<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How are FusionAuth Cloud deployments sorted in the account portal?]]></title><description><![CDATA[<p dir="auto">When viewing deployments at <a href="https://account.fusionauth.io/account/deployment/" rel="nofollow ugc">account.fusionauth.io/account/deployment</a>, the sort order appears inconsistent or random.</p>
<p dir="auto">This becomes problematic when managing multiple deployments for different products or environments, as it's easy to accidentally select the wrong instance.</p>
<p dir="auto">Is there a current sorting mechanism for deployments in the account portal? It would be helpful to have deployments sorted alphabetically by name or URL to prevent accidental misclicks when working with multiple instances.</p>
]]></description><link>https://fusionauth.io/community/forum/topic/3341/how-are-fusionauth-cloud-deployments-sorted-in-the-account-portal</link><generator>RSS for Node</generator><lastBuildDate>Fri, 06 Nov 2026 18:40:06 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/3341.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 03 Nov 2026 23:12:31 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How are FusionAuth Cloud deployments sorted in the account portal? on Tue, 03 Nov 2026 23:12:41 GMT]]></title><description><![CDATA[<p dir="auto">Currently, there is <strong>no sorting logic</strong> implemented for deployments in the FusionAuth Cloud account portal. The order of deployments is not sorted alphabetically or by any other consistent criteria at this time.</p>
<p dir="auto">This has been noted as a feature request to add sorting capabilities (or the ability to manually sort) deployments in the account portal. This would help prevent accidental selection of the wrong instance when managing multiple FusionAuth Cloud deployments.</p>
<p dir="auto">In the meantime, extra care should be taken when selecting deployments from the list to ensure you're working with the correct instance. You can use the <strong>Rename</strong> feature (available in the <strong>Action</strong> dropdown menu for each deployment) to give your deployments descriptive names that help distinguish between different products or environments.</p>
<li><a href="https://fusionauth.io/docs/get-started/run-in-the-cloud/cloud#managing-your-deployments" rel="nofollow ugc">Managing Your Deployments</a> - Overview of managing FusionAuth Cloud deployments in the account portal</li>
<li><a href="https://fusionauth.io/docs/get-started/run-in-the-cloud/cloud#the-account-portal" rel="nofollow ugc">The Account Portal</a> - Documentation on accessing and using the account portal</li>
<li><a href="https://fusionauth.io/docs/get-started/download-and-install/reference/account-portal" rel="nofollow ugc">FusionAuth Account Portal Reference</a> - Complete reference for the FusionAuth account portal features</li>
]]></description><link>https://fusionauth.io/community/forum/post/9022</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/9022</guid><dc:creator><![CDATA[FASupportBot]]></dc:creator><pubDate>Tue, 03 Nov 2026 23:12:41 GMT</pubDate></item></channel></rss>
