<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Data analysis of login&#x2F;user data from FusionAuth]]></title><description><![CDATA[<p dir="auto">Our data team has enjoyed lots of data points and insights from our existing auth solution. Specifically around users, data like:</p>
<li>sign in type (Apple login, Google login, phone number, emails)</li>
<li>MFA enabled/disabled</li>
<li>what kind of MFA</li>
<li>registration info</li>
<p dir="auto">We have data pipelines set up to ingest and turn this data into meaningful insights for the business.</p>
<p dir="auto">We want to make sure we maintain these important insights. How can we do this?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/3278/data-analysis-of-login-user-data-from-fusionauth</link><generator>RSS for Node</generator><lastBuildDate>Thu, 22 Oct 2026 21:36:20 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/3278.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 22 Oct 2026 15:59:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Data analysis of login&#x2F;user data from FusionAuth on Thu, 22 Oct 2026 16:06:09 GMT]]></title><description><![CDATA[<p dir="auto">You want to use FusionAuth webhooks to push data into your pipelines. I imagine the JSON will differ, so you might need to modify your mapping layer, but we should be able to provide the data you expect.</p>
<p dir="auto">Here's our <a href="https://fusionauth.io/docs/extend/events-and-webhooks/" rel="nofollow ugc">general webhook documentation</a>.</p>
<p dir="auto">Some events you might be interested in:</p>
<li><a href="https://fusionauth.io/docs/extend/events-and-webhooks/events/user/login/user-login-success" rel="nofollow ugc">User login success</a> which includes the authentication method</li>
<li><a href="https://fusionauth.io/docs/extend/events-and-webhooks/events/user/login/user-login-failed" rel="nofollow ugc">User login failure</a></li>
<li><a href="https://fusionauth.io/docs/extend/events-and-webhooks/events/user/user-two-factor-method-add" rel="nofollow ugc">Two factor method added</a></li>
<li><a href="https://fusionauth.io/docs/extend/events-and-webhooks/events/user/user-create-complete" rel="nofollow ugc">User create</a></li>
<p dir="auto">Where possible, avoid transactional webhooks because you're using this for analytics and transactional webhooks impact workflow duration negatively.</p>
<p dir="auto">You can also use the <a href="https://fusionauth.io/docs/lifecycle/manage-users/search/user-search-with-elasticsearch" rel="nofollow ugc">Search API</a> to get adhoc counts/true things up, but it won't necessarily have the richness of data of the webhooks.</p>
]]></description><link>https://fusionauth.io/community/forum/post/8895</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8895</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Thu, 22 Oct 2026 16:06:09 GMT</pubDate></item></channel></rss>
