<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Unable to Reset Locked Account Password when MFA Enabled]]></title><description><![CDATA[<p dir="auto">It seems like the issue of "When using a password reset flow to unlock a user account, the process may fail if the user has MFA enabled." was noted in the 1.43.0 release. What exactly was the fix?</p>
<p dir="auto">I am currently trying to set up the forgot password flow for users with locked account (ie. too many failed_login_attempts). For uses who have MFA enabled, they need to complete step up challenge first however I am getting a 500 error when trying to hit the /two-factor/login point to get a trustToken. How do I complete the forgot password flow with trust token for MFA users when their accounts are locked?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/3136/unable-to-reset-locked-account-password-when-mfa-enabled</link><generator>RSS for Node</generator><lastBuildDate>Tue, 16 Jun 2026 18:35:37 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/3136.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 12 Jun 2026 20:28:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Unable to Reset Locked Account Password when MFA Enabled on Tue, 16 Jun 2026 16:07:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/3839">@anthea-mo</a> It looks like the <a href="https://github.com/FusionAuth/fusionauth-issues/issues/1909" rel="nofollow ugc">fix</a> is to upgrade.</p>
<p dir="auto">I also found <a href="https://github.com/FusionAuth/fusionauth-issues/issues/383" rel="nofollow ugc">this</a> on the users accounts being locked.</p>
<p dir="auto">If this information does not get you where you need, please let me know.</p>
]]></description><link>https://fusionauth.io/community/forum/post/8606</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8606</guid><dc:creator><![CDATA[mark.robustelli]]></dc:creator><pubDate>Tue, 16 Jun 2026 16:07:12 GMT</pubDate></item></channel></rss>
