<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Upgrade from 1.62.0 to 1.69.2 fails to authorize &#x2F;oauth2&#x2F;token requests with a 400]]></title><description><![CDATA[<p dir="auto">We have two development instances of Cloud FusionAuth (dev and staging).<br />
We upgraded and tested in dev from 1.62.0 to 1.69.2.<br />
After upgrade in staging from 1.62.0 to 1.69.2, users cannot login using SSO. I cannot determine why the staging instance is failing the SSO login process, when the dev instance continues to work.<br />
It appears our call to https://{instanceName}/oauth2/token with {client_id, client_secret, code, grant_type, and redirec_uri} returns a 400 bad request error.<br />
I cannot identify the difference between the two instances.</p>
]]></description><link>https://fusionauth.io/community/forum/topic/3242/upgrade-from-1-62-0-to-1-69-2-fails-to-authorize-oauth2-token-requests-with-a-400</link><generator>RSS for Node</generator><lastBuildDate>Fri, 09 Oct 2026 23:17:27 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/3242.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 29 Sep 2026 19:13:14 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Upgrade from 1.62.0 to 1.69.2 fails to authorize &#x2F;oauth2&#x2F;token requests with a 400 on Fri, 09 Oct 2026 15:18:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/3876">@chatteberg</a> I just saw your post. If you have a paid support plan you can <a href="https://account.fusionauth.io/account/support/" rel="nofollow ugc">open a ticket</a>. If you do not have a paid support plan, are you still experiencing the issue?</p>
]]></description><link>https://fusionauth.io/community/forum/post/8821</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8821</guid><dc:creator><![CDATA[mark.robustelli]]></dc:creator><pubDate>Fri, 09 Oct 2026 15:18:09 GMT</pubDate></item></channel></rss>
