<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can you move users from one tenant to another?]]></title><description><![CDATA[<p dir="auto">Is there a way to move a user from one tenant to another? Or do we have to delete and re-import?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/33/can-you-move-users-from-one-tenant-to-another</link><generator>RSS for Node</generator><lastBuildDate>Tue, 10 Nov 2026 15:15:12 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/33.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 28 Apr 2020 17:30:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can you move users from one tenant to another? on Fri, 25 Oct 2024 13:39:43 GMT]]></title><description><![CDATA[<p dir="auto">Another option that works as of today is to set up a tenant to tenant connector.</p>
<p dir="auto">Add a connector to the new tenant. Point it at the /api/login endpoint of the old tenant, including an API key as a header.</p>
<p dir="auto">Change your app to send everyone to a new application in the new tenant.</p>
<p dir="auto">When the user logs in to the new application, if it is the first time they've been seen, the old tenant data, including password, will be queried. The password hash will be transparently migrated to the new tenant.</p>
<p dir="auto">This slow migration takes time, but is another option.</p>
]]></description><link>https://fusionauth.io/community/forum/post/7584</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/7584</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Fri, 25 Oct 2024 13:39:43 GMT</pubDate></item><item><title><![CDATA[Reply to Can you move users from one tenant to another? on Mon, 17 Jan 2022 17:12:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/1332">@dwong</a></p>
<p dir="auto">FusionAuth is API first, so this type of flow could be created using our API and custom integration code.</p>
<p dir="auto">Roughly:</p>
<li>On tenant B, a user from tenant A logs in.</li>
<li>Do a search for a user</li>
<li>If found, do a registration and/or user create using API.</li>
<li>The newly created user can now be logged in.  As referenced above, you may have some interstitial pages that would be needed for password generation as the user passes from one tenant to another.</li>
<p dir="auto">Another way to do this would be to reconsider how you are using tenants and applications.  Depending on your business requirements, registering a user to a new application rather than a completely separate tenant removes a few steps from a workflow as described.</p>
<p dir="auto">Reference documentation -&gt; <a href="https://fusionauth.io/docs/v1/tech/apis/" rel="nofollow ugc">https://fusionauth.io/docs/v1/tech/apis/</a></p>
<p dir="auto">Thanks,<br />
Josh</p>
]]></description><link>https://fusionauth.io/community/forum/post/4204</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/4204</guid><dc:creator><![CDATA[joshua]]></dc:creator><pubDate>Mon, 17 Jan 2022 17:12:20 GMT</pubDate></item><item><title><![CDATA[Reply to Can you move users from one tenant to another? on Fri, 14 Jan 2022 16:00:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/20">@dan</a> Could a rule be set up such that if an already-provisioned user (e.g. <a href="mailto:johndoe@abc.com" rel="nofollow ugc">johndoe@abc.com</a>) from tenant A which logs into tenant B can perform a custom backend query that finds that user on tenant A, automatically lazy-import them into B, and finally provide successful login?</p>
<p dir="auto">I wish to use multitenancy for custom login experience across tenants, but I don't necessarily care that the credentials for that email address are different.</p>
]]></description><link>https://fusionauth.io/community/forum/post/4194</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/4194</guid><dc:creator><![CDATA[dwong]]></dc:creator><pubDate>Fri, 14 Jan 2022 16:00:09 GMT</pubDate></item><item><title><![CDATA[Reply to Can you move users from one tenant to another? on Tue, 16 Feb 2021 02:59:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="mention plugin-mentions-user plugin-mentions-a" href="https://fusionauth.io/community/forum/uid/38">@rnsupercool</a></p>
<p dir="auto">Unfortunately, there's no way to extract the password and the other information via the APIs.</p>
<p dir="auto">Options I could see working:</p>
<li>if you have developer edition (or other paid edition), you could set up a connector from FusionAuth to itself (via a <a href="https://fusionauth.io/docs/v1/tech/connectors/generic-connector/" rel="nofollow ugc">generic http connector</a>). This would take time to move the users to a different tenant.</li>
<li>you can get a database dump of your FusionAuth instance and run a <a href="https://fusionauth.io/docs/v1/tech/apis/users/#import-users" rel="nofollow ugc">bulk import</a> of the user data, password, and other password settings into another tenant.</li>
<li>you could move over the users, set a random password and force them to change their password by setting <code>passwordChangeRequired</code>. Not sure that would definitely work; you should test this.</li>
<p dir="auto">Hope this helps.</p>
]]></description><link>https://fusionauth.io/community/forum/post/2413</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2413</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Tue, 16 Feb 2021 02:59:58 GMT</pubDate></item><item><title><![CDATA[Reply to Can you move users from one tenant to another? on Tue, 16 Feb 2021 02:30:25 GMT]]></title><description><![CDATA[<p dir="auto">How do you retrieve the whole user with password and other information? Is there any api available for the same?</p>
Lohith</p>
]]></description><link>https://fusionauth.io/community/forum/post/2412</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/2412</guid><dc:creator><![CDATA[rnsupercool]]></dc:creator><pubDate>Tue, 16 Feb 2021 02:30:25 GMT</pubDate></item><item><title><![CDATA[Reply to Can you move users from one tenant to another? on Tue, 28 Apr 2020 17:30:54 GMT]]></title><description><![CDATA[<p dir="auto">No, a user cannot be moved between tenants in the admin user interface. You could do this via the API with a retrieve and a create in a small program, though.</p>
]]></description><link>https://fusionauth.io/community/forum/post/72</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/72</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Tue, 28 Apr 2020 17:30:54 GMT</pubDate></item></channel></rss>
