<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to redirect users from FusionAuth 404 error page?]]></title><description><![CDATA[<p dir="auto">Users are frequently landing on FusionAuth's 404 error page. Is there a way to customize the 404 page via themes to automatically redirect users to another page, or what are the recommended approaches to handle this situation?</p>
]]></description><link>https://fusionauth.io/community/forum/topic/3304/how-to-redirect-users-from-fusionauth-404-error-page</link><generator>RSS for Node</generator><lastBuildDate>Tue, 03 Nov 2026 20:31:09 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/3304.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 30 Oct 2026 17:48:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to redirect users from FusionAuth 404 error page? on Tue, 03 Nov 2026 15:02:31 GMT]]></title><description><![CDATA[<p dir="auto">Unfortunately, there is no built-in way to customize the 404 page via FusionAuth themes to force a redirect. The standard theme editor does not include a template for the 404 error page, and this functionality is not currently supported.</p>
<p dir="auto">The recommended approach is to:</p>
<p dir="auto"><strong>Investigate the root cause</strong>: Try to determine what circumstances are causing users to hit the 404 page. If you can replicate the issue, identifying the source will help prevent it from occurring.</p>
<p dir="auto"><strong>Use a reverse proxy</strong>: If you need to redirect users away from the 404 page, the recommended solution is to set up a reverse proxy (such as nginx, Apache, or similar) in front of FusionAuth that can intercept 404 responses and redirect users to an appropriate page. For example, with nginx, you can use the <code>proxy_intercept_errors</code> directive to handle error responses.</p>
<p dir="auto">It's generally better to address why users are reaching the 404 page rather than simply redirecting them away from it, as this may indicate an underlying issue with URL construction, deep linking, or session handling in your application.</p>
<li><a href="https://fusionauth.io/docs/customize/look-and-feel/advanced-themes/" rel="nofollow ugc">Themes Overview</a> - Learn about FusionAuth's theme customization capabilities</li>
<li><a href="https://fusionauth.io/docs/operate/troubleshooting/#troubleshooting-proxies" rel="nofollow ugc">Troubleshooting Proxies</a> - Important guidance when using FusionAuth behind a reverse proxy</li>
<li><a href="https://fusionauth.io/community/forum/topic/119/404-page-theme">404 Page Theme Forum Discussion</a> - Community discussion confirming this limitation</li>
<li><a href="https://github.com/FusionAuth/fusionauth-issues/issues/404" rel="nofollow ugc">GitHub Issue #404</a> - Feature request for customizable error pages (consider upvoting if this is important to you)</li>
]]></description><link>https://fusionauth.io/community/forum/post/8945</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/8945</guid><dc:creator><![CDATA[FASupportBot]]></dc:creator><pubDate>Tue, 03 Nov 2026 15:02:31 GMT</pubDate></item></channel></rss>
