<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[403 calling Hosted Backend &#x2F;app&#x2F;refresh API]]></title><description><![CDATA[<p dir="auto">I'm trying to use the Hosted Backend /app/refresh API to manually refresh tokens using a valid refresh token (obtained from an external JWT reconcile call).</p>
<p dir="auto">Using Curl as follows (sensitive values xxxx'ed out):</p>
<p dir="auto">curl -v -X POST --cookie "app.rt=_xxxxx" <a href="http://localhost:9011/app/xxxxx" rel="nofollow ugc">http://localhost:9011/app/xxxxx</a></p>
<p dir="auto">returns a 403 even though the rt and application client id are correct.</p>
<p dir="auto">Any idea why this is happening?  Running licensed starter edition, v1.69.4 locally on port 9011.</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://fusionauth.io/community/forum/topic/3294/403-calling-hosted-backend-app-refresh-api</link><generator>RSS for Node</generator><lastBuildDate>Sat, 31 Oct 2026 03:47:21 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/3294.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 28 Oct 2026 16:47:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 403 calling Hosted Backend &#x2F;app&#x2F;refresh API on Fri, 30 Oct 2026 20:36:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/3893">@andrzej-taramina</a> Usually, when we see 403s on the hosted backend, the root cause ends up being an origin issue.</p>
<p dir="auto">The endpoint calls need to originate from the same domain the FusionAuth instance lives at</p>
<p dir="auto">There's some CORS information in this section of the hosted backend docs: <a href="https://fusionauth.io/docs/apis/hosted-backend#prerequisites" rel="nofollow ugc">https://fusionauth.io/docs/apis/hosted-backend#prerequisites</a></p>
]]></description><link>https://fusionauth.io/community/forum/post/8957</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8957</guid><dc:creator><![CDATA[bryan.robinson]]></dc:creator><pubDate>Fri, 30 Oct 2026 20:36:03 GMT</pubDate></item></channel></rss>
