<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Will upgrading FusionAuth invalidate user tokens and force re-login?]]></title><description><![CDATA[<p dir="auto">When planning a FusionAuth upgrade, will existing user sessions and tokens be invalidated, requiring users to log back in?</p>
<p dir="auto">Specifically:</p>
<li>Are tokens automatically invalidated during the upgrade process?</li>
<li>Will users experience forced logouts?</li>
<li>What should be considered when planning the upgrade to minimize user impact?</li>
]]></description><link>https://fusionauth.io/community/forum/topic/3204/will-upgrading-fusionauth-invalidate-user-tokens-and-force-re-login</link><generator>RSS for Node</generator><lastBuildDate>Mon, 19 Oct 2026 07:10:39 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/3204.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 02 Oct 2026 23:54:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Will upgrading FusionAuth invalidate user tokens and force re-login? on Fri, 02 Oct 2026 23:54:15 GMT]]></title><description><![CDATA[<p dir="auto"><strong>Usually no</strong> — FusionAuth upgrades do not log users out or invalidate tokens.</p>
<p dir="auto">However, there is <strong>one important exception</strong>: if your upgrade path includes <strong>v1.60.0</strong>, some tokens may be invalidated due to changes in token structure. The specific changes are deterministic and documented in the release notes:</p>
<li><a href="https://fusionauth.io/docs/release-notes#version-1-60-0" rel="nofollow ugc">FusionAuth 1.60.0 Release Notes</a></li>
<p dir="auto">Even when tokens are invalidated in v1.60.0, <strong>users with a valid refresh token should self-heal without needing to manually log in again</strong>.</p>
<p dir="auto">Additionally, if your upgrade path includes <strong>v1.69.0</strong>, be aware of changes to key management that may require attention. Review the migration guide:</p>
<li><a href="https://fusionauth.io/docs/operate/troubleshooting/1-69-0-migration-guide" rel="nofollow ugc">1.69.0 Migration Guide</a></li>
<p dir="auto"><strong>Recommendation</strong>: Review the release notes for any versions in your upgrade path to understand specific token behavior changes and plan accordingly.</p>
]]></description><link>https://fusionauth.io/community/forum/post/8745</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8745</guid><dc:creator><![CDATA[FASupportBot]]></dc:creator><pubDate>Fri, 02 Oct 2026 23:54:15 GMT</pubDate></item></channel></rss>
