<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Update on supporting discoverable WebAuthn credentials]]></title><description><![CDATA[<p dir="auto">From what I can tell in the docs, the FusionAuth API does not support discoverable WebAuthn passkeys: <a href="https://fusionauth.io/docs/apis/webauthn/complete-a-webauthn-passkey-registration#request-body" rel="nofollow ugc">https://fusionauth.io/docs/apis/webauthn/complete-a-webauthn-passkey-registration#request-body</a>. I wanted to confirm this is accurate as it is not very transparent from the docs, and if there are any plans to add support for this.</p>
<p dir="auto">I want to implement a passkey login using the WebAuthn API where the user does not need to provide a username/email. I understand there is a "re-authentication" workflow, but that seems designed around the hosted login pages rather than the API. Thanks!</p>
]]></description><link>https://fusionauth.io/community/forum/topic/3141/update-on-supporting-discoverable-webauthn-credentials</link><generator>RSS for Node</generator><lastBuildDate>Sat, 07 Nov 2026 13:35:18 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/3141.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 14 Aug 2026 01:18:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Update on supporting discoverable WebAuthn credentials on Wed, 19 Aug 2026 16:27:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/3594">@njanaskie</a> I don't have any experience with that flow. Hopefully someone that may have had some experience with this can chime in.</p>
]]></description><link>https://fusionauth.io/community/forum/post/8622</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8622</guid><dc:creator><![CDATA[mark.robustelli]]></dc:creator><pubDate>Wed, 19 Aug 2026 16:27:37 GMT</pubDate></item><item><title><![CDATA[Reply to Update on supporting discoverable WebAuthn credentials on Fri, 14 Aug 2026 22:44:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/2507">@mark-robustelli</a> Thanks for the response! I have a requirement to prompt for passkeys without a user first needing to identify themselves. A possible workaround would be for clients to remember the user so we can pass that along to the API. However, it is not a true discoverable passkey flow. I'll check to see if this is being tracked.</p>
]]></description><link>https://fusionauth.io/community/forum/post/8621</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8621</guid><dc:creator><![CDATA[njanaskie]]></dc:creator><pubDate>Fri, 14 Aug 2026 22:44:09 GMT</pubDate></item><item><title><![CDATA[Reply to Update on supporting discoverable WebAuthn credentials on Fri, 14 Aug 2026 16:25:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/3594">@njanaskie</a> said in <a href="/community/forum/post/8619">Update on supporting discoverable WebAuthn credentials</a>:</p>
<p dir="auto">You are right. FusionAuth does not support discoverable WebAuthn passkeys. In the page you referred to, there is some verbiage that states that directly in the <em>credential.clientExtensionResults.credProps.rk</em> section.</p>
<p dir="auto"><em>'FusionAuth does not currently support discoverable credentials (sometimes referred to as "resident keys").'</em></p>
<p dir="auto">I'd recommend checking the <a href="https://github.com/FusionAuth/fusionauth-issues" rel="nofollow ugc">FusionAuth GitHub issues</a> or opening/upvoting a feature request to track progress on this.</p>
<p dir="auto">Maybe if you tell us a little more about your use case and why the user can't enter the username/email someone can help with a work around.</p>
]]></description><link>https://fusionauth.io/community/forum/post/8620</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8620</guid><dc:creator><![CDATA[mark.robustelli]]></dc:creator><pubDate>Fri, 14 Aug 2026 16:25:07 GMT</pubDate></item></channel></rss>
