<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to get base theme files for advanced theme upgrade without local install?]]></title><description><![CDATA[<p dir="auto">When upgrading FusionAuth with advanced themes, the <a href="https://fusionauth.io/docs/theme/advanced-themes/upgrade-advanced-theme" rel="nofollow ugc">upgrade documentation</a> recommends installing the new version locally via Docker to get the base theme files.</p>
<p dir="auto">I'm using the FusionAuth theme-helper repo and want to run the <code>download.sh</code> script to get the latest default theme files for diffing against my customized theme.</p>
<p dir="auto">Are these my only options?</p>
<li>Install the new FusionAuth version locally via Docker and pull the theme from that fresh install</li>
<li>Pull theme files directly from the <code>fusionauth-theme-history</code> GitHub repository</li>
<p dir="auto">Is there a simpler way to get the base theme files for a specific version without doing a fresh local install?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/3241/how-to-get-base-theme-files-for-advanced-theme-upgrade-without-local-install</link><generator>RSS for Node</generator><lastBuildDate>Wed, 14 Oct 2026 01:26:13 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/3241.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 09 Oct 2026 15:01:50 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to get base theme files for advanced theme upgrade without local install? on Fri, 09 Oct 2026 15:02:01 GMT]]></title><description><![CDATA[<p dir="auto">You can avoid the fresh local install by pulling the theme files directly from the <strong>fusionauth-theme-history</strong> repository:</p>
<p dir="auto"><a href="https://github.com/FusionAuth/fusionauth-theme-history/tree/main" rel="nofollow ugc">github.com/FusionAuth/fusionauth-theme-history/tree/main</a></p>
<p dir="auto">To use this with the theme-helper repo:</p>
<li>Download your current customized theme using <code>download.sh</code> from the theme-helper repo</li>
<li>Grab the new target version's theme files from <code>fusionauth-theme-history</code></li>
<li>Run <code>diff-themes.sh</code> from theme-helper against the two folders to see what changed</li>
<p dir="auto">This approach lets you diff your customized theme against the base theme for any FusionAuth version without needing to spin up a local FusionAuth instance.</p>
<p dir="auto"><strong>Alternative approaches:</strong></p>
<p dir="auto">If you prefer working directly with git, you can clone the theme-history repo and use git's built-in diffing. For example, to generate a patch between two versions:</p>
<pre><code class="language-bash">git format-patch 1.61.0..1.64.1 --stdout &gt; update-themes.patch
<p dir="auto">Then apply it to your theme repository:</p>
<pre><code class="language-bash">git am --3way update-themes.patch
<p dir="auto">You can also use GitHub's built-in diff viewer to compare themes across versions directly in your browser.</p>
<li><a href="https://fusionauth.io/docs/customize/look-and-feel/advanced-themes/upgrade-advanced-theme" rel="nofollow ugc">Upgrade an Advanced Theme</a> - Complete guide for upgrading custom themes</li>
<li><a href="https://fusionauth.io/docs/customize/look-and-feel/advanced-themes/upgrade-advanced-theme#theme-history-repository" rel="nofollow ugc">Theme History Repository</a> - Official documentation on using the fusionauth-theme-history repo (available back to version 1.23.0)</li>
<li><a href="https://fusionauth.io/docs/customize/look-and-feel/advanced-themes/upgrade-advanced-theme#theme-helper" rel="nofollow ugc">Theme Helper</a> - Documentation for the fusionauth-theme-helper tool</li>
<li><a href="https://fusionauth.io/docs/customize/look-and-feel/advanced-themes/upgrade" rel="nofollow ugc">Advanced Theme Upgrade Notes</a> - Version-specific upgrade requirements and breaking changes</li>
<li><a href="https://fusionauth.io/docs/apis/themes" rel="nofollow ugc">Themes API</a> - API reference for programmatically retrieving theme files</li>
]]></description><link>https://fusionauth.io/community/forum/post/8819</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8819</guid><dc:creator><![CDATA[FASupportBot]]></dc:creator><pubDate>Fri, 09 Oct 2026 15:02:01 GMT</pubDate></item></channel></rss>
