<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Is the user&#x2F;registration endpoint safe for concurrent calls?]]></title><description><![CDATA[<p dir="auto">I need to register a user across multiple applications (8 in my case) using the <code>/api/user/registration</code> endpoint. To improve performance, I'd like to make these calls in parallel rather than sequentially.</p>
<p dir="auto"><strong>Question:</strong> Is it safe to call the <code>user/registration</code> endpoint concurrently for the same user across different applications? Could this cause:</p>
<li>Race conditions with the database</li>
<li>Duplicate records</li>
<li>Conflicting updates to the user object</li>
<p dir="auto">Or should I stick with sequential calls to avoid potential issues?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/3273/is-the-user-registration-endpoint-safe-for-concurrent-calls</link><generator>RSS for Node</generator><lastBuildDate>Tue, 27 Oct 2026 16:07:19 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/3273.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 20 Oct 2026 21:05:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Is the user&#x2F;registration endpoint safe for concurrent calls? on Mon, 26 Oct 2026 22:51:53 GMT]]></title><description><![CDATA[<p dir="auto">The <code>/api/user/registration</code> endpoint can be problematic when called concurrently for the same user. <strong>FusionAuth recommends using sequential calls</strong>.</p>
<p dir="auto"><strong>Recommendation:</strong> Make your registration calls sequentially, one after another, even though it may take slightly longer. This ensures data consistency and avoids potential conflicts or failures during the registration process.</p>
<p dir="auto">There is currently no single API call to atomically register a user to multiple applications. Each registration to an application requires a separate API call, and sequential execution is the safest approach.</p>
<li><a href="https://fusionauth.io/docs/apis/registrations/" rel="nofollow ugc">User Registration API</a> - Overview of the registration API and available operations</li>
<li><a href="https://fusionauth.io/docs/apis/registrations/create-a-user-registration-for-an-existing-user" rel="nofollow ugc">Create a User Registration (for an existing user)</a> - API documentation for creating registrations</li>
<li><a href="https://fusionauth.io/docs/get-started/core-concepts/registrations" rel="nofollow ugc">Registrations Core Concept</a> - Understanding the relationship between Users and Applications</li>
<li><a href="https://fusionauth.io/docs/get-started/core-concepts/applications" rel="nofollow ugc">Applications</a> - Core concepts about Applications in FusionAuth</li>
<li><a href="https://fusionauth.io/community/forum/topic/238/registering-a-user-to-other-applications-during-registration">Registering a user to other applications during registration</a> - Community discussion on this topic</li>
]]></description><link>https://fusionauth.io/community/forum/post/8885</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8885</guid><dc:creator><![CDATA[FASupportBot]]></dc:creator><pubDate>Mon, 26 Oct 2026 22:51:53 GMT</pubDate></item></channel></rss>
