<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Mobile SDK options]]></title><description><![CDATA[<p dir="auto">What are the SDK options for Mobile development using FusionAuth?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/323/mobile-sdk-options</link><generator>RSS for Node</generator><lastBuildDate>Fri, 06 Nov 2026 13:45:11 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/323.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 24 Aug 2020 15:47:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Mobile SDK options on Mon, 24 Aug 2020 15:52:18 GMT]]></title><description><![CDATA[<p dir="auto">The mobile app really shouldn’t be calling FusionAuth APIs. You should be using your backend to call FusionAuth. Usually, this is a proxy style setup, as outlined in this post about <a href="https://fusionauth.io/blog/2020/03/10/securely-implement-oauth-in-react" rel="nofollow ugc">OAuth and React</a>. This will work for both OAuth and regular API calls.</p>
<p dir="auto">If you really want the mobile app to call the OAuth flow directly, make sure you follow the best practices from RFC 8252 (use the browser, not an embedded webview). Here's a <a href="https://fusionauth.io/blog/2020/08/19/securing-react-native-with-oauth" rel="nofollow ugc">React Native tutorial</a> that you can adapt.</p>
]]></description><link>https://fusionauth.io/community/forum/post/935</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/935</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Mon, 24 Aug 2020 15:52:18 GMT</pubDate></item></channel></rss>
