheme, i.encryption_scheme) AS u_password_encryption_scheme, u.expiry AS u_expiry, COALESCE(u.password_factor, i.factor) AS u_password_factor, u.first_name AS u_first_name, u.full_name AS u_full_name, u.image_url AS u_image_url, i.insert_instant AS i_insert_instant, u.insert_instant AS u_insert_instant, i.last_login_instant AS i_last_login_instant, i.last_update_instant AS i_last_update_instant, u.last_login_instant AS u_last_login_instant, u.last_update_instant AS u_last_update_instant, u.last_name AS u_last_name, u.middle_name AS u_middle_name, u.mobile_phone AS u_mobile_phone, u.parent_email AS u_parent_email, COALESCE(u.password, i.password) AS u_password, COALESCE(u.password_change_reason, i.password_change_reason) AS u_password_change_reason, CASE WHEN u.password IS NULL THEN i.password_change_required ELSE u.password_change_required END AS u_password_change_required, COALESCE(u.password_last_update_instant, i.password_last_update_instant) AS u_password_last_update_instant, COALESCE(u.password_salt, i.salt) AS u_password_salt, i.is_primary AS i_is_primary, i.tenants_id AS i_tenants_id, i.status AS i_status, u.tenants_id AS u_tenants_id, u.timezone AS u_timezone, i.type AS i_type, REPLACE(i.username_index, UPPER(i.username), i.username) AS i_unique_username, i.username AS i_username, i.username_status AS i_username_status, i.users_id AS i_users_id, CASE WHEN i.type = 1 THEN i.display_value END AS i_display_value, CASE WHEN i.type = 1 THEN REPLACE(i.value, UPPER(i.display_value), i.display_value) ELSE i.value END AS i_value, i.verified AS i_verified, i.verified_instant AS i_verified_instant, u.verified_instant AS u_verified_instant, i.verified_reason AS i_verified_reason FROM users AS u LEFT OUTER JOIN identities AS i ON u.id = i.users_id WHERE u.id = ?
2026-01-21 11:51:25.910 AM DEBUG io.fusionauth.api.domain.UserMapper.retrieveById - ==&gt; Parameters: xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx(UUID)
2026-01-21 11:51:25.912 AM DEBUG io.fusionauth.api.domain.UserMapper.retrieveById - &lt;==      Total: 1
2026-01-21 11:51:25.913 AM DEBUG io.fusionauth.api.domain.GroupMapper.retrieveMembersByUserIds - ==&gt;  Preparing: SELECT gm.id AS gm_id, gm.groups_id AS gm_groups_id, gm.data AS gm_data, gm.users_id AS gm_users_id, gm.insert_instant AS gm_insert_instant, g.tenants_id AS g_tenants_id FROM group_members AS gm JOIN groups AS g ON gm.groups_id = g.id WHERE gm.users_id IN ( ? )
2026-01-21 11:51:25.913 AM DEBUG io.fusionauth.api.domain.GroupMapper.retrieveMembersByUserIds - ==&gt; Parameters: xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx(UUID)
2026-01-21 11:51:25.934 AM DEBUG io.fusionauth.api.domain.GroupMapper.retrieveMembersByUserIds - &lt;==      Total: 1
2026-01-21 11:51:25.935 AM DEBUG io.fusionauth.api.domain.UserMapper.retrieveRegistrationsByUserIds - ==&gt;  Preparing: SELECT ur.id AS ur_id, ur.applications_id AS ur_applications_id, ur.authentication_token AS ur_authentication_token, ur.clean_speak_id AS ur_clean_speak_id, ur.data AS ur_data, ur.insert_instant AS ur_insert_instant, ur.last_login_instant AS ur_last_login_instant, ur.last_update_instant AS ur_last_update_instant, ur.timezone AS ur_timezone, ur.username AS ur_username, ur.username_status AS ur_username_status, ur.users_id AS ur_users_id, ur.verified AS ur_verified, ur.verified_instant AS ur_verified_instant, ar1.name AS group_ar_name, ar2.name AS registration_ar_name, a.tenants_id AS a_tenants_id FROM user_registrations AS ur INNER JOIN applications AS a ON a.id = ur.applications_id LEFT OUTER JOIN user_registrations_application_roles AS urar ON urar.user_registrations_id = ur.id LEFT OUTER JOIN group_members AS gm ON ur.users_id = gm.users_id LEFT OUTER JOIN group_application_roles AS gar ON gar.groups_id = gm.groups_id LEFT OUTER JOIN application_roles AS ar1 ON ar1.id = urar.application_roles_id AND ar1.applications_id = ur.applications_id LEFT OUTER JOIN application_roles AS ar2 ON ar2.id = gar.application_roles_id AND ar2.applications_id = ur.applications_id WHERE ur.users_id IN ( ? )
2026-01-21 11:51:25.936 AM DEBUG io.fusionauth.api.domain.UserMapper.retrieveRegistrationsByUserIds - ==&gt; Parameters: xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx(UUID)
2026-01-21 11:51:25.937 AM DEBUG io.fusionauth.api.domain.UserMapper.retrieveRegistrationsByUserIds - &lt;==      Total: 1
2026-01-21 11:51:25.938 AM DEBUG io.fusionauth.api.domain.ExternalIdentifierMapper.retrieveByUserIdAndTypes - ==&gt;  Preparing: SELECT id, applications_id, data, expiration_instant, insert_instant, tenants_id, type, users_id FROM external_identifiers WHERE users_id = ? AND type IN ( ? , ? )
2026-01-21 11:51:25.939 AM DEBUG io.fusionauth.api.domain.ExternalIdentifierMapper.retrieveByUserIdAndTypes - ==&gt; Parameters: xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx(UUID), 1(Integer), 25(Integer)
2026-01-21 11:51:25.939 AM DEBUG io.fusionauth.api.domain.ExternalIdentifierMapper.retrieveByUserIdAndTypes - &lt;==      Total: 0
2026-01-21 11:51:25.954 AM DEBUG io.fusionauth.api.domain.ThemeMapper.retrieveCountByCriteria - ==&gt;  Preparing: SELECT COUNT(*) FROM themes
2026-01-21 11:51:25.954 AM DEBUG io.fusionauth.api.domain.ThemeMapper.retrieveCountByCriteria - ==&gt; Parameters:
2026-01-21 11:51:25.956 AM DEBUG io.fusionauth.api.domain.ThemeMapper.retrieveCountByCriteria - &lt;==      Total: 1
2026-01-21 11:51:25.959 AM DEBUG io.fusionauth.api.domain.ThemeMapper.retrieveByCriteria - ==&gt;  Preparing: SELECT * FROM themes ORDER BY insert_instant ASC LIMIT ? OFFSET ?
2026-01-21 11:51:25.959 AM DEBUG io.fusionauth.api.domain.ThemeMapper.retrieveByCriteria - ==&gt; Parameters: 25(Integer), 0(Integer)
2026-01-21 11:51:26.001 AM DEBUG io.fusionauth.api.domain.ThemeMapper.retrieveByCriteria - &lt;==      Total: 25
]]></description><link>https://fusionauth.io/community/forum/topic/3092/admin-ui-actions-over-themes-blocks-application-since-1-61-2</link><generator>RSS for Node</generator><lastBuildDate>Wed, 11 Nov 2026 12:25:28 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/3092.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 22 Jan 2026 17:23:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Admin UI actions over themes blocks application since 1.61.2 on Mon, 16 Mar 2026 13:06:13 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2507">@mark-robustelli</a></p>
<p dir="auto">I’ve been investigating the issue over the last few weeks.</p>
<p dir="auto">Having taken a JVM dump while the issue was occurring, here is the stack trace for the thread causing the deadlock</p>
<pre><code> {
   "tid": "8820",
   "name": "HTTP client [\/[0:0:0:0:0:0:0:1]:50154]",
   "stack": [
      "java.base\/jdk.internal.misc.Unsafe.park(Native Method)",
      "java.base\/java.lang.VirtualThread.parkOnCarrierThread(VirtualThread.java:677)",
      "java.base\/java.lang.VirtualThread.parkNanos(VirtualThread.java:648)",
      "java.base\/java.lang.System$2.parkVirtualThread(System.java:2652)",
      "java.base\/jdk.internal.misc.VirtualThreads.park(VirtualThreads.java:67)",
      "java.base\/java.util.concurrent.locks.LockSupport.parkNanos(LockSupport.java:408)",
      "java.base\/sun.nio.ch.Poller.pollIndirect(Poller.java:137)",
      "java.base\/sun.nio.ch.Poller.poll(Poller.java:102)",
      "java.base\/sun.nio.ch.Poller.poll(Poller.java:87)",
      "java.base\/sun.nio.ch.NioSocketImpl.park(NioSocketImpl.java:175)",
      "java.base\/sun.nio.ch.NioSocketImpl.timedRead(NioSocketImpl.java:280)",
      "java.base\/sun.nio.ch.NioSocketImpl.implRead(NioSocketImpl.java:304)",
      "java.base\/sun.nio.ch.NioSocketImpl.read(NioSocketImpl.java:346)",
      "java.base\/sun.nio.ch.NioSocketImpl$1.read(NioSocketImpl.java:796)",
      "java.base\/java.net.Socket$SocketInputStream.read(Socket.java:1099)",
      "java.base\/java.io.BufferedInputStream.fill(BufferedInputStream.java:291)",
      "java.base\/java.io.BufferedInputStream.read1(BufferedInputStream.java:347)",
      "java.base\/java.io.BufferedInputStream.implRead(BufferedInputStream.java:420)",
      "java.base\/java.io.BufferedInputStream.read(BufferedInputStream.java:399)",
      "java.base\/sun.net.www.http.ChunkedInputStream.fastRead(ChunkedInputStream.java:244)",
      "java.base\/sun.net.www.http.ChunkedInputStream.read(ChunkedInputStream.java:698)",
      "java.base\/java.io.FilterInputStream.read(FilterInputStream.java:119)",
      "java.base\/sun.net.www.protocol.http.HttpURLConnection$HttpInputStream.read(HttpURLConnection.java:3677)",
      "java.base\/java.io.BufferedInputStream.read1(BufferedInputStream.java:345)",
      "java.base\/java.io.BufferedInputStream.read(BufferedInputStream.java:405)",
      "com.inversoft.rest.JSONResponseHandler$BetterBufferedInputStream.read(JSONResponseHandler.java:127)",
      "com.fasterxml.jackson.core.json.UTF8StreamJsonParser._loadMore(UTF8StreamJsonParser.java:220)",
      "com.fasterxml.jackson.core.json.UTF8StreamJsonParser._loadMoreGuaranteed(UTF8StreamJsonParser.java:2457)",
      "com.fasterxml.jackson.core.json.UTF8StreamJsonParser._finishString2(UTF8StreamJsonParser.java:2540)",
      "com.fasterxml.jackson.core.json.UTF8StreamJsonParser._finishAndReturnString(UTF8StreamJsonParser.java:2520)",
      "com.fasterxml.jackson.core.json.UTF8StreamJsonParser.getText(UTF8StreamJsonParser.java:294)",
      "com.fasterxml.jackson.databind.deser.std.StringDeserializer.deserialize(StringDeserializer.java:42)",
      "com.fasterxml.jackson.databind.deser.std.StringDeserializer.deserialize(StringDeserializer.java:11)",
      "com.fasterxml.jackson.databind.deser.impl.FieldProperty.deserializeAndSet(FieldProperty.java:137)",
      "com.fasterxml.jackson.databind.deser.BeanDeserializer.vanillaDeserialize(BeanDeserializer.java:302)",
      "com.fasterxml.jackson.databind.deser.BeanDeserializer.deserialize(BeanDeserializer.java:169)",
      "com.fasterxml.jackson.databind.deser.std.CollectionDeserializer._deserializeNoNullChecks(CollectionDeserializer.java:501)",
      "com.fasterxml.jackson.databind.deser.std.CollectionDeserializer._deserializeFromArray(CollectionDeserializer.java:358)",
      "com.fasterxml.jackson.databind.deser.std.CollectionDeserializer.deserialize(CollectionDeserializer.java:245)",
      "com.fasterxml.jackson.databind.deser.std.CollectionDeserializer.deserialize(CollectionDeserializer.java:29)",
      "com.fasterxml.jackson.databind.deser.DefaultDeserializationContext.readRootValue(DefaultDeserializationContext.java:342)",
      "com.fasterxml.jackson.databind.ObjectMapper._readMapAndClose(ObjectMapper.java:4971)",
      "com.fasterxml.jackson.databind.ObjectMapper.readValue(ObjectMapper.java:3924)",
      "com.inversoft.rest.JSONResponseHandler.apply(JSONResponseHandler.java:68)",
      "com.inversoft.rest.RESTClient.go(RESTClient.java:430)",
      "io.fusionauth.client.FusionAuthClient.searchThemes(FusionAuthClient.java:5372)",
      "io.fusionauth.app.action.admin.theme.IndexAction.lambda$search$0(IndexAction.java:52)",
      "io.fusionauth.client.LambdaDelegate.execute(LambdaDelegate.java:58)",
      "io.fusionauth.app.action.admin.theme.IndexAction.search(IndexAction.java:52)",
      "io.fusionauth.app.action.admin.BaseSearchAction.execute(BaseSearchAction.java:77)",
      "java.base\/jdk.internal.reflect.DirectMethodHandleAccessor.invoke(DirectMethodHandleAccessor.java:103)",
      "java.base\/java.lang.reflect.Method.invoke(Method.java:580)",
      "org.primeframework.mvc.util.ReflectionUtils.invoke(ReflectionUtils.java:443)",
      "org.primeframework.mvc.action.DefaultActionInvocationWorkflow.execute(DefaultActionInvocationWorkflow.java:77)",
      "org.primeframework.mvc.action.DefaultActionInvocationWorkflow.perform(DefaultActionInvocationWorkflow.java:60)",
      "org.primeframework.mvc.workflow.SubWorkflowChain.continueWorkflow(SubWorkflowChain.java:50)",
      "org.primeframework.mvc.message.DefaultMessageWorkflow.perform(DefaultMessageWorkflow.java:50)",
      "org.primeframework.mvc.validation.DefaultValidationWorkflow.perform(DefaultValidationWorkflow.java:45)",
      "org.primeframework.mvc.security.DefaultSecurityWorkflow.perform(DefaultSecurityWorkflow.java:79)",
      "org.primeframework.mvc.parameter.DefaultPostParameterWorkflow.perform(DefaultPostParameterWorkflow.java:49)",
      "org.primeframework.mvc.content.DefaultContentWorkflow.perform(DefaultContentWorkflow.java:74)",
      "org.primeframework.mvc.parameter.DefaultParameterWorkflow.perform(DefaultParameterWorkflow.java:58)",
      "org.primeframework.mvc.parameter.DefaultURIParameterWorkflow.perform(DefaultURIParameterWorkflow.java:92)",
      "org.primeframework.mvc.scope.DefaultScopeRetrievalWorkflow.perform(DefaultScopeRetrievalWorkflow.java:50)",
      "org.primeframework.mvc.action.DefaultActionMappingWorkflow.perform(DefaultActionMappingWorkflow.java:130)",
      "org.primeframework.mvc.security.DefaultSavedRequestWorkflow.perform(DefaultSavedRequestWorkflow.java:65)",
      "org.primeframework.mvc.cors.CORSFilter.doFilter(CORSFilter.java:188)",
      "org.primeframework.mvc.cors.CORSRequestWorkflow.perform(CORSRequestWorkflow.java:66)",
      "org.primeframework.mvc.workflow.DefaultMVCWorkflow.perform(DefaultMVCWorkflow.java:109)",
      "org.primeframework.mvc.PrimeMVCRequestHandler.handle(PrimeMVCRequestHandler.java:76)",
      "io.fusionauth.http.server.internal.HTTPWorker.run(HTTPWorker.java:183)",
      "java.base\/java.lang.VirtualThread.run(VirtualThread.java:329)"
<p dir="auto">I enabled trace logging in <code>io.fusionauth.http.server.internal</code> to analyse the process in HTTPWorker</p>
<pre><code>2026-03-12 03:53:18.758 PM TRACE io.fusionauth.http.server.internal.HTTPWorker - [993] Running HTTP worker. Block while we wait to read the preamble
2026-03-12 03:53:18.758 PM TRACE io.fusionauth.http.server.internal.HTTPWorker - [993] Set state [Process]. Call the request handler.
2026-03-12 03:53:18.773 PM TRACE io.fusionauth.http.server.internal.HTTPWorker - [993] Handler completed successfully
2026-03-12 03:53:18.773 PM TRACE io.fusionauth.http.server.internal.HTTPWorker - [993] Enter Keep-Alive state [KeepAlive] Reset socket timeout [60000].
2026-03-12 03:53:18.773 PM TRACE io.fusionauth.http.server.internal.HTTPWorker - [993] Running HTTP worker. Block while we wait to read the preamble
2026-03-12 03:53:18.775 PM TRACE io.fusionauth.http.server.internal.HTTPWorker - [993] Set state [Process]. Call the request handler.
2026-03-12 03:53:18.776 PM TRACE io.fusionauth.http.server.internal.HTTPWorker - [993] Handler completed successfully
2026-03-12 03:53:18.776 PM TRACE io.fusionauth.http.server.internal.HTTPWorker - [993] Enter Keep-Alive state [KeepAlive] Reset socket timeout [60000].
2026-03-12 03:53:18.776 PM TRACE io.fusionauth.http.server.internal.HTTPWorker - [993] Running HTTP worker. Block while we wait to read the preamble
2026-03-12 03:53:18.777 PM TRACE io.fusionauth.http.server.internal.HTTPWorker - [993] Set state [Process]. Call the request handler.
2026-03-12 03:53:19.977 PM TRACE io.fusionauth.http.server.internal.HTTPServerThread - [993] Check worker in state [Write]
2026-03-12 03:53:21.978 PM TRACE io.fusionauth.http.server.internal.HTTPServerThread - [993] Check worker in state [Write]
2026-03-12 03:53:23.979 PM TRACE io.fusionauth.http.server.internal.HTTPServerThread - [993] Check worker in state [Write]
2026-03-12 03:55:54.019 PM TRACE io.fusionauth.http.server.internal.HTTPServerThread - [993] Check worker in state [Write]
2026-03-12 03:55:56.019 PM DEBUG io.fusionauth.http.server.internal.HTTPServerThread - [993] Check worker in state [Write] writingSlow=[true] writeThroughput=[16271] minimumWriteThroughput=[16384]
2026-03-12 03:55:56.019 PM DEBUG io.fusionauth.http.server.internal.HTTPServerThread - [993] Closing connection readingSlow=[false] writingSlow=[true] timedOut=[false]  Min write throughput [16384], actual throughput [16271].
2026-03-12 03:55:56.019 PM DEBUG io.fusionauth.http.server.internal.HTTPServerThread - [993] Closing client connection [/127.0.0.1:36278] due to inactivity
2026-03-12 03:55:56.021 PM TRACE io.fusionauth.http.server.internal.HTTPServerThread - Thread dump from server side.
2026-03-12 03:55:56.024 PM DEBUG io.fusionauth.http.server.internal.HTTPWorker - [993] Closing socket. The socket was closed by a client, proxy or otherwise.
<p dir="auto">The HTTPWorker begins the process of reading and writing the response for the request, and continues for 2.6 minutes until the HTTPServerThread terminates it because the minimumWriteThroughput (16KB/sec) threshold has not been met.</p>
<p dir="auto">HTTPServerCleanerThread kills the server-side connection mid-response due to a write throughput check that measures average bytes/sec since the first socket write.<br />
The client is waiting for data that the server is generating very slowly.</p>
<p dir="auto">Analyzing why the server is writing so slowly (16271 bytes/sec):<br />
The call is <a href="http://localhost:9012" rel="nofollow ugc">http://localhost:9012</a> — FusionAuth calls itself. Client and server virtual threads share the same JVM's carrier thread pool.<br />
With Kubernetes CPU limit = 1000m, JDK 21 uses UseContainerSupport (default), so availableProcessors() = 1 → only 1 carrier thread.</p>
<p dir="auto">com.inversoft.rest.JSONResponseHandler$BetterBufferedInputStream.read(byte[], int, int) is synchronized — causes virtual thread carrier thread pinning in JDK 21.</p>
<li>Client virtual thread enters synchronized read() → calls ChunkedInputStream.fastRead() → calls socket.read() which blocks → PINS the carrier thread (can't unmount from synchronized block)</li>
<li>Server virtual thread needs to write more data but cannot get a carrier thread (carrier thread pinned by client)</li>
<li>Neither makes progress → throughput decays over time as numberOfBytesWritten is fixed but elapsed keeps growing</li>
<p dir="auto"><code>BetterBufferedInputStream.read()</code> pins that single carrier thread while blocking on <code>ChunkedInputStream.fastRead()</code>, leaving no carrier thread for the server to write more data. The resulting ping-pong limits throughput to ~16 KB/sec on a 2.5MB response.</p>
<p dir="auto">HTTPServerCleanerThread computes average throughput since the very first write (not a recent window). With 2.5MB written at 16271 bytes/sec average, that's ~156 seconds (2.6 min) before the average decays below the 16384 bytes/sec threshold.</p>
<p dir="auto">With 9 themes, the response is small enough to fit entirely within the kernel’s socket buffer (~128KB). The server writes the entire content in one go without blocking on <code>socket.write()</code> (the buffer does not fill up), transitions to the KeepAlive state, and the cleaner can no longer terminate the connection due to write throughput.</p>
<p dir="auto">As a workaround, I resolved the issue <strong>increasing the Kubernetes CPU limit from 1000m to 1050m</strong>.<br />
Kubernetes translates the CPU limit into the container’s cgroups, setting 2 carrier threads instead of 1.</p>
<p dir="auto">With that CPU limit, all themes are recovered properly, also with 35 themes (~6.2 MB response).</p>
<p dir="auto">Can you reproduce it setting Kubernetes CPU limit to 1000m (1 core) in your environment?</p>
]]></description><link>https://fusionauth.io/community/forum/post/8526</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8526</guid><dc:creator><![CDATA[david.cuen]]></dc:creator><pubDate>Mon, 16 Mar 2026 13:06:13 GMT</pubDate></item><item><title><![CDATA[Reply to Admin UI actions over themes blocks application since 1.61.2 on Thu, 12 Feb 2026 16:22:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/3748">@david-cuen</a> Thanks for your patience and dedication to seeing this through. It would help a ton if you could find something reproducible. Let me know what you find and I can continue to try it on this end.</p>
]]></description><link>https://fusionauth.io/community/forum/post/8507</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8507</guid><dc:creator><![CDATA[mark.robustelli]]></dc:creator><pubDate>Thu, 12 Feb 2026 16:22:26 GMT</pubDate></item><item><title><![CDATA[Reply to Admin UI actions over themes blocks application since 1.61.2 on Wed, 11 Feb 2026 11:41:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2507">@mark-robustelli</a><br />
The instance is currently running in an AWS EC2 Linux environment. I'm sorry, but I can't change the infrastructure.</p>
<p dir="auto">The error occurs when processing the response to the internal call made from FusionAuth with the RESTClient to the endpoint<br />
<a href="http://localhost:9012/api/theme/search" rel="nofollow ugc">http://localhost:9012/api/theme/search</a>.<br />
As far as I know, there is no proxy running in front of this internal FusionAuth call.</p>
<p dir="auto">I have tried making calls to /api/theme/search from outside of the instance container.<br />
The result is always correct and with the complete JSON response.</p>
<p dir="auto">Regarding funky characters in themes, in my tests they are all clones of the default advanced theme. So I can't understand the difference in the error when having +1 default advanced theme, only what was mentioned about the final size of the response.</p>
<p dir="auto">I'm going to try to reproduce it using default simple theme clones.</p>
]]></description><link>https://fusionauth.io/community/forum/post/8506</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8506</guid><dc:creator><![CDATA[david.cuen]]></dc:creator><pubDate>Wed, 11 Feb 2026 11:41:32 GMT</pubDate></item><item><title><![CDATA[Reply to Admin UI actions over themes blocks application since 1.61.2 on Mon, 09 Feb 2026 21:47:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/3748">@david-cuen</a> This is really weird. I was not able to replicate it. There is one more thing I may try later if I get some time. That is to make one template that big and try that.</p>
<p dir="auto">In the mean time, I went back to look at the error message. "Premature EOF" and the fact that it was working on a windows box has be back to believing that a funky character or something is causing the error on the linux box. I wish we could narrow it down. Have you tried to install into another linux environment, EC2 for example, and see if you get the same issue? (That may tell us if it is a linux thing or if it is your one specific environment.) Also, someone mentioned to ask if you have any proxies running in front of FusionAuth?</p>
]]></description><link>https://fusionauth.io/community/forum/post/8505</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8505</guid><dc:creator><![CDATA[mark.robustelli]]></dc:creator><pubDate>Mon, 09 Feb 2026 21:47:56 GMT</pubDate></item><item><title><![CDATA[Reply to Admin UI actions over themes blocks application since 1.61.2 on Mon, 09 Feb 2026 15:06:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/3748">@david-cuen</a> I wasn't able to find much else out on Friday. Awesome that it looks like you have it narrowed down to the size. I will try to replicate this. I will let you know if I can.</p>
]]></description><link>https://fusionauth.io/community/forum/post/8504</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8504</guid><dc:creator><![CDATA[mark.robustelli]]></dc:creator><pubDate>Mon, 09 Feb 2026 15:06:54 GMT</pubDate></item><item><title><![CDATA[Reply to Admin UI actions over themes blocks application since 1.61.2 on Mon, 09 Feb 2026 09:22:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2507">@mark-robustelli</a> The error occurs when the response from the theme search is greater than 2.5 MB.</p>
<p dir="auto">I don't know if it's related or not, but it happens to me in versions of FusionAuth later than 1.60.2.<br />
In the release notes for version 1.61.0, an upgrade of the Jackson dependencies has just been made</p>
<p dir="auto"><a href="https://fusionauth.io/docs/release-notes/#version-1-61-0" rel="nofollow ugc">https://fusionauth.io/docs/release-notes/#version-1-61-0</a></p>
<pre><code>Upgrade com.fasterxml.jackson.* 2.17.2 -&gt; 2.19.2
<p dir="auto">In that version of Jackson, the collection deserialization process has been modified.</p>
]]></description><link>https://fusionauth.io/community/forum/post/8503</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8503</guid><dc:creator><![CDATA[david.cuen]]></dc:creator><pubDate>Mon, 09 Feb 2026 09:22:20 GMT</pubDate></item><item><title><![CDATA[Reply to Admin UI actions over themes blocks application since 1.61.2 on Fri, 06 Feb 2026 17:14:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/3748">@david-cuen</a> sorry for the delayed response. I was unexpectedly out. Thanks for trying to dig a bit deeper. The message you definitely leads me to believe that it is either a specific theme or as you said a size thing. Both are a bit confusing to me as the size you  mentioned for your themes does not seem that bit and you stated that you tried loading the themes in different orders and that did not seem to make a difference. I will see if I can dig a little deeper on these error messages and see if there is anything I can find.</p>
]]></description><link>https://fusionauth.io/community/forum/post/8501</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8501</guid><dc:creator><![CDATA[mark.robustelli]]></dc:creator><pubDate>Fri, 06 Feb 2026 17:14:20 GMT</pubDate></item><item><title><![CDATA[Reply to Admin UI actions over themes blocks application since 1.61.2 on Tue, 03 Feb 2026 17:30:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2507">@mark-robustelli</a> I've launched the instance in the infrastructure enabling an agentlib to perform remote debugging of the JVM.</p>
<p dir="auto">Debugging the theme search process, I see following exception produced in the RESTClient response of the API call</p>
<pre><code>com.inversoft.rest.JSONException: Failed to parse the HTTP response as JSON. Actual HTTP response body:
Note: Output has been truncated to the first 1024 of 2560141 bytes.
{"themes":[{"data":{},"defaultMessages":"#\n# Date and Time formats\n#\ndate-format=M/d/yyyy\ndate-time-format=M/d/yyyy hh:mm a z\ndate-time-seconds-format=M/d/yyyy hh:mm:ss a z\n\n#\n# Text used on the page (inside the HTML). You can create new key-value pairs here and use them in the templates.\n#\naccess-denied=Access denied\naccount=Account\naction=Action\nadd-two-factor=Add two-factor\nadd-webauthn-passkey=Add passkey\nback-to-login=Return to Login\ncancel=Cancel\ncaptcha-google-branding=This site is protected by reCAPTCHA and the Google &lt;a href=\"https://policies.google.com/privacy\" class=\"text-indigo-500 hover:text-indigo-700 font-medium focus:outline-none focus:underline\"&gt;Privacy Policy&lt;/a&gt; and &lt;a href=\"https://policies.google.com/terms\" class=\"text-indigo-500 hover:text-indigo-700 font-medium focus:outline-none focus:underline\"&gt;Terms of Service&lt;/a&gt; apply.\ncreated=Created\ncustomize=Customize\nauthorized-not-registered=Registration is required to access this application and your account has no
<p dir="auto">Cause:</p>
<pre><code>"com.fasterxml.jackson.databind.JsonMappingException: Premature EOF (through reference chain: io.fusionauth.domain.api.ThemeSearchResponse["themes"]-&gt;java.util.ArrayList[9])"
<p dir="auto">StackTrace:</p>
<pre><code>com.inversoft.rest.JSONResponseHandler.apply(JSONResponseHandler.java:73)
java.base/jdk.internal.reflect.DirectMethodHandleAccessor.invoke(DirectMethodHandleAccessor.java:103)
java.base/java.lang.reflect.Method.invoke(Method.java:580)
java.base/java.lang.VirtualThread.run(VirtualThread.java:329)
]]></description><link>https://fusionauth.io/community/forum/post/8499</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8499</guid><dc:creator><![CDATA[david.cuen]]></dc:creator><pubDate>Tue, 03 Feb 2026 17:30:02 GMT</pubDate></item><item><title><![CDATA[Reply to Admin UI actions over themes blocks application since 1.61.2 on Tue, 03 Feb 2026 10:38:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2507">@mark-robustelli</a> The size of the tpl folders for each theme is around 352 KB - 404 KB.</p>
<p dir="auto">I would like to mention that the hang occurs when launching the instance in a Linux environment with the Docker image.<br />
If I launch a local instance on a Windows computer against the same PostgreSQL database, the hang problem does not occur.</p>
Platform: Windows 11 10.0 amd64</p>
<p dir="auto">Instances are launched with ENV var:<br />
FUSIONAUTH_APP_MEMORY=1024M<br />
DATABASE_CONNECTION_HEALTHCHECK_99PERCENT_MS=500</p>
<p dir="auto">When consulting Prometheus metrics with /api/status after the instance has recovered from the hang, errors appear in the theme search</p>
<pre><code>            "prime-mvc.[/api/theme/search].errors": {
                "count": 2,
                "fifteenMinuteRate": 0.001224500060165843,
                "fiveMinuteRate": 0.002437052376257949,
                "meanRate": 0.0012614192847508726,
                "oneMinuteRate": 0.003282810949244636
<p dir="auto">Any idea how to find the error that occurs in the internal call from fusionauth admin app to its API?</p>
]]></description><link>https://fusionauth.io/community/forum/post/8498</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8498</guid><dc:creator><![CDATA[david.cuen]]></dc:creator><pubDate>Tue, 03 Feb 2026 10:38:17 GMT</pubDate></item><item><title><![CDATA[Reply to Admin UI actions over themes blocks application since 1.61.2 on Mon, 02 Feb 2026 15:56:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/3748">@david-cuen</a> Goodnews and badnews. The goodnews is that I imported the exact theme you pointed to and was able to copy that 11 times and not issues. My environment now has 26 themes. The badnews is that is not helping you. Sorry. I think we need to dig a little further. Based on the additional pages you mentioned (adding/editing tenant/application) I am wondering if something specific with the edits you have made to the themes. The fact that you change the order they are loaded in makes that less likely though. What are the sizes of the tpl folders for your themes?</p>
]]></description><link>https://fusionauth.io/community/forum/post/8497</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8497</guid><dc:creator><![CDATA[mark.robustelli]]></dc:creator><pubDate>Mon, 02 Feb 2026 15:56:53 GMT</pubDate></item><item><title><![CDATA[Reply to Admin UI actions over themes blocks application since 1.61.2 on Fri, 30 Jan 2026 18:28:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/3748">@david-cuen</a> perfect. I was copying themes, but will us that one and let you know what I find.</p>
]]></description><link>https://fusionauth.io/community/forum/post/8494</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8494</guid><dc:creator><![CDATA[mark.robustelli]]></dc:creator><pubDate>Fri, 30 Jan 2026 18:28:01 GMT</pubDate></item><item><title><![CDATA[Reply to Admin UI actions over themes blocks application since 1.61.2 on Fri, 30 Jan 2026 12:41:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2507">@mark-robustelli</a> I have downloaded the FusionAuth advanced default theme (id 75a068fd-e94b-451a-9aeb-3ddb9a3b5987) used in the tests with the FusionAuth CLI</p>
<p dir="auto">The files are available in<br />
<a href="https://github.com/davidcuenavoristravel/fusionauth-shared-themes/tree/main/default_theme/tpl" rel="nofollow ugc">https://github.com/davidcuenavoristravel/fusionauth-shared-themes/tree/main/default_theme/tpl</a></p>
<p dir="auto">Best regards.</p>
]]></description><link>https://fusionauth.io/community/forum/post/8493</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8493</guid><dc:creator><![CDATA[david.cuen]]></dc:creator><pubDate>Fri, 30 Jan 2026 12:41:04 GMT</pubDate></item><item><title><![CDATA[Reply to Admin UI actions over themes blocks application since 1.61.2 on Wed, 28 Jan 2026 23:34:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/3748">@david-cuen</a> OK, I was able to get more than 10, but you're right about it possibly being the size. Is it possible for you to <a href="https://fusionauth.io/docs/customize/cli" rel="nofollow ugc">share the theme</a> you are using with us or me individually? I don't want you to give away any secrets, proprietary info or share anything private if you can't but getting a look at the theme may help.</p>
]]></description><link>https://fusionauth.io/community/forum/post/8492</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8492</guid><dc:creator><![CDATA[mark.robustelli]]></dc:creator><pubDate>Wed, 28 Jan 2026 23:34:31 GMT</pubDate></item><item><title><![CDATA[Reply to Admin UI actions over themes blocks application since 1.61.2 on Wed, 28 Jan 2026 16:02:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/3748">@david-cuen</a> Awesome that you have isolated the issues. I am going to test from my side and see if I can replicate with the 10+ themes. If I can then you should report this as a bug. I will let you know what I find. Hope to be able to get to this today.</p>
]]></description><link>https://fusionauth.io/community/forum/post/8488</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8488</guid><dc:creator><![CDATA[mark.robustelli]]></dc:creator><pubDate>Wed, 28 Jan 2026 16:02:12 GMT</pubDate></item><item><title><![CDATA[Reply to Admin UI actions over themes blocks application since 1.61.2 on Wed, 28 Jan 2026 12:09:16 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2507">@mark-robustelli</a>, thanks for your reply.<br />
I have created a new instance as you suggested.</p>
<p dir="auto">With only the two default themes ("FusionAuth" and "FusionAuth - Simple"), everything works correctly.</p>
<p dir="auto">I have been importing our themes one by one (all of them are advanced themes).<br />
The search works correctly until it reaches 10 registered themes. After that number, the same error occurs.<br />
It does not matter which themes are registered, but rather the total number of themes. Changing the themes creation order produces the same result.</p>
<p dir="auto">To discard problems in our themes data, I deleted them and started testing from scratch.</p>
<p dir="auto">I created new themes using the default advanced theme "FusionAuth" as base and duplicating it.<br />
When the 10 existing themes are reached, the problem occurs again.</p>
<p dir="auto"><img src="/community/forum/assets/uploads/files/1769601145160-6ea282f4-e432-432e-b2c4-5bbc7de44eb2-image.png" alt="6ea282f4-e432-432e-b2c4-5bbc7de44eb2-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Creating new themes using the default simple theme as base, I have not been able to reproduce the problem exceeding 10 registered themes.</p>
<p dir="auto"><img src="/community/forum/assets/uploads/files/1769601982403-32b0331c-f811-44ad-9f41-e10bb7eed861-image.png" alt="32b0331c-f811-44ad-9f41-e10bb7eed861-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I assume that the problem is not related to the number of themes registered, but rather to the volume of data that they all contain.</p>
]]></description><link>https://fusionauth.io/community/forum/post/8487</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8487</guid><dc:creator><![CDATA[david.cuen]]></dc:creator><pubDate>Wed, 28 Jan 2026 12:09:16 GMT</pubDate></item><item><title><![CDATA[Reply to Admin UI actions over themes blocks application since 1.61.2 on Mon, 26 Jan 2026 15:03:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/3748">@david-cuen</a> can you try to spin up a new instance and let me know if you see the problem? If not, it may have to do specifically with the themes themselves. If the new instance works correctly, import each theme and test. This may help narrow the issue.</p>
]]></description><link>https://fusionauth.io/community/forum/post/8486</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8486</guid><dc:creator><![CDATA[mark.robustelli]]></dc:creator><pubDate>Mon, 26 Jan 2026 15:03:19 GMT</pubDate></item><item><title><![CDATA[Reply to Admin UI actions over themes blocks application since 1.61.2 on Fri, 23 Jan 2026 14:59:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/3748">@david-cuen</a> Thanks for the detailed message. I hope to have some time today to try and replicate this. I will let you know what I see.</p>
]]></description><link>https://fusionauth.io/community/forum/post/8485</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8485</guid><dc:creator><![CDATA[mark.robustelli]]></dc:creator><pubDate>Fri, 23 Jan 2026 14:59:56 GMT</pubDate></item></channel></rss>
