<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Is there a Helm chart release for FusionAuth 1.53.4?]]></title><description><![CDATA[<p dir="auto">I'm looking to upgrade to FusionAuth 1.53.4 using Helm, but I don't see a corresponding chart version in the <a href="https://github.com/FusionAuth/charts/tags" rel="nofollow ugc">FusionAuth charts repository</a>.</p>
<p dir="auto">Is a Helm chart release for version 1.53.4 expected soon? I'd like to deploy this version today.</p>
<p dir="auto">I understand I can specify the Docker image version directly in the Helm values, but I typically track <code>helm chart version == image version</code> for FusionAuth deployments.</p>
]]></description><link>https://fusionauth.io/community/forum/topic/3264/is-there-a-helm-chart-release-for-fusionauth-1-53-4</link><generator>RSS for Node</generator><lastBuildDate>Fri, 16 Oct 2026 14:21:22 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/3264.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 15 Oct 2026 15:33:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Is there a Helm chart release for FusionAuth 1.53.4? on Thu, 15 Oct 2026 15:33:32 GMT]]></title><description><![CDATA[<p dir="auto">The Helm chart for FusionAuth 1.53.4 has been released and should now be available in the <a href="https://github.com/FusionAuth/charts/tags" rel="nofollow ugc">FusionAuth charts repository</a>.</p>
<p dir="auto">In the meantime, if you need to deploy a specific FusionAuth version before the corresponding Helm chart is released, you can override the image tag in your Helm values file:</p>
<pre><code class="language-yaml">image:
  tag: "1.53.4"
<p dir="auto">This allows you to use the latest Helm chart while specifying the exact FusionAuth Docker image version you need.</p>
<li><a href="https://fusionauth.io/docs/get-started/download-and-install/kubernetes/fusionauth-deployment#helm-chart-configuration" rel="nofollow ugc">Deploy with Kubernetes - Helm Chart Configuration</a> - Complete guide on configuring and deploying FusionAuth using Helm charts</li>
<li><a href="https://fusionauth.io/docs/get-started/download-and-install/kubernetes/fusionauth-deployment#deploy-fusionauth-to-the-cluster" rel="nofollow ugc">Deploy FusionAuth to the Cluster</a> - Instructions for installing and verifying your Helm deployment</li>
<li><a href="https://fusionauth.io/docs/get-started/download-and-install/kubernetes/" rel="nofollow ugc">Kubernetes Overview</a> - Overview of FusionAuth on Kubernetes with architecture diagrams</li>
<li><a href="https://fusionauth.io/docs/operate/deploy/upgrade" rel="nofollow ugc">Upgrade FusionAuth</a> - General guidance on upgrading FusionAuth installations</li>
<p dir="auto">When you override the image tag in your <code>values.yaml</code> file, you can verify the correct version is deployed by checking the IMAGES column in your Kubernetes deployment:</p>
<pre><code class="language-bash">kubectl get deployments -o wide
]]></description><link>https://fusionauth.io/community/forum/post/8865</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8865</guid><dc:creator><![CDATA[FASupportBot]]></dc:creator><pubDate>Thu, 15 Oct 2026 15:33:32 GMT</pubDate></item></channel></rss>
