<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Upgrading 1.64.1 to 1.65.0 never boots]]></title><description><![CDATA[<p dir="auto">I upgraded my FusionAuth instance (self-hosted container) from 1.64.1 to 1.65.0, but the container never starts.<br />
Reading the logs during start up I found the following issue</p>
<pre><code>SQL: SELECT internal_authentication_keys_id FROM instance LIMIT 1"}
Cause: org.postgresql.util.PSQLException: ERROR: column \"internal_authentication_keys_id\" does not exist"}
ERROR org.primeframework.mvc.guice.GuiceBootstrap - Unable to start the server. Exception:"}
<p dir="auto">So the app is clearly expecting a schema change that my database doesn’t have.</p>
<p dir="auto">What’s confusing is:</p>
<p dir="auto">There are no visible migration scripts running during startup<br />
Release notes don’t mention a migration step<br />
But 1.65 clearly assumes this column exists in instance</p>
<p dir="auto">I downloaded the schemas for both versions and instance.internal_authentication_keys does exist on 1.65.0, but not 1.64.1</p>
]]></description><link>https://fusionauth.io/community/forum/topic/3131/upgrading-1-64-1-to-1-65-0-never-boots</link><generator>RSS for Node</generator><lastBuildDate>Tue, 12 May 2026 08:27:10 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/3131.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 08 May 2026 10:31:27 GMT</pubDate><ttl>60</ttl></channel></rss>
