<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Why is &#96;act&#96; claim now reserved in 1.70.0? Lambda silently fails with no warning]]></title><description><![CDATA[<p dir="auto">After upgrading to FusionAuth 1.70.0, a JWT populate lambda that was previously setting the <code>act</code> claim now silently fails. The lambda executes successfully, but the <code>act</code> claim is discarded without any warning or error log.</p>
<p dir="auto">The application had been using <code>act</code> to represent the actor while maintaining internal user IDs (since <code>sub</code> cannot be overridden). This worked fine in earlier versions, but after upgrading to 1.70.0, the claim is no longer present in the JWT, breaking authentication.</p>
<li>Why was <code>act</code> made a reserved claim in 1.70.0?</li>
<li>Is there any way to override reserved claims or disable this behavior?</li>
<li>Why is there no warning log when FusionAuth discards a reserved claim set by a lambda?</li>
<li>How is this considered a <em>minor</em> change rather than a <em>breaking</em> change when it silently breaks existing implementations?</li>
<p dir="auto">This pattern seems risky — any claim name in use today could become reserved in a future RFC, causing working implementations to fail after an upgrade with no visibility into what changed.</p>
]]></description><link>https://fusionauth.io/community/forum/topic/3357/why-is-act-claim-now-reserved-in-1-70-0-lambda-silently-fails-with-no-warning</link><generator>RSS for Node</generator><lastBuildDate>Thu, 12 Nov 2026 13:36:50 GMT</lastBuildDate><atom:link href="https://fusionauth.io/community/forum/topic/3357.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 10 Nov 2026 19:25:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Why is &#96;act&#96; claim now reserved in 1.70.0? Lambda silently fails with no warning on Thu, 12 Nov 2026 12:23:45 GMT]]></title><description><![CDATA[<p dir="auto">The <code>act</code> claim was reserved in FusionAuth 1.70.0 because it is defined in <a href="https://datatracker.ietf.org/doc/html/rfc8693#section-4.1" rel="nofollow ugc">RFC 8693 (OAuth 2.0 Token Exchange)</a> as a standard claim representing the "actor" in delegated token scenarios. FusionAuth began enforcing this reservation to ensure compliance with the RFC and prevent conflicts with the claim's intended usage in token exchange flows.</p>
<h2>Why This Is Classified as Minor</h2>
<p dir="auto">FusionAuth follows semantic versioning, and this change was classified as <em>minor</em> rather than <em>breaking</em> because:</p>
<li>The <code>act</code> claim is a <strong>standardized RFC claim</strong> with a specific defined purpose</li>
<li>Using non-standard values in RFC-defined claims can cause interoperability issues with other OAuth/OIDC systems</li>
<li>The change aligns FusionAuth's behavior with industry standards</li>
<p dir="auto">However, the lack of logging when a reserved claim is silently discarded is a valid concern and makes troubleshooting difficult.</p>
<h2>Recommended Solutions</h2>
<h3>1. Use a Custom Claim Namespace</h3>
<p dir="auto">Instead of using <code>act</code> directly, use a namespaced custom claim that won't conflict with RFC-defined claims:</p>
<pre><code class="language-javascript">// In your JWT populate lambda
jwt['https://yourapp.com/actor'] = 'your-actor-id';
<p dir="auto">This approach is standard practice in OAuth/OIDC and prevents future collisions with reserved claims.</p>
<h3>2. Use <code>applicationId</code> or Other Non-Reserved Claims</h3>
<p dir="auto">If the actor represents an application or service account, consider using the built-in <code>applicationId</code> claim or another custom claim that describes your specific use case (e.g., <code>actorId</code>, <code>serviceAccountId</code>).</p>
<h2>Why Reserved Claims Cannot Be Overridden</h2>
<p dir="auto">Reserved claims like <code>act</code>, <code>sub</code>, <code>iss</code>, <code>aud</code>, etc., are protected because they have specific meanings defined by RFCs and must maintain consistent behavior for:</p>
<li><strong>Interoperability</strong>: Other systems expect these claims to have specific formats and meanings</li>
<li><strong>Security</strong>: Claims like <code>iss</code> and <code>aud</code> are critical for token validation and cannot be arbitrarily changed</li>
<li><strong>Standards Compliance</strong>: FusionAuth aims to be a standards-compliant identity provider</li>
<h2>Migration Path</h2>
<p dir="auto">If you're currently using <code>act</code> in production:</p>
<li>Update your JWT populate lambda to use a namespaced custom claim</li>
<li>Update your application to read from the new claim name</li>
<li>Test thoroughly in a non-production environment before upgrading</li>
<p dir="auto">If you need to maintain backward compatibility during migration, you could temporarily set both claims in your lambda (the custom namespaced one and attempt to set <code>act</code>, knowing it will be discarded) and update your application to check for both, prioritizing the custom claim.</p>
<hr />
<li><a href="https://fusionauth.io/docs/lambdas/tokens/jwt-populate" rel="nofollow ugc">JWT Populate Lambda</a> - Documentation on customizing JWT claims with lambdas</li>
<li><a href="https://fusionauth.io/docs/lambdas/tokens/client-credentials-jwt-populate" rel="nofollow ugc">Client Credentials JWT Populate Lambda</a> - Documentation for lambdas in the Client Credentials grant</li>
<li><a href="https://fusionauth.io/docs/authorization/token-exchange" rel="nofollow ugc">OAuth Token Exchange (RFC 8693)</a> - FusionAuth's implementation of RFC 8693, which defines the <code>act</code> claim</li>
<li><a href="https://fusionauth.io/docs/release-notes#version-1-70-0" rel="nofollow ugc">FusionAuth 1.70.0 Release Notes</a> - Release notes for version 1.70.0</li>
<li><a href="https://fusionauth.io/blog/announcing-fusionauth-1-70" rel="nofollow ugc">FusionAuth 1.70 Announcement: Token Exchange</a> - Blog post explaining the new token exchange feature and scoped delegation</li>
<li><a href="https://github.com/FusionAuth/fusionauth-issues/issues/1721" rel="nofollow ugc">GitHub Issue #1721: JWT claim overriding, namespacing or the ability to unreserve claims</a> - Open issue discussing the ability to override or unreserve claims</li>
<h2>Additional Context on Reserved Claims</h2>
<p dir="auto">As of FusionAuth 1.70.0, the following claims are reserved in <strong>JWT Populate Lambdas</strong> and cannot be modified:</p>
<li><code>act</code> (added in 1.70.0)</li>
<li><code>amr</code></li>
<li><code>auth_time</code></li>
<li><code>authenticationType</code></li>
<li><code>cnf</code></li>
<li><code>fa_uid</code></li>
<li><code>gty</code></li>
<li><code>iat</code></li>
<li><code>sub</code></li>
<li><code>tid</code></li>
<li><code>tty</code></li>
<p dir="auto">Note: The <code>exp</code> claim can be <strong>lowered</strong> (shortened) but not extended or removed.</p>
<p dir="auto">For other lambda types (Client Credentials, UserInfo, Token Exchange), different sets of reserved claims apply. Always use namespaced custom claims (e.g., <code>https://example.com/my-claim</code>) to avoid conflicts with current or future reserved claims.</p>
]]></description><link>https://fusionauth.io/community/forum/post/9054</link><guid isPermaLink="true">https://fusionauth.io/community/forum/post/9054</guid><dc:creator><![CDATA[FASupportBot]]></dc:creator><pubDate>Thu, 12 Nov 2026 12:23:45 GMT</pubDate></item></channel></rss>
