<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[SAML authnRequest exception]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I am trying to implement FusionAuth as idP for an application (SuiteCRM) and am getting an error at the redirect.</p>
<p dir="auto">I am running FusionAuth (1.62.1) in Docker for testing but get the same error on our staging instance.</p>
<p dir="auto">The error is:</p>
<pre><code>FusionAuth encountered an exception while processing the SAML v2 AuthnRequest.
The request originated from: 172.19.0.1.
SAMLRequest: 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
Exception:
io.fusionauth.samlv2.domain.SAMLException: Invalid AuthnRequest. Inflating the bytes failed.
  at io.fusionauth.samlv2.util.SAMLTools.decodeAndInflate(SAMLTools.java:168)
  at io.fusionauth.samlv2.service.DefaultSAMLv2Service.parseRequestRedirectBinding(DefaultSAMLv2Service.java:641)
  at io.fusionauth.api.service.samlv2.DefaultSAMLv2ProviderService.parseAuthNRedirectRequest(DefaultSAMLv2ProviderService.java:314)
  at io.fusionauth.app.action.samlv2.LoginAction.lambda$get$0(LoginAction.java:101)
  at io.fusionauth.app.action.samlv2.BaseSAMLAction.handleSAMLException(BaseSAMLAction.java:111)
  at io.fusionauth.app.action.samlv2.LoginAction.get(LoginAction.java:98)
  at java.base/jdk.internal.reflect.DirectMethodHandleAccessor.invoke(DirectMethodHandleAccessor.java:103)
  at java.base/java.lang.reflect.Method.invoke(Method.java:580)
  at org.primeframework.mvc.util.ReflectionUtils.invoke(ReflectionUtils.java:443)
  at org.primeframework.mvc.action.DefaultActionInvocationWorkflow.execute(DefaultActionInvocationWorkflow.java:77)
  at org.primeframework.mvc.action.DefaultActionInvocationWorkflow.perform(DefaultActionInvocationWorkflow.java:60)
  at org.primeframework.mvc.workflow.SubWorkflowChain.continueWorkflow(SubWorkflowChain.java:50)
  at org.primeframework.mvc.message.DefaultMessageWorkflow.perform(DefaultMessageWorkflow.java:50)
  at org.primeframework.mvc.validation.DefaultValidationWorkflow.perform(DefaultValidationWorkflow.java:45)
  at org.primeframework.mvc.security.DefaultSecurityWorkflow.perform(DefaultSecurityWorkflow.java:60)
  at org.primeframework.mvc.parameter.DefaultPostParameterWorkflow.perform(DefaultPostParameterWorkflow.java:49)
  at org.primeframework.mvc.content.DefaultContentWorkflow.perform(DefaultContentWorkflow.java:74)
  at org.primeframework.mvc.parameter.DefaultParameterWorkflow.perform(DefaultParameterWorkflow.java:58)
  at org.primeframework.mvc.parameter.DefaultURIParameterWorkflow.perform(DefaultURIParameterWorkflow.java:92)
  at org.primeframework.mvc.scope.DefaultScopeRetrievalWorkflow.perform(DefaultScopeRetrievalWorkflow.java:50)
  at org.primeframework.mvc.action.DefaultActionMappingWorkflow.perform(DefaultActionMappingWorkflow.java:130)
  at org.primeframework.mvc.security.DefaultSavedRequestWorkflow.perform(DefaultSavedRequestWorkflow.java:65)
  at org.primeframework.mvc.cors.CORSRequestWorkflow.perform(CORSRequestWorkflow.java:68)
  at org.primeframework.mvc.workflow.DefaultMVCWorkflow.perform(DefaultMVCWorkflow.java:109)
  at org.primeframework.mvc.PrimeMVCRequestHandler.handle(PrimeMVCRequestHandler.java:76)
  at io.fusionauth.http.server.internal.HTTPWorker.run(HTTPWorker.java:183)
  at java.base/java.lang.VirtualThread.run(VirtualThread.java:329)
Caused by: java.util.zip.DataFormatException: invalid code lengths set
  at java.base/java.util.zip.Inflater.inflateBytesBytes(Native Method)
  at java.base/java.util.zip.Inflater.inflate(Inflater.java:376)
  at java.base/java.util.zip.Inflater.inflate(Inflater.java:470)
  at io.fusionauth.samlv2.util.SAMLTools.decodeAndInflate(SAMLTools.java:158)
  ... 37 more
<p dir="auto">Using the Onelogin decoder tool (<a href="https://www.samltool.com/decode.php" rel="nofollow ugc">https://www.samltool.com/decode.php</a>) the request seems valid and is shown below:</p>
<pre><code>&lt;samlp:AuthnRequest
    xmlns:samlp="urn:oasis:names:tc:SAML:2.0:protocol"
    xmlns:saml="urn:oasis:names:tc:SAML:2.0:assertion"
    ID="ONELOGIN_5d10bafc7b1602cbb1ac37c509e360e855819860"
    Version="2.0"
    ProviderName="Example"
    IssueInstant="2026-02-19T14:49:55Z"
    Destination="http://localhost:9013/samlv2/login/ee0d98b5-0d7c-11f1-8200-364d3bfc89af"
    ProtocolBinding="urn:oasis:names:tc:SAML:2.0:bindings:HTTP-POST"
    AssertionConsumerServiceURL="http://localhost/saml/acs"&gt;
    &lt;saml:Issuer&gt;http://localhost/saml/login&lt;/saml:Issuer&gt;
    &lt;samlp:NameIDPolicy
        Format="urn:oasis:names:tc:SAML:1.1:nameid-format:unspecified"
        AllowCreate="true" /&gt;
&lt;/samlp:AuthnRequest&gt;
<p dir="auto">In SuiteCRM I am following the directions in the manual here:<br />
[<a href="https://docs.suitecrm.com/8.x/admin/configuration/saml/8.7.0-saml-configuration/" rel="nofollow ugc">https://docs.suitecrm.com/8.x/admin/configuration/saml/8.7.0-saml-configuration/</a>](link url)</p>
<p dir="auto">If anyone has any ideas what I am doing wrong?</p>
<p dir="auto">Thanks.</p>
]]></description><link>https://fusionauth.io/community/forum/topic/3097/saml-authnrequest-exception</link><generator>RSS for Node</generator><lastBuildDate>Wed, 11 Nov 2026 12:38:13 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/3097.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 19 Feb 2026 15:40:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to SAML authnRequest exception on Thu, 02 Apr 2026 14:16:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2507">@mark-robustelli</a> cheers, that was a useful post. The IAMShowcase tools did help me filter out what was correct and what was not. Eventually I found that the compression config settings on the passed request were not correct.</p>
]]></description><link>https://fusionauth.io/community/forum/post/8544</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8544</guid><dc:creator><![CDATA[james.hudson]]></dc:creator><pubDate>Thu, 02 Apr 2026 14:16:31 GMT</pubDate></item><item><title><![CDATA[Reply to SAML authnRequest exception on Fri, 20 Feb 2026 15:36:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/1129">@james-hudson</a> You may want to check out this <a href="https://fusionauth.io/blog/test-saml-configuration" rel="nofollow ugc">blog</a> post. Hopefully that can help.</p>
]]></description><link>https://fusionauth.io/community/forum/post/8514</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8514</guid><dc:creator><![CDATA[mark.robustelli]]></dc:creator><pubDate>Fri, 20 Feb 2026 15:36:40 GMT</pubDate></item></channel></rss>
