<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How do I submit a custom password hasher plugin JAR for FusionAuth Cloud?]]></title><description><![CDATA[<p dir="auto">I'm trying to deploy a custom password hasher plugin to our FusionAuth Cloud instance following the documentation at <a href="https://fusionauth.io/docs/extend/code/password-hashes/writing-a-plugin#installing-on-fusionauth-cloud" rel="nofollow ugc">deploying a custom password hasher</a>.</p>
<p dir="auto">The documentation says to open a support ticket and include the JAR file. However, when I navigate to the support ticket creation page at the account portal, I only see text input fields — there's no option to attach files.</p>
<p dir="auto">How should I provide the plugin JAR file when requesting it to be installed on our Cloud deployment?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/3238/how-do-i-submit-a-custom-password-hasher-plugin-jar-for-fusionauth-cloud</link><generator>RSS for Node</generator><lastBuildDate>Wed, 14 Oct 2026 00:33:41 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/3238.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 08 Oct 2026 17:03:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How do I submit a custom password hasher plugin JAR for FusionAuth Cloud? on Thu, 08 Oct 2026 17:03:30 GMT]]></title><description><![CDATA[<p dir="auto">When submitting a custom password hasher plugin (or any plugin JAR) for installation on FusionAuth Cloud, you should:</p>
<li>Open a support ticket through the account portal as normal (text-only is fine)</li>
<li>Reply to the ticket conversation in <strong>Slack</strong> with the plugin JAR file attached</li>
<p dir="auto">The account portal does not accept file attachments during ticket creation, but replying via Slack to an open ticket thread allows you to send files directly to the support team.</p>
<p dir="auto"><strong>Note:</strong> Some file-sharing platforms (like Slack) may block <code>.jar</code> files for security reasons. If this happens, you can zip the JAR file first and attach the <code>.zip</code> instead.</p>
<h2>Installation considerations</h2>
<p dir="auto">When requesting plugin installation, be sure to specify:</p>
<li>Which specific Cloud deployments/tenants need the plugin installed</li>
<li>Whether users are actively logging in (there may be 1-2 minutes of downtime during deployment)</li>
<li>Your preferred time window for the installation if downtime is a concern</li>
<li>Any considerations for dev/test environments if you have ongoing testing</li>
<p dir="auto">The support team will handle uploading and rolling the deployment with the new plugin.</p>
]]></description><link>https://fusionauth.io/community/forum/post/8813</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8813</guid><dc:creator><![CDATA[FASupportBot]]></dc:creator><pubDate>Thu, 08 Oct 2026 17:03:30 GMT</pubDate></item></channel></rss>
