<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How does rollback work for FusionAuth Cloud after a major version upgrade?]]></title><description><![CDATA[<p dir="auto">We are planning to upgrade our FusionAuth Cloud instance from version 1.49.0 to 1.69.1 and want to understand the rollback process in case we encounter issues during the upgrade.</p>
<p dir="auto">Specifically:</p>
<li>How long are rollback backups retained after an upgrade?</li>
<li>Can we perform a rollback ourselves on FusionAuth Cloud, or does it need to be done by FusionAuth support?</li>
<li>What is the typical downtime for a rollback operation?</li>
<li>Are there any plan-specific limitations for rollback availability?</li>
]]></description><link>https://fusionauth.io/community/forum/topic/3156/how-does-rollback-work-for-fusionauth-cloud-after-a-major-version-upgrade</link><generator>RSS for Node</generator><lastBuildDate>Tue, 29 Sep 2026 00:55:35 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/3156.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 28 Sep 2026 16:08:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How does rollback work for FusionAuth Cloud after a major version upgrade? on Mon, 28 Sep 2026 16:54:47 GMT]]></title><description><![CDATA[<h2>Rollback Process for FusionAuth Cloud</h2>
<p dir="auto">For FusionAuth Cloud deployments, the rollback process must be handled by FusionAuth support—it is not something you can perform yourself.</p>
<h3>Plan Eligibility and Backup Retention</h3>
<li><strong>Business and High Availability (HA) Deployments</strong>: Upgrade backups are retained and available for <strong>30 days</strong></li>
<li><strong>Basic Deployments</strong>: Backups are not included, so rollbacks cannot be performed</li>
<h3>How to Request a Rollback</h3>
<p dir="auto">If you identify an issue after performing the upgrade:</p>
<li>Open a support ticket with FusionAuth</li>
<li>The support team will perform the complete database rollback for you</li>
<h3>Expected Downtime</h3>
<p dir="auto">The rollback operation typically takes <strong>20 minutes to 2 hours</strong>, depending on:</p>
<li>Database size</li>
<li>How quickly the operations team can complete the rollback</li>
<p dir="auto">Note that this involves a complete database rollback, so plan for 1-2 hours of downtime.</p>
<h3>Support During Upgrades</h3>
<p dir="auto">For production upgrades, FusionAuth can provide:</p>
<li>An engineer on standby during your scheduled upgrade window</li>
<li>An on-call support number for emergency assistance</li>
<h3>Pre-Upgrade Best Practices</h3>
<p dir="auto">Before upgrading to 1.69.1:</p>
<li><strong>Review Release Notes</strong> for breaking changes, database migrations, and API modifications</li>
<li><strong>Choose an Upgrade Strategy</strong>:
<li>Incremental (version-by-version) for lower risk</li>
<li>Direct upgrade for speed (but requires thorough testing)</li>
<li><strong>Test in Staging</strong> to verify:
<li>Authentication flows, webhooks, and APIs function correctly</li>
<li>Templates render properly</li>
<li>Database migrations complete successfully</li>
<li><strong>Coordinate with Support</strong> to schedule the upgrade and have assistance available if needed</li>
]]></description><link>https://fusionauth.io/community/forum/post/8650</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8650</guid><dc:creator><![CDATA[FASupportBot]]></dc:creator><pubDate>Mon, 28 Sep 2026 16:54:47 GMT</pubDate></item></channel></rss>
