<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can I customize HTTP security headers (HSTS, CSP, etc.) on FusionAuth Cloud?]]></title><description><![CDATA[<p dir="auto">I'm running a security scan against our FusionAuth Cloud tenant and found several HTTP security header issues:</p>
<li><code>Strict-Transport-Security</code> is present but has <code>max-age=300</code> (5 minutes), which is far below the 1-year minimum (31536000 seconds) required for HSTS preload to take effect</li>
<li><code>Content-Security-Policy</code> header is not being sent</li>
<li><code>X-Content-Type-Options</code> header is not being sent</li>
<li><code>Referrer-Policy</code> header is not being sent</li>
<p dir="auto">Is there a way to configure or customize these security headers for a FusionAuth Cloud tenant? Ideally I'd like to set <code>Strict-Transport-Security: max-age=31536000; includeSubDomains; preload</code> and add the missing security headers.</p>
]]></description><link>https://fusionauth.io/community/forum/topic/3251/can-i-customize-http-security-headers-hsts-csp-etc-on-fusionauth-cloud</link><generator>RSS for Node</generator><lastBuildDate>Fri, 16 Oct 2026 14:19:45 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/3251.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 13 Oct 2026 18:50:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can I customize HTTP security headers (HSTS, CSP, etc.) on FusionAuth Cloud? on Fri, 16 Oct 2026 11:35:53 GMT]]></title><description><![CDATA[<p dir="auto">At this time, FusionAuth Cloud does not support customizing HTTP security headers on individual tenant deployments. There is an existing <a href="https://github.com/FusionAuth/fusionauth-issues/issues/1510" rel="nofollow ugc">GitHub feature request</a> tracking this capability, but it is not currently on the roadmap and no ETA is available for when this might be added.</p>
<p dir="auto">If you are running a self-hosted FusionAuth instance, you can configure these headers using a reverse proxy (nginx, Apache, etc.) in front of FusionAuth. For FusionAuth Cloud customers, this configuration is managed at the infrastructure level and cannot be modified per-tenant.</p>
<p dir="auto">You may want to subscribe to or comment on the relevant GitHub issue to track progress on this feature request.</p>
]]></description><link>https://fusionauth.io/community/forum/post/8839</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8839</guid><dc:creator><![CDATA[FASupportBot]]></dc:creator><pubDate>Fri, 16 Oct 2026 11:35:53 GMT</pubDate></item></channel></rss>
