<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Twillio Messenger]]></title><description><![CDATA[<p dir="auto">Hi community,</p>
<p dir="auto">I am trying to create a Twillio messenger to be able to perform MFA for my users.</p>
<p dir="auto">I create a Message Service in Twillio and then in Fusion Auth I fill in the information required in Twillio Messenger form.</p>
<p dir="auto">URL: <a href="https://api.twilio.com" rel="nofollow ugc">https://api.twilio.com</a><br />
AccountSID, AuthToken,  From phone Number and Messaging service id all provided by Twillio.</p>
<p dir="auto">When I try to test this configuration with my phone number I get an error</p>
<pre><code>An unexpected error occurred, review the system logs for additional details.
<p dir="auto">But I don't see anything in my logs.</p>
<p dir="auto">When I sent an SMS directly from Twillio it works great.</p>
<p dir="auto">Any help or advice would be appraciate.</p>
<p dir="auto">My fusion instance is hosted and it is 1.62.1</p>
<p dir="auto">Thanks<br />
Romain</p>
]]></description><link>https://fusionauth.io/community/forum/topic/3095/twillio-messenger</link><generator>RSS for Node</generator><lastBuildDate>Sat, 07 Nov 2026 02:01:21 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/3095.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 17 Feb 2026 20:53:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Twillio Messenger on Wed, 18 Feb 2026 17:46:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/3769">@rgros</a> Do you have Debug enabled?</p>
<p dir="auto"><img src="/community/forum/assets/uploads/files/1771436733830-screenshot-2026-02-18-at-10.43.14-am.png" alt="Screenshot 2026-02-18 at 10.43.14 AM.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Then you should check your Event Log.</p>
<p dir="auto"><img src="/community/forum/assets/uploads/files/1771436754946-screenshot-2026-02-18-at-10.44.20-am.png" alt="Screenshot 2026-02-18 at 10.44.20 AM.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Let us know what you find.</p>
]]></description><link>https://fusionauth.io/community/forum/post/8510</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8510</guid><dc:creator><![CDATA[mark.robustelli]]></dc:creator><pubDate>Wed, 18 Feb 2026 17:46:06 GMT</pubDate></item></channel></rss>
