<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Weird behavior for OpenID connect login after 1.62 upgrade - MS prompts to verify email]]></title><description><![CDATA[<p dir="auto">Since upgrading from 1.59 to 1.62 if a username is entered on the FusionAuth login screen, if you select to login with OpenID connect (ours is validating against M365), we get a prompt to "verify your email".  If you don't fill in a username, the prompt does not come up and login works as it should.  This was not an issue in 1.59 or earlier.</p>
<p dir="auto">Login with fake username added (username does not exist in M365 or FusionAuth)</p>
<p dir="auto"><img src="/community/forum/assets/uploads/files/1771416374738-b7578d9d-453a-481a-94b4-24ea584d7043-image.png" alt="b7578d9d-453a-481a-94b4-24ea584d7043-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Result after hitting "Login with OpenID Connect" -- note the username and wonky email foo*****@bar.com</p>
<p dir="auto"><img src="/community/forum/assets/uploads/files/1771416481916-b2c143e5-a57f-4a0c-b76a-f57e37d0923e-image.png" alt="b2c143e5-a57f-4a0c-b76a-f57e37d0923e-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://fusionauth.io/community/forum/topic/3096/weird-behavior-for-openid-connect-login-after-1-62-upgrade-ms-prompts-to-verify-email</link><generator>RSS for Node</generator><lastBuildDate>Wed, 11 Nov 2026 12:15:16 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/3096.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 18 Feb 2026 12:09:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Weird behavior for OpenID connect login after 1.62 upgrade - MS prompts to verify email on Fri, 27 Mar 2026 19:09:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2507">@mark-robustelli</a> I just upgraded to 1.64, still happens, exact same behavior</p>
]]></description><link>https://fusionauth.io/community/forum/post/8535</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8535</guid><dc:creator><![CDATA[scottw]]></dc:creator><pubDate>Fri, 27 Mar 2026 19:09:24 GMT</pubDate></item><item><title><![CDATA[Reply to Weird behavior for OpenID connect login after 1.62 upgrade - MS prompts to verify email on Wed, 18 Feb 2026 17:48:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/737">@scottw</a> Hopefully, I can get a little time over the next couple of days and see if I can duplicate it. I will let you know if I find anything.  Anyone else seeing his behavior?</p>
]]></description><link>https://fusionauth.io/community/forum/post/8511</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8511</guid><dc:creator><![CDATA[mark.robustelli]]></dc:creator><pubDate>Wed, 18 Feb 2026 17:48:31 GMT</pubDate></item></channel></rss>
